04-25-2017 07:16 AM
3,351 ... 107108109110111 ...
tools
  1. wrich2005's Avatar
    My google play services was unusually high (almost twice what the screen on time was) until I disabled location services. Much better now.
    12-20-2015 08:05 PM
  2. anon(9228075)'s Avatar
    Have installed the recent OTA update? T-Mobile here, went to bed after a full charge, 7 hours of standby while I slept, with WiFi, GPS, Bluetooth (connects to my home Panasonic cordless phones to provide an extra line to my landline hookup) and woke up with 95% my best battery performance yet.
    Granted, the first two Note 5's I received from T-Mobile were plagued by poor battery consumption performance and most importantly to me at the time the Bluetooth issue (my Plantronics headset would not stay connected). However, those 2 units didn't have the benefit of 3 OTA updates at least one of which had some fixes for the battery consumption.
    I don't know if it's a hardware or software issue that makes the difference. I am just grateful I finally got a copy that has neither a Bluetooth or battery issue.
    Yes I've installed the last update just the other day.
    12-20-2015 08:29 PM
  3. anon(9228075)'s Avatar
    I went into Google settings and location and mine is off. Is that only place to go? I have location off in the quick setting
    12-20-2015 08:30 PM
  4. anon(9228075)'s Avatar
    I found this youtube video with a few things to try. You can skip to 2:20 on the video to get to the important part.
    There are two main things he mentioned to turn off. Google location history, and Android Device Manager, which is under Device Administrators.
    I just turned them two off and am going to monitor it. If still no good results, then I'm going to call AT&T for a replacement. I just hate getting a refurb for my two month old phone.
    I can't find android device manager. Where is it located? Can you give the menu steps to find it?
    12-20-2015 08:31 PM
  5. maskedcarrot's Avatar
    In Settings / Lock screen / Other Security Settings / Phone administrator.
    In there you should see Android Device Manager. On my Verizon Note 5, it was off by default. On my AT&T Note 5, it was on, so I turned it off.
    12-20-2015 08:50 PM
  6. anon(9228075)'s Avatar
    Thanks.
    What do you know... I'm on Verizon and mine was on. Turned it off.
    What exactly does it do?
    12-20-2015 08:52 PM
  7. JJ Jones's Avatar
    Thanks.
    Allows you to locate your phone in the event you lose it. Also allows for remotely locking and wiping it if it's stolen.
    From my AT&T Platinum Gold Note 5
    12-20-2015 08:54 PM
  8. anon(9228075)'s Avatar
    This. Is. Ridiculous.
    Attached Thumbnails Note 5 Battery life thread-417.jpg ย
    12-20-2015 11:29 PM
  9. Ruben Ocasio's Avatar
    All good here on my AT&T Note 5
    12-20-2015 11:34 PM
  10. RC51 RIDER's Avatar
    Is this good battery life on my Note 5 ?
    Posted via the Android Central App RC51 RIDER W/ NOTE 5
    Attached Thumbnails Note 5 Battery life thread-9523.jpg ย
    12-21-2015 08:16 PM
  11. guacapoli's Avatar
    what theme is that?
    12-22-2015 09:34 AM
  12. Ruben Ocasio's Avatar
    what theme is that?
    What theme is what don't see nothing mate.
    12-22-2015 09:37 AM
  13. anon(9228075)'s Avatar
    Another crappy night of battery life. Lost 18% overnight and had WiFi set on "only on when plugged in" so it was off all night.
    It used to be good overnight. Maybe would lose 4 or 5 %.
    12-22-2015 09:41 AM
  14. maskedcarrot's Avatar
    So today my battery life was pretty good. I don't know if it's a coincidence, or maybe something I was tweaking.
    I woke up, turned on my phone with 100% battery. Uninstalled Gsam, rebooted phone and cleared cache, and turned OFF WiFi. I ran with WiFi turned off all day.
    And my battery life was much better. Phone is on for 15 hours, most of it idling cause I was at work, and I am down to 72% battery left.
    This was with my AT&T Note 5.
    So it appears that I am having the WiFi bug that some on here have mentioned. Sounds like a software bug that won't be fixed until we get Marshmellow. Weird bug though, being as Android has always had better battery life when on WiFi in the past. Samsung's programmers must be slipping.
    One thing I don't understand is that my Verizon Note 5 has version OJ3, and my AT&T Note 5 is still on OJ1. I wonder why AT&T hasn't updated yet?
    12-22-2015 11:34 PM
  15. dlcpa's Avatar
    I just got and LG V 10 and the phone is getting hot and discharging like crazy. From 4 a.m. to 9:45 this morning the phone went from 100% battery life - 30% battery life while I was sleeping. I have a feeling the the LTE radio is killing the phone. It never happened with my galaxy note 2. It got hot at times but only when I was using it. The v10 is getting hot just sitting there.
    I'm charging it now and it doesn't seem to be as hot because I shut off data. That's okay when I'm at home or in the office but when I'm out I need data on. I am having this feeling that the note 5s are having the same problem. If they are, I'm really stuck between a rock and a hard place because switching to a note 5 could give me the same poor life without the possibility of a spare battery. Still using AT&T, like I did on the note 2 and the same programs that I had on the note 2, with probably a few less because I haven't loaded everything up yet.
    I got a free tablet the LG GPad 8 with the phone, of course have to pay AT&T $240 for it over the next two years, but that is essential to share the responsibilities of the day and battery life with the phone. Are there any deals on tablets when you buy a Samsung phone now? I really don't know what to do and my thoughts are even heading towards looking at the iPhone, some of you if you know me, it's just not a place I usually go because of what Apple has done with its tax inversion.
    So, I'm curious what your gonna do and if you're satisfied with your galaxy note 5 then maybe I'll look at that
    12-25-2015 10:30 AM
  16. Ruben Ocasio's Avatar
    Excellent Battery life ๐Ÿ”‹ ๐Ÿ”‹ on my AT&T Note 5 with 1 Day and 8 Hrs And SOT over 5 Hrs.๐Ÿ‘ ๐Ÿ‘๐Ÿ‘๐Ÿ‘
    12-25-2015 03:28 PM
  17. JJ Jones's Avatar
    https://uploads.tapatalk-cdn.com/201...b4707eee6d.jpg
    https://uploads.tapatalk-cdn.com/201...1be7bbfa8e.jpg
    Wow that's excellent! Are you using Package Disabler Pro?
    12-25-2015 09:32 PM
  18. Ruben Ocasio's Avatar
    Yes a few disabled with Package Disabler Pro and the rest bloatware i don't use from settings, All Applications.
    12-25-2015 09:37 PM
  19. KelseyRo4's Avatar
    I hate to be another person asking this question, but can anyone tell me if this looks normal? I'm trying to decide if I should leave my location on or not, and this was with it on.
    Attached Thumbnails Note 5 Battery life thread-15773.jpg ย
    12-25-2015 11:30 PM
  20. linkiik121's Avatar
    Leave it on. It shouldn't have any real impact on the battery.
    12-25-2015 11:34 PM
  21. RC51 RIDER's Avatar
    I have good battery life on my Note 5 frome T mobile , however I'm going to try this tonight and see
    12-25-2015 11:47 PM
  22. linkiik121's Avatar
    Looks good.... Whats Normal is hard to say. Somedays, I get 5 hours screen time, others I get 6+. Depends on a lot of things. Where you go, how much your moving around, what apps you used, was the phone used more outside under the sun or in a darker room, etc... too many things to list.
    With 5 hours SOT. I would say your phone is fine
    12-26-2015 12:24 AM
  23. KelseyRo4's Avatar
    Thanks guys
    12-26-2015 12:40 AM
  24. KelseyRo4's Avatar
    You think so? I just always see people saying to turn it off. I also did a device health check through my verizon, and it said the GPS was draining the battery
    12-26-2015 12:43 AM
  25. KelseyRo4's Avatar
    This is what I was referring to
    Attached Thumbnails Note 5 Battery life thread-15818.jpg ย
    12-26-2015 12:46 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
