04-25-2017 07:16 AM
3,351 ... 108109110111112 ...
tools
  1. Ruben Ocasio's Avatar
    This is what I was referring to
    My location is always on never do i turn it off i keep my location set on wifi and mobile that setting is low which saves you battery.
    12-26-2015 03:32 AM
  2. tan_pg's Avatar
    Im barely getting 20hrs of stand by time with my note 5. Its been 2 months since i got the phone. Sot barely reaches 4hrs. Should i factory reset? Recalibrate the battery?
    12-26-2015 08:50 AM
  3. linkiik121's Avatar
    Depends, it might be normal for you. Could be a low signal or an app that's using a lot of power. We would need to see more info on what's going on. Can you take a screen shot of the battery apps and SOT.
    12-26-2015 10:26 AM
  4. KelseyRo4's Avatar
    My phone drained 9% in 4 hours, while sleeping, with the power saving on. It looks like it all went to the phone radio (I took the picture a little late. When I first woke up the phone it was 14% phone radio and no screen time). Is this normal, or because of a bad signal?
    Attached Thumbnails Note 5 Battery life thread-15846.jpg ย
    12-26-2015 12:09 PM
  5. calicocat2010's Avatar
    My phone drained 10% in 4 hours, while sleeping, with the power saving on. It looks like it all went to the phone radio. Is this normal, or because of a bad signal?
    You're fine. Look at the time you have remaining. Plus you're only losing 2.2 % an hour.
    12-26-2015 12:11 PM
  6. KelseyRo4's Avatar
    Thanks
    12-26-2015 12:12 PM
  7. KelseyRo4's Avatar
    I guess I'm just not used to it because my iphone wouldn't lose any battery power while I slept :/ just curious, why is that, if anyone knows?
    12-26-2015 12:20 PM
  8. Ruben Ocasio's Avatar
    Excellent Battery life so far at 54%
    12-26-2015 12:31 PM
  9. linkiik121's Avatar
    What did you do different about this time vs other?
    12-26-2015 01:11 PM
  10. Ruben Ocasio's Avatar
    That was cause i was in Denver visiting family for Christmas, but now i am home Laramie Wyoming, didn't do any changes , so must of been a weak Network where i was in Denver.
    12-26-2015 01:14 PM
  11. KelseyRo4's Avatar
    Wow that's amazing. I wish I had that battery life!
    12-26-2015 01:24 PM
  12. Ruben Ocasio's Avatar
    At 50 % and SOT over 6Hrs lol
    12-26-2015 01:26 PM
  13. JJ Jones's Avatar
    I'm getting good battery life, but not quite that good. Please share what you disabled with PDP.
    From my AT&T Platinum Gold Note 5
    12-26-2015 01:26 PM
  14. KelseyRo4's Avatar
    Please tell us your secret!
    12-26-2015 03:26 PM
  15. KelseyRo4's Avatar
    Yes a few disabled with Package Disabler Pro and the rest bloatware i don't use from settings, All Applications.
    I downloaded this to see if it'll help. No idea how it works so I just did disable bloatware lol. Fingers crossed!
    12-26-2015 04:34 PM
  16. JJ Jones's Avatar
    You may lose quite a bit of functionality if you chose the "disable bloat ware" option.
    Also, if memory serves, don't go into ultra power saving mode after doing that. I remember reading something about that'll brick the phone.
    washaw likes this.
    12-26-2015 05:59 PM
  17. Ruben Ocasio's Avatar
    Outstanding Battery life ๐Ÿ”‹ ๐Ÿ”‹ ๐Ÿ”‹ On AT&T Note 5 at 26% and i am sure i will get over 9 hrs SOT ๐Ÿ‘๐Ÿ‘๐Ÿ‘
    12-26-2015 06:11 PM
  18. Gps21's Avatar
    I Think LTE is less drain than Wi-Fi and first level of power save I keep always on, no problems. Battery is better than I thought after I removed tons of apps and disable others, some needed two or more attempts.
    12-26-2015 06:41 PM
  19. Ruben Ocasio's Avatar
    Not true see my battery life on post above that was all on my WiFi at home, if i am on 4G LTE i probably get about 6 to 7 hrs on SOT.
    12-26-2015 06:44 PM
  20. Gps21's Avatar
    I don't think the software makes much difference against manual work available, I removed it and achieved best outcome.
    12-26-2015 06:46 PM
  21. Gps21's Avatar
    Could be , I didn't have hard facts, just have feeling it is faster at home - May be usage...I'm on ac
    12-26-2015 06:50 PM
  22. JJ Jones's Avatar
    https://uploads.tapatalk-cdn.com/201...3398ea2264.jpg
    https://uploads.tapatalk-cdn.com/201...c7d7066a38.jpg
    Please do share what's disabled manually and what's disabled by PDP.
    I can get 6 hours fairly easily with what I've disabled, but 9 hours is like my old Turbo.
    12-26-2015 07:32 PM
  23. Ruben Ocasio's Avatar
    Outstanding Note 5 battery life ๐Ÿ”‹ ๐Ÿ”‹ ๐Ÿ”‹ On AT&T
    Here's my final one just plugged it in SOT over 10 hrs plus over a day ๐Ÿ‘๐Ÿ‘๐Ÿ‘
    12-26-2015 09:08 PM
  24. KelseyRo4's Avatar
    Omg is that true?!
    12-26-2015 11:04 PM
  25. KelseyRo4's Avatar
    I found this online: "Note: DO NOT USE ULTRA POWER SAVING MODE IF YOU HAVE COM.SEC.ANDROID.EMERGENCYLAUNCHER DISABLED, It will freeze your phone."
    Thanks!
    12-26-2015 11:08 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
