04-25-2017 07:16 AM
3,351 ... 119120121122123 ...
tools
  1. Kelly Kearns's Avatar
    I don't use messenger, I have an app that allows me to get my messages I'm the Facebook app. I use only the Facebook app and I have to access 4 different Facebook accounts on it.
    01-09-2016 05:01 PM
  2. zCirca's Avatar
    Do you still use Facebook Chat Enabler Reborn (feat. Helper)? I think it was you that linked to that before. I read through all the posts in this thread a few days ago.
    01-09-2016 05:21 PM
  3. Kelly Kearns's Avatar
    Yeah I use that and I stopped updating my Facebook because it stopped working. This is the Facebook version I'm on.
    zCirca likes this.
    01-09-2016 05:37 PM
  4. zCirca's Avatar
    Thank you. I'll look into that
    Kelly Kearns likes this.
    01-09-2016 05:59 PM
  5. aspiller1998's Avatar
    That isn't normal..
    Nope, and at 8pm tonight android system started drinking my battery. It's dropping like crazy now. Earlier today it was going down at a normal rate.
    01-09-2016 07:26 PM
  6. Kelly Kearns's Avatar
    Posted your battery stats page please.
    01-09-2016 07:27 PM
  7. aspiller1998's Avatar
    01-09-2016 07:33 PM
  8. aspiller1998's Avatar
    Won't upload for some reason. Says jpeg file is broken. I'll try again
    01-09-2016 07:35 PM
  9. Kelly Kearns's Avatar
    It is there. Android System isn't too high, higher than mine is normally. I've seen it up to 20 and 30 percent before.
    How many hours of screen time do you have?
    01-09-2016 07:41 PM
  10. aspiller1998's Avatar
    It is there. Android System isn't too high, higher than mine is normally. I've seen AS up to 20 and 30 percent.
    Lol now I see it. SOT is 2 hrs at 48%
    01-09-2016 07:48 PM
  11. Kelly Kearns's Avatar
    Hmm.. 2 hours isn't that good for what you have been using.
    What kind of stuff have you been doing on the phone?
    First, but f you do not have GSAM installed, go to the Play Store and download it.
    Under WiFi and advanced, do you have all of this turned off like I do?
    01-09-2016 07:52 PM
  12. aspiller1998's Avatar
    All are off under WiFi. Today I've been texting people on messenger, facebook, insta, and snap chat. Nothing major like live streaming video or anything, no gaming either.
    01-09-2016 07:56 PM
  13. aspiller1998's Avatar
    And I just installed gsam.
    01-09-2016 07:56 PM
  14. Kelly Kearns's Avatar
    Ok.. Set GSam to keep up with "Since last full charge". Charge your phone before bed, unplug it, let the phone run through the night and then through the day. Then I want you to post your battery stats page again and the screenshot of the GSam page.
    Just use your phone as normal, don't top off the charge during the day, I want to see all the stats on one charge.
    01-09-2016 08:00 PM
  15. aspiller1998's Avatar
    Will do! Thanks so much for trying to help me find out what's going on, I appreciate it! Thing is, when I got this thing in September android system & os were fine and got about 5.5 hrs of SOT total until November and then android system and os started going nuts.
    01-09-2016 08:03 PM
  16. Kelly Kearns's Avatar
    Did you install a new app or get an update?
    You can always try a cache wipe if you haven't done that already. Do you know how to do that?
    01-09-2016 08:04 PM
  17. aspiller1998's Avatar
    No new apps or software updates. I've cleared the cache, disabled bloat, virtually everything I did to my knowledge. Stay awake time still counts up like crazy even in safe mode.
    01-09-2016 08:06 PM
  18. Kelly Kearns's Avatar
    Oh... In safe mode too? That is a problem.
    How long have you had the phone?
    01-09-2016 08:08 PM
  19. aspiller1998's Avatar
    Since the week before last of September. I had this dead on same problem with my galaxy s5, it also stayed awake in safe mode. I even had a software reflash done at best buy and nothing. Since then I gave it to my brother and guess what? Android system and os are now behaving... I do not get this at all.
    01-09-2016 08:10 PM
  20. Kelly Kearns's Avatar
    If it wasn't in safe mode, I would say it is an app causing it.
    You should have had some updates since you got the phone.. Hasn't AT&T released updates? I've gotten an update every month.
    01-09-2016 08:13 PM
  21. aspiller1998's Avatar
    I have gotten updates, but the issue didn't start after the last update which I believe was in October. Not so sure.
    01-09-2016 08:14 PM
  22. Kelly Kearns's Avatar
    When did the issue start for you? AT&T isn't doing the monthly Google security updates?
    What we might do is let you run it normally for one charge and them run it in safe mode for one charge and compare both stats.
    01-09-2016 08:16 PM
  23. aspiller1998's Avatar
    No, AT&T is the slowest carrier on earth with updates. They were the last major carrier for their s5 to get lollipop.
    01-09-2016 08:18 PM
  24. aspiller1998's Avatar
    But this whole issue started thanksgiving weekend.
    01-09-2016 08:18 PM
  25. Kelly Kearns's Avatar
    Yeah I know, I was with AT&T until this past summer. I figured they would be doing the security updates though.
    01-09-2016 08:19 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
