04-25-2017 07:16 AM
3,351 ... 120121122123124 ...
tools
  1. aspiller1998's Avatar
    Yeah I know, I was with AT&T until this past summer. I figured they would be doing the security updates though.
    I checked the update history on their site. Latest one for the note 5 was September 28th.
    Update summary*********
    Effective September 28, 2015, AT&T will release a software update for the Samsung Galaxy*Note 5*(N920A). This update will be made available to customers via Firmware Over The Air (FOTA).*A Wi-Fi connection is required for the update.
    Software update includes
    Support for additional Gear VR featuresSupport for Android for Work (AfW)Enhanced support for the Samsung keyboard accessoryUpdated Samsung Knox to version 2.5.1Other general fixes
    01-09-2016 08:25 PM
  2. Kelly Kearns's Avatar
    That is bad. Samsung is releasing the monthly Google security updates as is T-Mobile.
    01-09-2016 08:48 PM
  3. aspiller1998's Avatar
    Wow, that's att for ya!
    01-09-2016 08:49 PM
  4. Kelly Kearns's Avatar
    Yup that was just one of the many things that made me leave AT&T and go back to T-Mobile.
    01-09-2016 08:49 PM
  5. aspiller1998's Avatar
    I would go with tmo, but they have 0 coverage in my area
    01-09-2016 08:50 PM
  6. Kelly Kearns's Avatar
    That's too bad. For 5 lines with 10 gb of data each and including payments for 5 new phones, our bill is less than it was at AT&T for 5 lines (2 were dumb phones) and 15 gb of shared data and no payments for phones on the bill. TMO even has unlimited data right now, 4 lines for $180..$45 a line. Their phones are also cheaper than AT&T and a lot less bloat.
    01-09-2016 08:54 PM
  7. aspiller1998's Avatar
    Wow! For 3 lines mine is $194...
    01-09-2016 08:57 PM
  8. Kelly Kearns's Avatar
    We got 4 lines for $120 and the 5th line is $20, so 5 lines with true rollover data, 10 gb each line, no sharing, for $140.
    The price and the irritation.. It was just a no brainer to go back to TMO.
    01-09-2016 09:00 PM
  9. Ruben Ocasio's Avatar
    3 lines here 30 gb data 152.00 a month.
    01-09-2016 09:02 PM
  10. aspiller1998's Avatar
    Amazing! I'm in one of those att or Verizon areas. No one. Else works here
    01-09-2016 09:03 PM
  11. Kelly Kearns's Avatar
    Keep checking the TMO coverage though in your area, they are always expanding. Also if you have good TMO coverage in your area but just not at your house they have free LTE boosters and mini cell towers that will give you full coverage, data and cell service, in your house.
    01-09-2016 09:03 PM
  12. aspiller1998's Avatar
    They show my area as a "fair" sigma, with selected devices. I would use wifi calling but my internet is an unlimited att hotspot bc there's no cable or U-verse out here .
    01-09-2016 09:04 PM
  13. Kelly Kearns's Avatar
    Oh.. That unlimited AT&T Hotspot is a good thing to have though. I'm not sure how much TMO charges for unlimited tethering.
    01-09-2016 09:06 PM
  14. aspiller1998's Avatar
    It's an old grandfathered plan totally separate from my post paid phones account. It's an old prepaid iPad unlimited plan. Used 400GB one month, but that's beside the point.
    01-09-2016 09:12 PM
  15. Kelly Kearns's Avatar
    Well I sure wouldn't get rid of that, you will never find that again.
    01-09-2016 09:38 PM
  16. tan_pg's Avatar
    Can somebody help me out here? Went to bed at around 79-75% battery. Turned on ultra power saving mode too, and when i woke up, i was down to 50% after around 5hrs? Thats never happened to me before. Android system and android os popped up and seems to be draining my battery. What's happening?
    01-09-2016 09:39 PM
  17. tan_pg's Avatar
    Whoops here's the pic
    01-09-2016 09:41 PM
  18. aspiller1998's Avatar
    Oh no I'll hang on to it as long as I can.
    Kelly Kearns likes this.
    01-09-2016 09:41 PM
  19. Kelly Kearns's Avatar
    Do you have a dual SIM phone?
    01-09-2016 10:07 PM
  20. tan_pg's Avatar
    Are there note 5's that are only single sim? Yup i do use both sim slots. Ive had the phone for around 4 months now. This is the first time something like this has happened.
    01-09-2016 11:34 PM
  21. Kelly Kearns's Avatar
    Yes, most have a single SIM. That first one, is the signal always that low?
    You will need to do the same thing I said above, charge the phone, run it post the battery stats, install GSam and set it the same and post the stats from that also.
    01-10-2016 12:14 AM
  22. zCirca's Avatar
    Another question: I don't remember anyone posting screenshots of what they have their vibration frequency at (if on at all). May be be a strange question, however, I know it affects battery life or was listed as something to change to help battery life. Possibly what Ruben Ocasio, Kelly Kearns, and others with high SOT/battery life. Thanks
    01-10-2016 12:54 AM
  23. Kelly Kearns's Avatar
    You mean the vibrate for ringing and notifications, etc?
    01-10-2016 12:58 AM
  24. tan_pg's Avatar
    Not always.. ok installed gsam will be posting the stats after. Thanks
    01-10-2016 01:49 AM
  25. zCirca's Avatar
    Yeah, the three options under vibration intensity for calls, notifications, and feedback
    01-10-2016 02:12 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
