04-25-2017 07:16 AM
3,351 ... 123124125126127 ...
tools
  1. Kelly Kearns's Avatar
    You have an average of 26 hours on battery, that is more than a day. You are only using about 6.6% an hour.
    01-11-2016 09:22 PM
  2. aspiller1998's Avatar
    Do you think my WiFi drain is high? It looks like it to me.
    01-11-2016 09:24 PM
  3. Kelly Kearns's Avatar
    I'm not sure, not sure when you turned on WiFi. I've seen a lot of Verizon customers experience a high standby and high drain when WiFi is on, there is a thread about it in the Note 5 forum. I've seen a a few AT&T users have that but only a handful.
    I'm assuming you have WiFi set to sleep when the screen is off, not to scan, no network notifications etc.
    01-11-2016 09:28 PM
  4. aspiller1998's Avatar
    Everything is off in WiFi settings besides it turning off while in stand by. I need WiFi on all the time at home because my data signal isn't the best
    01-11-2016 09:32 PM
  5. Kelly Kearns's Avatar
    Well.. Back when I had AT&T I had my WiFi set to turn off when the phone was sleeping and I still got all my notifications right away.
    You might want to try that setting and see if it helps the battery drain when you're connected to WiFi.
    01-11-2016 09:38 PM
  6. aspiller1998's Avatar
    I'll try it, thanks.
    01-11-2016 09:39 PM
  7. Kelly Kearns's Avatar
    But.. Thinking about it, I was on a microcell, which is why I got my notifications.
    01-11-2016 09:40 PM
  8. Kelly Kearns's Avatar
    I never use WiFi for more than about 5 minutes anymore so I don't even know if my battery drains more on WiFi.
    With my Note 4 I never toggled my WiFi to off and I would get 6-8 hours of SOT and charge only once a day.
    01-11-2016 09:43 PM
  9. dennisharrison's Avatar
    Verizon - disable wifi when screen is off = battery issues resolved for me.
    01-11-2016 10:14 PM
  10. Ruben Ocasio's Avatar
    Battery life On my AT&T Note 5 is still excellent here over 6hrs SOT , wish it would actually show that i been using Tapatalk and Gplus a lot.
    01-12-2016 04:52 PM
  11. Kelly Kearns's Avatar
    Do you always run your battery down that low?
    For just normal everyday use, I try not to let mine get below 30%.
    01-12-2016 05:20 PM
  12. aspiller1998's Avatar
    Battery so far today.
    01-12-2016 05:40 PM
  13. Ruben Ocasio's Avatar
    The answer is No, if you mean me , most the time when i am at 20% i charge it , just was out at hospital so went down to 3 % then i recharged at my car.
    Kelly Kearns likes this.
    01-12-2016 06:53 PM
  14. Ruben Ocasio's Avatar
    So far amazing battery life for today at 42% am over 4hrs SOT so far.
    01-13-2016 11:46 AM
  15. aspiller1998's Avatar
    I've noticed something... the "4G LTE" icon is on a lot when WiFi is on. I thought it was locations services, but thing is that I have them off. Maybe this is causing the drain..? EDIT: just noticed "gpsd" in my battery stats even thought GPS hasn't been enabled once today.
    01-13-2016 03:43 PM
  16. linkiik121's Avatar
    https://uploads.tapatalk-cdn.com/201...cb3b41f337.jpg
    https://uploads.tapatalk-cdn.com/201...8e59577999.jpg
    Is smart switch on? That's weird...
    The gpsd I had that turn on as well before.
    [ATTACH]null[/ATTACH]
    01-13-2016 04:22 PM
  17. aspiller1998's Avatar
    Smart switch is off
    01-13-2016 04:29 PM
  18. ScottH323's Avatar
    Weeks ago I posted about this going on. When on wifi, the phone will periodically connect to LTE also at the same time. I also stated that GPSD has started to show up, and usually uses 10%-15% of fully charged battery. I do not remember seeing GPSD in battery stats before the last firmware update. I wonder what's changed. What exactly is GPSD?
    01-13-2016 07:14 PM
  19. aspiller1998's Avatar
    Usage for today. Horrible SoT... I want to get at least 5-5.5 hrs of SoT. I'm ready to give up...
    01-13-2016 09:10 PM
  20. JJ Jones's Avatar
    https://uploads.tapatalk-cdn.com/201...88fe29abd3.jpghttps://uploads.tapatalk-cdn.com/201...6bb5c70761.jpg
    Try this.....
    For 1 day, delete both Facebook and Facebook Messenger and use the browser for both. Then compare battery stats to what you just posted. I'll bet a dime to a dozen donuts you'll get twice the screen on time. Those 2 apps are battery killers.
    From my AT&T Platinum Gold Note 5
    01-13-2016 10:00 PM
  21. TheMatrix31's Avatar
    Try this.....
    Is it possible for those two apps' use to be shown as "Android System" rather than each individual app by themselves? I don't really use them that heavily but I do have them. FB is at 0.4% of my battery use so far and Messenger is 0.2% according to GSam.
    I ask this because I'm wondering if some apps are being used but showing up as "Android System" which, today anyway, is around 25% of my use as per GSam.
    01-14-2016 02:35 AM
  22. cre8tivspirit's Avatar
    I've had great battery life until yesterday. Normally I'd still have about 45-50% at the end of the day. That's taking it off the charger at 5:30 AM and on the charger around 7:00 PM each night. Yesterday I noticed that I was down to 50% at noon. Thinking that I probably didn't have it sitting in the wireless charger correctly, I brushed it off. Last night I plugged the phone in and made sure it was at 100% this morning. Within 3 hours and minimal usage, my battery has dropped to 68%. Installed Gsam to see what's going on and Android system is using over 28% of my battery. I haven't changed anything, settings wise, or added any new apps recently.
    01-14-2016 07:04 AM
  23. acm1108's Avatar
    I've had great battery life until yesterday. Normally I'd still have about 45-50% at the end of the day. That's taking it off the charger at 5:30 AM and on the charger around 7:00 PM each night. Yesterday I noticed early in the day that I was down to 50% at noon. Thinking that I probably didn't have sitting in the wireless charger correctly, I brushed it off. Later night I plugged the phone in and made sure it was at 100% this morning. Within 3 hours and minimal usage, my battery has dropped to 68%. Installed Gsam to see what's going on and Android system is using over 28% of my battery. I haven't changed anything settings wise or added any new apps recently.
    I'm interested how this one plays out.
    01-14-2016 07:48 AM
  24. JJ Jones's Avatar
    If memory serves, the background services associated with both those apps are a part of Android System, so in a way yes they'd show in that too.
    01-14-2016 07:52 AM
  25. carlosrey23's Avatar
    how did you disable all the bloat apps?
    01-14-2016 09:06 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
