04-25-2017 07:16 AM
3,351 ... 126127128129130 ...
tools
  1. maskedcarrot's Avatar
    This is just silly. The Note 5 and the iPhone 6S cost about the same.
    Why is it Silly? He/She said they wanted to get an iPhone but didn't have the money for one. If you don't have an upgrade available, what's wrong with the way I mentioned to get one? It's similar to getting a credit card.
    heraldo likes this.
    01-20-2016 08:43 PM
  2. Nathan Innocent's Avatar
    I feel like this could be improved even more. What else should I do. I removed most of T-Mobile bloatware, disabled Android Device Manager. Idk what to do now. Is this impressive?
    01-20-2016 09:12 PM
  3. linkiik121's Avatar
    What's the screen time?
    01-20-2016 10:00 PM
  4. calicocat2010's Avatar
    So last night , I had charged my battery to 100% at midnight, went to bed and then woke up to it draining 11%!!! In 7.5 hours. That's to 89%. Now, tonight I charged the phone , and it was full at 100% by 10p.m. IT IS 1:38 AM and I'm down to 65%!! This is insane!!
    Attached Thumbnails Note 5 Battery life thread-1453361942573.jpg   Note 5 Battery life thread-1453361956856.jpg
    01-21-2016 01:41 AM
  5. linkiik121's Avatar
    It happened to me two times seems like 89% is the magic number. The Android OS stayed awake. Just restart the phone and charge it and it'll most likely fix the issue. The second time it was the media server.
    01-21-2016 05:16 AM
  6. migreenberg's Avatar
    Have you tried turning on Do Not Disturb when you go to bed ? I have this set and usually lose 2-5 % overnight.
    01-21-2016 06:33 AM
  7. calicocat2010's Avatar
    I believe in my screenshots, the DND icon was showing. It is set to come on at a specific time.
    01-21-2016 08:55 AM
  8. calicocat2010's Avatar
    I did restart it then charged it. Just woke up, and so I'll see how it goes today.
    01-21-2016 08:56 AM
  9. Nathan Innocent's Avatar
    Five Hours of Screen on Time.
    01-21-2016 10:47 AM
  10. ScottH323's Avatar
    So with GPSD sucking 20% of my battery, I thought I would try to turn off wifi completely. Believe it or not, at 15 hours of use starting at a full charge, I'm only down to 67%. I had wifi searching off too. I only use wifi at home, so I guess I'm just going to toggle it on when I get home.
    01-21-2016 11:36 AM
  11. calicocat2010's Avatar
    Ok, so last night I deleted Dropbox, as I use ES Explorer and I am trying a new Browser, Dolphin....my battery is doing pretty well. It's at 84% and only been up since 845 this morning.
    01-21-2016 12:55 PM
  12. Benn Aff's Avatar
    I lose 3 - 4% per hour on android system usage, when mobile data is on.
    If I turn off mobile data, then i lose 0.5-1% per hour.
    I think, that modem is crazy, because 1 hour in standby Kernel Wake lock lli_pm_wlock: 9m 48s 854ms (771 times)
    01-22-2016 07:13 AM
  13. dlcpa's Avatar
    Sounds good..try draining it all the way to 0%?
    Draining a fixed battery phone down to zero is risky because what if you have to leave when it's at zero? You have a brick. I have a Note 2 with 4 batteries and 2 wall chargers so I'm OK for days.
    Since my phone, which was fried by repeated access to Microsoft Exchange acts (wrong service settings), had been serviced and most parts replaced, it's magnificent.
    01-22-2016 08:57 AM
  14. tentativeuser's Avatar
    I'm new to this thread, which seems to have several thousand previous posts. I have only read a few of them. I hope it will be okay if I share my experience and maybe there will be some suggestions. If there's somewhere else I should or should have posted it, please let me know.
    For Christmas I got an unlocked Verizon-version Note 5 64GB in the US for use elsewhere. I noticed immediately the battery drained rather fast, but assumed this was normal. Now, however, my friends have informed me that it is not. Even with the screen on low, it loses about 1% of battery in about 4 minutes. With the screen on the brightest, it's about 2.
    I'm not a super heavy phone user, but I can barely make through the day without a charger.
    I've uninstalled or disabled all the bloatware that came with the phone, and Facebook too because I've been told it can sometimes use battery without displaying that it's doing so. But now I'm out of ideas. Could it be somehow because my phone is trying to connect to Verizon? Is it something I did? Is my phone a lemon?
    I really like this phone, but I'm very sad and frustrated about this.
    P.S.: If I leave it unplugged while I sleep and turn wi-fi and the screen off, it still runs down about 10%.
    01-22-2016 09:59 AM
  15. guacapoli's Avatar
    I actually just switched from an AT&T Note 5 to a Verizon Note 5 because my job added me to their plan. The battery life is just terrible. I will mostly only use email (manual fetch) and texting and yet my battery will still go down an at incredible rate.
    I'm praying the Marshmallow update will fix this. Part of me wishes I got the Note 4 so I can carry extra batteries. This battery life is just not cutting it.
    01-22-2016 11:29 AM
  16. tentativeuser's Avatar
    I haven't read this thread searching for "Verizon," but is this a common problem with Verizon Note 5's?
    I've half a mind to try and see if I can return it and get another phone. I tend to use phones until they're hopelessly obsolete, but I don't think I can take this battery life for that long.
    01-22-2016 04:55 PM
  17. odb9014's Avatar
    Awwwww yeah!
    01-23-2016 08:12 AM
  18. calicocat2010's Avatar
    Now THIS is soooo much better, and I just woke up.
    01-23-2016 11:32 AM
  19. snppr22's Avatar
    Like the commenter about, tentativeuser, I have not read through much of this thread. I have had my 32 GB VZW Note 5 since October and the battery life has been declining rapidly. On WiFi, with a good 4G signal (and a network extender as backup) and with the screen brightness at auto I am lucky to get 8 hours of battery with maybe 3 hours of screen on time. And that is when I clear the cache and start from a full charge. If I don't clear the cache and restart the phone (at least) daily the battery life will decline. And when I am on the road (I travel for work) it isn't even close. I know that signal is a big factor, but it takes maybe 3 hours of standby with auto brightness and moderate use to get down to 40-50%.
    I have poked around here a bit and I have called Samsung and found some weird information. When I run a diagnostic with the Samsung Plus app it flags that NFL mobile is using a excessive amount of data (2GB in the last 24 hours) even though I disabled it the day I got the phone. Just to be sure I enabled, updated, restarted the phone, and then disabled the app. I cleared the cache and restarted again and a day later it still said that NFL mobile was using an excessive amount of data. Samsung is supposed to call back after they investigate, but I am not holding my breath.
    Anyone have any thoughts?
    01-23-2016 03:07 PM
  20. heraldo's Avatar
    That's the boat I'm in. Well, maybe half as bad. I went to turn the app manger off and it was already turned off. I've been testing different things every night to see what's eating up the battery, like turning off all connectivity and that one I only had like 2% drain for the night. But that means that during the day in standby mode it's still sucking down the power.
    01-23-2016 03:50 PM
  21. calicocat2010's Avatar
    I deleted Chrome Browser as it uses up a lot of data usage , using Dolphin Browser; disabled some more apps or restricted them to the background. I deleted Dropbox, as I use ES Explorer, and now my battery is stellar. I haven't used it heavily yet, but still I'm happy because I definitely won't need to worry about charging.
    01-23-2016 04:01 PM
  22. linkiik121's Avatar
    Have you tried the data saver in chrome?
    01-23-2016 04:42 PM
  23. calicocat2010's Avatar
    No, because I never knew it had one. Where would that be located? Does it help stop the drain on your battery?
    *,Update , I have turned on Data Saver. I'll see how it goes.*
    01-23-2016 05:29 PM
  24. TheMatrix31's Avatar
    I've come to the conclusion that this phone is just randomly up and down for me. After stressing for a while about what happened with my Package Disabler Pro and my phone going haywire with battery once I disabled stuff again + having Knox forced on me (I think maybe I disabled something I shouldn't have, creating some battery issues), I re-enabled everything again disabled stuff, this time only disabling the stuff according to a screenshot I posted in this thread in early December. Just now decided to disable S Finder and S Voice and OneNote. I don't use them but hopefully it doesn't break anything if I disable them with PDP.
    For two days my battery was really, really good with my normal use. Screen time low but I went over 24 hours without having to charge. Fast forward to yesterday and today and it's pretty inexplicable again. Didn't even use Spotify today and my phone is down to 39% and it's only been off battery for 11 hours. Guess this is just how it is.
    01-23-2016 09:39 PM
  25. heraldo's Avatar
    Did you mean data or battery usage?
    I used to use dolphin, but it crashes and then you lose all your tabs.
    01-23-2016 10:07 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
