04-25-2017 07:16 AM
3,351 ... 128129130131132 ...
tools
  1. abdullah1982's Avatar
    I found the biggest drainer in Google Settings>Location Service>Google location history. Turned it Off and saved quiet a lot. Also keep my wifi and 3G always on but keep location off when not using.
    Sd-black theme also saves battery on my phone and I also changed Always allow scanning in wifi>more to scan only when wifi is on. So when I am out of home/office and when wifi is off it doesnt keep scanning. currently getting around 24-30 hours of battery life.
    02-02-2016 12:24 AM
  2. calicocat2010's Avatar
    Yep. That was one of the draining issues. Good job for fixing it!
    02-02-2016 07:36 AM
  3. jlost's Avatar
    Wouldn't that make google now useless?
    02-02-2016 08:33 AM
  4. emad1995's Avatar
    You can still use google now it just won't give you any updates on your current location or eta to, for example, work. Location based reminders won't work either.
    02-02-2016 09:41 AM
  5. jlost's Avatar
    02-02-2016 11:22 AM
  6. pyramidhead2321's Avatar
    Sounds good..try draining it all the way to 0%?
    Not a wise idea as lithium ion batteries don't do well if you deplete them all the way it's a good way to kill the battery for good but if you want it to last then keep it away from 0%. You can drain it to like 2 or 3% but I wouldn't venture lower than that.
    02-02-2016 01:49 PM
  7. pyramidhead2321's Avatar
    There is an app on the Google Play Store called Package Disabler Pro it is a paid app but it is worth it trust me improved my battery life by allot. I used to get around 3 to 4 hours of on screen time with 14 or so hours total on battery and after this I get round 6 to 7 hours on screen time with upwards of 17+ hours of total time on battery. I haven't truly tested it this is just t I get of it by the end of the day sometimes when I'm more active on it there are apps and services that are safe to disable you can experiment with the app if you want to but I'm posting a list of apps that I found on the internet that are safe.
    There are other ways to save battery life that are like disabling location when not in use, using dark wallpapers over colored ones as Super AMOLED displays are better on dark colors. If don't mind black wallpapers for both lock screen and home screen, then that is the best way to go and changing up the theme to a darker theme helps to. Turning off the always scanning feature on the Wi-Fi settings menu helps some to I just read that today. I'm sure there is more you can do to save power like screen timeout. Using Developer Options helps too and it can also speed up your phone to unlock developer options look it up on YouTube to learn how to do it I think it's by tapping on build number a set number of times to get to the build number go to about device or about phone then find build number. In developer options turn on Force GPU Rendering and turn off animations or turn them to .5x if you like the animations I have mine off as I don't care for them. Don't mess with background processes as that will make the phone or device limited in what it can do and may drain the battery more than saving it as it would have to re-open the apps that you use keep it on standard limit and with the other tweaks it will be fine.
    Other apps to install to help with battery life: ShutApp once your setup the apps that you don't want it to kill and place it on the home page of your choice or in a folder of your choice I keep it out on my second page so I can get to it easily. Also change the launcher to one that suits your needs I use Nova launcher prime but you can use which ever one you want to once you set that up on the package disabler pro app disable Touch Wiz app and any other Samsung services you don't use like S-Voice and what not plus what is in the list above you will be set.
    I also use SD Maid Pro as it's the best cleaner I found you can use the free version if you want to but I recommend buying the pro version I used to use Clean Master but I found that one to be intrusive with how it runs in the background and SD Maid isn't intrusive and is simple and easy to use and does the job very well in my book.
    With the lock screen if you don't have it setup for any kind of security and just have it on swipe go to unlock effect and set it to none this will help with speeding up the unlocking of your device. Just like keeping location off unless you need it same goes for Bluetooth and if you’re out and about away from Wi-Fi turn that off as well the only time Wi-Fi should be on is at home, work, or Wi-Fi hot spots like coffee shops and fast food joints. Turning off most of the special features like smart stay and other kind of features like that can help out too and in the long run every little bit helps.
    I think this is the best information I have gathered if I find more I will add to this list or if I forgot anything or if you know of more battery saving techniques please feel free to post a reply and add to this. I wanted to post this info that I have gathered so it's all in one centralized location and you don't have to go all over the place trying to find better ways to save battery like I did. Plus, one post I read this person got their Note 5 to last for 12 hours on screen time and that's amazing I would like to see the iPhone get the same in fact it would be nice if all mobile devices could get that kind of life on one charge. I hope you enjoyed reading this and I hope it helps you achieve better battery life and feel free to comment.
    Note: Package Disabler Pro is for Samsung devices only so if you have a different branded phone skip this app and just use the others and find out more of what you can do with your device.
    Clayspeed01 likes this.
    02-02-2016 02:55 PM
  8. srinathp1988's Avatar
    Is there a specific list of apps you have disabled using package disabler? I read some reviews in play store suggesting that their phone bricked on clicking "disable all bloatware" . So for now I have disbaled only the at&t and Samsung apps which i dont use and I don't see much of a difference in battery life
    02-02-2016 11:17 PM
  9. pyramidhead2321's Avatar
    I followed the list I provided in the post I haven't had any issues with what I disabled. I wouldn't tell the app to disable all bloatware better off doing it manually like I did I can see why that might brick a device as it may think something's bloatware and disable a system service or app that is needed for the OS so long as you follow the list in my post you shouldn't have any issues. What would help is to copy the text from my post into a notepad app on your computer then use the Ctrl+F to find the app as you go down the list in the package disabler app from top to bottom it might take a few to finish the whole list but it's worth it if you ask me.
    02-03-2016 12:56 AM
  10. total_telecom's Avatar
    Should be the NOTE 3 has over 5 hours screen on time 10 hours with a spare battery. Not exactly a leap forward here.
    02-09-2016 02:24 AM
  11. dougdraws's Avatar
    I'm a paranoid battery freak. I have a paranoia of running out of battery...lol
    With a new device fresh out of the box, the first thing you should do is charge it up. You’re basically following the manufacturer’s instructions here, and letting it discharge completely straightaway isn’t a good idea.
    However, this doesn’t mean that you shouldn’t let it discharge at all. You will need to have an idea of how long your battery lasts, so letting the charge run down is something you should do. If you’re concerned about this and don’t want to discharge completely (note this shouldn’t damage a Li-ion cell), wait until the low battery warning shows and then recharge.
    [excerpt taken from Keep Your Android’s Battery Healthy]
    02-09-2016 02:30 PM
  12. Prem Kulpy's Avatar
    Guys is this normal?
    I use mobile data like 12hours per day..
    Screetime on averages 4hrs..
    02-10-2016 10:35 PM
  13. koves's Avatar
    ,subscribed
    02-10-2016 11:21 PM
  14. jjsaw5's Avatar
    Just yesterday, my phone died after being off the charger for 3 hours. Today, same deal.
    Didn't have much on the phone so i factory reset it. Today...full charge battery from 100% to 80 in 1 hour 30 minutes. Haven't touched the phone in that time frame, first time i turned the screen on was to check the life.
    Do you think my battery went bad?
    02-12-2016 02:41 PM
  15. KelseyRo4's Avatar
    Has anyone noticed that their phone holds a charge better when charged with the fast charger as opposed to another one, such as an iPhone charger? I'm starting to wonder if it makes a difference because aside from the voltage being higher on the Samsung charger, idk what other difference there could be. When I use my fast charger, I get about 5 hours SOT. When I use my iphone charger, I get like 3. Could this play a part, or am I crazy lol
    02-12-2016 03:46 PM
  16. nizmoz's Avatar
    Yes
    02-12-2016 06:39 PM
  17. srinathp1988's Avatar
    Yes
    Even if i use wi fi all day i am geting only 4 hours if screen on time (
    02-12-2016 08:36 PM
  18. TheMatrix31's Avatar
    It feels like my phone does better when I use my 3rd party fast charger as opposed to the wireless pad they sent for free when I set up Samsung Pay. Which sucks because I use the wireless pad when I sleep overnight so I don't charge my phone in 40 minutes with the fast charger and have it sit plugged in for multiple hours.
    02-13-2016 02:31 AM
  19. jlost's Avatar
    I had the LG G4 and was able to achieve 5+ hours of on screen time. I switched from Verizon to AT&T and baught the Note 5. So, i am waiting it out to see if i can mirror the same on screen time. Let's see...
    02-13-2016 08:02 AM
  20. sunrat39's Avatar
    Finally!
    I was able to get 4 hours of SOT on VERIZON.
    02-13-2016 09:42 AM
  21. JJ Jones's Avatar
    I have no problem getting that kind of SOT on my AT&T Note. Merely disabled the carrier crap I'll never use through the app manager and it's been great.
    From my AT&T Platinum Gold Note 5
    02-13-2016 09:43 AM
  22. Ruben Ocasio's Avatar
    Android System way to high tho 32% i never seen that on my AT&T Note5.
    02-13-2016 10:18 AM
  23. clevin's Avatar
    Not necessarily, android os is known for doing all kinda of crap in the background, the newer the os version, the worse.
    To check if your battery is fine, do a calibration. When you do it, put the thing in airplane mode and just play mp4 movies in loop.
    02-13-2016 04:21 PM
  24. HOLLYWOODANT215's Avatar
    Wtf %140
    02-13-2016 07:02 PM
  25. calicocat2010's Avatar
    Wtf %140
    WTF????
    02-14-2016 12:11 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
