04-25-2017 07:16 AM
3,351 ... 130131132133134 ...
tools
  1. nizmoz's Avatar
    Not sure how my note 5 is getting this good suddenly but I like!
    mpanju7 likes this.
    02-28-2016 08:07 PM
  2. rainyboy7's Avatar
    Without power saving mode, not bad
    Note 5 Battery life thread-uploadfromtaptalk1456727945053.jpgNote 5 Battery life thread-uploadfromtaptalk1456727953824.jpg
    mpanju7 and zCirca like this.
    02-29-2016 12:39 AM
  3. zCirca's Avatar
    ^^^ that pretty much looks like my stats, however, I even have Facebook Messenger installed and it's usually around my 2nd or 3rd highest drain on on the Android battery stats. Love the battery life.
    02-29-2016 02:25 PM
  4. mpanju7's Avatar
    Do you mind sharing your set up for screen brightness and location services? Do you keep data off or do you mostly use Wi-Fi?
    02-29-2016 07:49 PM
  5. zCirca's Avatar
    I'm not sure about rainyboy7's settings but I've switched to Auto Brightness now. I used to always leave it on a very low brightness (unless in the direct sun of course) but decided to try out Auto and I swear it's somehow better battery life. I leave my location on always and to GPS/Wifi/mobile network mode or High Accuracy on other phones, but I don't have really any app that regularly polls GPS. I manually refresh my weather. I disabled Location History. My data is always on. I try to get on WiFi as much as I can (I turn it off when I absolutely know I can't get on WiFi), I have Never selected for keep WiFi on during sleep, and always allow scanning off. This is all on my AT&T Note 5.
    mpanju7 likes this.
    02-29-2016 11:44 PM
  6. pyramidhead2321's Avatar
    Did you actually read what I posted, in a straight forward assessment or are you simply acting like an android fanboy, discounting the ability to swap out a battery in under one hour at a local Apple store, and not having that same ability where Samsung does NOT have a local authorized repair rep who could do the same?
    After all, THIS is 'the battery thread' and if a power user like myself, who uses the phone for business, and has no Facebook, no Instagram, no twitter, no social accounts on the phone and who requires a battery to last, and can't get a fresh one installed, then an alternative is Apple... WHO CAN DO IT!
    THIS... is the reason for the post (s)... and not some newbie running to iOS!
    You do know that there're online retailers that can do this with the Note 5 and if you can't wait for it there're other Android phones out there that have a removable battery such as the LG G4 or V10 and plenty of others why jump to iPhone over this. No I'm not a fanboy just curious and also as a note this is Android Central ad should have nothing to do with iOS or iPhone yes it may be a battery thread but it's still Android Central meaning only Android related material.
    03-01-2016 12:45 AM
  7. aspiller1998's Avatar
    I've done literally everything possible. FDR multiple times , cleared cache, uninstalled apps, disabled apps, turned off google location services, EVERYTHING. Yet android system continues to drain my battery. Beginning to hate this phone and I'm stuck with it for another year and a half...
    03-01-2016 07:46 PM
  8. Climb14er's Avatar
    I've checked out the repair shops here in Denver and until they can obtain a Samsung Factory battery, they will not use after market batteries. It might be a few months before they can get the authentic batteries.
    Won't be sending my phone away to any online repair shops!
    Might have Samsung send me a warranty replacement phone with a new battery installed. That's about all I will do for now replacing the battery.
    03-01-2016 10:41 PM
  9. Trees's Avatar
    Android System is going to use battery as it represents OS/TouchWiz level apps and processes. Android System on my Note 5 is typically in the 20-24% range. Kernel is typically (Android OS) represent core OS processes, and is typically 10-12%.
    So, I wouldn't worry about Android System and Kernel using battery as they are essential "components" required to run the OS and phone features.
    03-02-2016 06:10 AM
  10. aspiller1998's Avatar
    Yes, but total stay awake used to be 10 minutes in a 16 hr usage time frame. Now it's 45-80 minutes and screen on time is only 2 hrs compared to the original 5.5 hrs.
    03-02-2016 04:08 PM
  11. Trees's Avatar
    Sounds like an app is running that is in turn keeping the OS awake. Maybe a wake detector app will help pinpoint which app is causing the increased awake times.
    msndrstood likes this.
    03-03-2016 06:11 AM
  12. aspiller1998's Avatar
    Can't root WLD requires root
    03-04-2016 07:17 PM
  13. KelseyRo4's Avatar
    Should android system usage be so high?
    03-04-2016 07:20 PM
  14. aspiller1998's Avatar
    Are you running marshmallow ?
    03-04-2016 07:20 PM
  15. KelseyRo4's Avatar
    who? me?
    03-04-2016 07:46 PM
  16. KelseyRo4's Avatar
    Oops here it is
    Attached Thumbnails Note 5 Battery life thread-screenshot_2016-03-04-20-19-02.jpg
    03-04-2016 07:47 PM
  17. aspiller1998's Avatar
    Yes, it seems high, and yes about marshmallow. Verizon released marshmallow today to their Note 5
    03-04-2016 07:48 PM
  18. KelseyRo4's Avatar
    No. I didn't know it came out. I'm gonna download it now.
    03-04-2016 07:54 PM
  19. aspiller1998's Avatar
    Good! Tell me if you actually get it!
    03-04-2016 07:55 PM
  20. KelseyRo4's Avatar
    downloading as we speak
    03-04-2016 08:05 PM
  21. aspiller1998's Avatar
    Sweet!
    03-04-2016 08:06 PM
  22. KelseyRo4's Avatar
    Sweet!
    Done I hope it helps
    03-04-2016 08:41 PM
  23. aspiller1998's Avatar
    How is it? Feel free to post screenshots
    03-04-2016 08:41 PM
  24. KelseyRo4's Avatar
    I already noticed the WiFi bug is fixed. Now when I have WiFi on, mobile data automatically shuts off. Before they ran at the same time. I'll attach some screenshots
    03-04-2016 09:20 PM
  25. aspiller1998's Avatar
    Ah that's good. How's android system behaving?
    03-04-2016 09:21 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
