Save big + get 3 months free! Sign up for ExpressVPN today
04-25-2017 07:16 AM
3,349 ... 2526272829 ...
tools
  1. ebm2010's Avatar
    I don't know.. That is not something I know much about. Let me see if I can get someone that can answer your questions.
    Thank you because this is bothering me a lot. I love my note 5.... I just can't stand the battery standby thing
    bigjunior45 and Kelly Kearns like this.
    08-30-2015 11:59 AM
  2. Kelly Kearns's Avatar
    Just hang out a bit, I'm checking now to see if someone more knowledgeable on this issue has an explanation for you
    08-30-2015 12:00 PM
  3. Kelly Kearns's Avatar
    OK, have you thought about taking the phone back to Verizon, having them switch it out with another new one and see if the problem persists on the new one?
    08-30-2015 12:25 PM
  4. dpham00's Avatar
    If you are in a very weak signal area , you can enable upsm which should shut off data when the screen is off. You can also do this by Tasker and other third party apps. There are also apps that would let you turn on the data at certain intervals like juice defender. I am not a fan of juice defender, but it could be useful in very weak signal areas if set up right
    Sent from my Verizon Samsung Galaxy Note 5
    08-30-2015 12:43 PM
  5. Kelly Kearns's Avatar
    What about why the S4 had low standby but the N5 has high standby. Do you know of a reason it would be different for those two phones?
    08-30-2015 12:48 PM
  6. James8561's Avatar
    for high cell standby, try turning off VoLTE or Advanced Calling
    08-30-2015 12:52 PM
  7. erasat's Avatar
    Was the S4 on Lollipop or Kit Kat, there is a huge difference after Lollipop was introduced, a lot of battery drain that wasn't there before, and Standby is one of those. But not just Lollipop, my S6 Edge was very good on Standby on 5.0.2, once 5.1.1 was installed it has decreased, not a lot but noticeable, still can't find the reason why.
    08-30-2015 12:53 PM
  8. ebm2010's Avatar
    I had lollipop on my S4
    08-30-2015 01:13 PM
  9. ebm2010's Avatar
    I did turn it off. I did a factory reset too and literally everything else people said to do and nothing has worked so far.
    08-30-2015 01:16 PM
  10. Kelly Kearns's Avatar
    At this point, all I know to tell you is to return it where you bought it and have them switch it out and try a new one. I'm sorry, that is all I know to tell you.
    08-30-2015 01:20 PM
  11. dpham00's Avatar
    Not sure why, but there some differences. The Verizon note 5 supports pcs lte, the Verizon s4 doesn't. Also, the s4 had 2 cellular paths. The Note 5 had only one. The s4 had the baseband chip integrated into the soc, both being qualcomm. The Note 5 has a Exynos cpu with a discrete baseband processor.
    It could also be something else. The Note 5 and s6e are very similar and the note 5 has 15% larger battery. Yet in my usage, the note 5 gets 50% better battery life, if not more.
    Disabling volte and changing the mode to lte/cdma are the only things that I can think of, without root.
    08-30-2015 01:20 PM
  12. ebm2010's Avatar
    I did two speed tests under the 4g network.
    Could this be what is affecting my cell standby? It didn't affect the battery on the GS4 but my signal is pretty terrible.
    Regardless, I am going to go to the verizon store tomorrow and I'll either order a new phone or see if I can test out a signal booster
    08-30-2015 02:27 PM
  13. mhunter6378's Avatar
    Yes, low signal strength will drain battery very fast. I was in a seminar for three days last week, signal in the building was bad (1 bar to none usually). On first day of seminar I went from 98% to 53% in 8 hours with no phone use during that time. Days two and three I switched to airplane mode while in the building and lost 2 to 3% the entire time.
    08-30-2015 02:45 PM
  14. smooth4lyfe's Avatar
    Yeah I can't seem to get rid of cell standby I even am using doze now and can't get it to go away.
    If you are on AT&T, turn off HD Voice... That should fix it
    Sent from my Galaxy Note 5!
    08-30-2015 03:18 PM
  15. zazusmc03's Avatar
    I made the switch Tuesday from the iPhone 5s and I'm in love with the battery life on this beast. I'm on my phone all day at work when it's slow and I had to plug my iPhone in by 2 because of horrible battery life. With this phone I sit on it all day at work and don't have to worry about charging it at all!!
    08-30-2015 04:00 PM
  16. H3aTeRzz's Avatar
    Battery update. Day 4
    08-30-2015 04:35 PM
  17. H3aTeRzz's Avatar
    Screen time
    08-30-2015 04:37 PM
  18. H3aTeRzz's Avatar
    3rd
    08-30-2015 04:39 PM
  19. spasell's Avatar
    Attached is my screen. I still don't get anywhere near what everyone else is getting. I don't know why my Alarm clock is coming up as using battery because I only use it when it's on the wireless charging pad.
    Outside of that I'm curious if anyone that sees this sees something unusual. And like others my connection here at home is almost always 3G. I don't get good signal here.
    What pisses me off is with my IPhone 6+ it had great reception due to fact I believe they have more radios in their phones or more bands.
    Edit. Can't attach my screen. I have 9 hours 38 min on battery with 20% left.
    Android System 25%
    Screen 13%
    Cell Standby 8%
    Those are my top ones.
    08-30-2015 04:47 PM
  20. Kelly Kearns's Avatar
    Thanks! Thus is the type info I was looking for.
    With what dpham00 said above, I think the signal booster is the way to go. Your signal is very bad. I had a similar issue when LTE phones came out and I expected them to have a much better signal than my non LTE phone, which was decent or more. That was not the case.
    Better phone, better radio, right? There was much more involved than just the radio.
    08-30-2015 05:00 PM
  21. spasell's Avatar
    Something I noticed. Cell Standby is third on battery usage at 10% Is that normal? All day I've had a steady signal but mostly 3G since I'm on border of 4g.
    But when I clicked on on it standby was 10 37 min which is where my battery unplugged is at right now.
    2nd on that is Time without Signal which was 0. I take it that is good.
    The 3rd item though says Total Connection Time 2 hours 38 min but I don't get that part. Does that mean that's what data was used by my cell because I have WiFi on all the time and it's a strong signal. I don't have VOIP and I didn't get any calls today or call anyone. What would that be?
    Love this device but having switched from iPhone 6+ I never had to worry about battery on that phone. I never changed many settings or Had to get certain apps to ensure I'd have good battery.
    I got 15-18 hours with pretty heavy usage and I'm doing nothing different on this phone and getting 8-10 and that's with using apps to try and get battery extended. So frustrating.
    08-30-2015 05:55 PM
  22. bigjunior45's Avatar
    Still don't understand why instagram is showing up on my battery usage when I haven't opened the app today. Again my standby still sucks
    08-30-2015 06:11 PM
  23. Kelly Kearns's Avatar
    Because Facebook does a lot of crap that phone manufacturers let them get away with.
    Do you use Instagram at all?
    08-30-2015 06:28 PM
  24. Scribbly-One's Avatar
    I am having the same stand by issues as everyone else, have all the changes and things turned off that have been suggested and have cleared cache but it is still at the top of my list day after day.....but battery is still pretty good, been averaging 28 hours with 4.5 hrs of SOT
    08-30-2015 06:29 PM
  25. Kelly Kearns's Avatar
    Can you post your battery page and let me look?
    I know especially for iPhone users it sounds and seems just like you are saying, but it really isn't.
    Yeah you are going to tweak things, some people more than others. Don't get hung up on how many hours though, we all want our battery to last for what we need. Don't get me wrong, we would all love a battery that lasts a week, but you can get too worried about numbers and time. I've seen it happen before. I've gotten 9 hours screen time and 18 hours on a charge at the same time and others wanted that. Well I don't get that every day and I just want to make sure I get the best battery I can for what I need.
    08-30-2015 06:33 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
