04-25-2017 07:16 AM
3,351 ... 2728293031 ...
tools
  1. Kelly Kearns's Avatar
    On the S6 with 5.1.1, there is an option in the Battery menu, it's called Auto Stop, great for all apps that keeps draining the battery on the background. In the S6 is in the Detail button on the Battery Menu, but some other Asian and European carriers moved it to the RAM Management menu, I'm not sure if it's the one on the Smart Manager app, it wasn't very clear when I was told about it.
    Anyways, I talked about this a couple of days ago, and Kelly, tried but it was showing the grayed out detail button that was there also for the S6 before the latest update. I assumed that because of Note 5 and Edge+ have the latest 5.1.1 you were supposed to also have it but it seems that if it's not just some carriers blocking that and others have it, then it's possible that it gets to the new devices with a new update soon, look for it on your phone or keep an eye for it after the next update.
    I just had an app show up there and I could open that. Only thing I could really do was uninstall that app though, no auto stop feature for T-mobile.
    08-30-2015 09:04 PM
  2. erasat's Avatar
    This is how it looks like on my T-Mobile S6 edge.
    Note 5 Battery life thread-screenshot_2015-08-30-22-10-52.png Note 5 Battery life thread-screenshot_2015-08-30-22-11-01.png Note 5 Battery life thread-screenshot_2015-08-30-22-11-06.png
    08-30-2015 09:19 PM
  3. bigjunior45's Avatar
    Logged out of Instagram over an hour ago and it still went up from 5% to 6%
    This phone is awesome but geez the Instagram and Cell Standby battery drain issues is beyond frustrating and quite embarrassing.
    Stop this feature and that feature babying this damn phone to try and stop it from bleeding to death. Though I hated iTunes and got tired of Apple lacking in updated features, at least I didn't have to turn off location, wifi, Bluetooth, HD calling (VoLTE), etc to preserve battery life.
    08-30-2015 09:47 PM
  4. Kelly Kearns's Avatar
    the instagram isn't the phone, but what it does with Android.
    Force stop it.
    I never turn off WiFi or location, rarely use Bluetooth and have VoLTE calling on.
    Remind me again about your signal. Better yet, post me screenshots of your battery and the apps listed under it.
    Also, who is your carrier?
    08-30-2015 09:50 PM
  5. marxbrother8388's Avatar
    I'm mostly on wifi in a well covered Verizon cell area. I lose about 3% an hour and have about 2 hours of screen time a day with some video and I can make it about 16 hours before needing to charge up. It really doesn't matter to me about drain unless I am losing 10-15% an hour. I have chargers everywhere, my car, office, my laptop bag for when I work onsite, 4 or 5 thoughout the house and a one in the glove box of each car in case I need one when I am out. Plus I carry at times a 20000mAh battery pack. Sorry for the winded post
    ladyc0524 likes this.
    08-30-2015 10:09 PM
  6. bigjunior45's Avatar
    Force stop it.
    I have Verizon and here are the screenshots you've requested. Also what apps are involved with Google Services? The only google app I use is Google chrome and I've barely been on it
    Attached Thumbnails Note 5 Battery life thread-1440990508678.jpg   Note 5 Battery life thread-1440990523575.jpg
    08-30-2015 10:10 PM
  7. erasat's Avatar
    My WiFi is ALWAYS on, for Location switch from Best accuracy to power Saving (WiFi and Cell signal) and only switch to Best accuracy when needed pinpoint Location in Google maps or other maps apps, what you need to turn it off in Android and surely not in iPhone because the way Google apps work with them is Location History, on Android, Google integrated one of the biggest battery drainer into Location History, Location reporting. If you want to preserve your battery life with this latest Google Play services you should turn off Location History.
    I don't need to turn off (I think I can't) HD calling but I do turn off VoLTE because first, where I live, is still not available and second, Lollipop introduced a nasty bug, not just for Samsung phones but all of them, at random, where it causes the Cell Standby drain, so yes, from everything you mentioned above, the only thing that you should turn off for sure if you are one of the "lucky ones" is VoLTE, depending on your carrier you can do just that but if it's integrated to HD calling then there's no other way.
    For the other things you mentioned, check what I posted it can greatly help you. One more thing, if you use Location for just Weather updates ( most people do) you don't need that, just enter your city or cities manually and turn off the Current Location option.
    Android is a lot more customizable than iPhone but by default it had tons of features, services and apps on, that they are not on iPhones, so out of the box experience will never be as easy as an iPhone but with a couple of tweaks you can have a very well fine tuned phone, with tons of more features and stuff that you'll love.
    08-30-2015 10:10 PM
  8. Kelly Kearns's Avatar
    Ok, first day on the app, getting ready to charge. These are my stats so far. Will continue testing.
    Attached Thumbnails Note 5 Battery life thread-1440990683743.jpg   Note 5 Battery life thread-1440990696554.jpg
    08-30-2015 10:11 PM
  9. erasat's Avatar
    Yes it works Kelly, I've been using it since April, but now that you have some data with just ShutApp then install Doze again and combine both as the developer intended, then compare and see if you have better results like I've been getting.
    08-30-2015 10:19 PM
  10. bigjunior45's Avatar
    Yes I have VoLTE (HD calling for Verizon) turned off and location history turned off. I also have location set for battery saving mode. I also have my brightness of my phone set under 50%. I also have Wi-Fi turned off when in sleep.
    I don't want to go back to Apple but hopefully some will understand why I would be discouraged in these battery issues and turning some stuff off lol....ugh
    08-30-2015 10:19 PM
  11. Kelly Kearns's Avatar
    Ahhh.. Together. Will try that.
    08-30-2015 10:22 PM
  12. bigjunior45's Avatar
    I'll also screenshot my phone tomorrow after work where I get 1 bar of 4G and see where I'm sitting with cell standby
    08-30-2015 10:23 PM
  13. Kelly Kearns's Avatar
    This is my brightness inside and it is still bright. I turn it up outside.
    Also after the screenshots from work, let's get some from home also and look at both.
    Yes I understand.. If I didn't, I wouldn't still be in this thread spending all this time.
    08-30-2015 10:26 PM
  14. ebm2010's Avatar
    So after turning on airplane mode, I only lost 2-3% battery over 5 hours(That was with wifi enabled). Also for no reason, my phone just restarted itself while it was charging. Anyone know what's up with that?
    08-30-2015 10:32 PM
  15. erasat's Avatar
    I understand and that's why I'm trying to help you, I know that you have been very interested in the Note since it was released and coming from the IPhone exclusively you are used to some things, but that's also why I'm telling you that there will never be an exact experience using one or the other platforms.
    The nature of Android makes for tons of features and services running in the background as you have been experiencing, plus the bloatware that you don't see either on iPhones. In other words, it comes as a mess from factory, there's no way a phone set like that can give you same performance than a fine tuned IPhone. So sadly but it's the truth, unless something change, it's on us to do the tweaks and "fine tuning" that neither Google or Samsung on this case are doing.
    BUT, your carrier has a lot to do with your Cell Standby issues, is the way they configure their radios and options in the phone that cause a lot of issues, that together with the Lollipop bugs, it's what can cause a lot of frustration. If suggest you that if you have done what you have described and it's still doing the same, ask for a replacement and see if the next one at least doesn't have the Standby drain.
    08-30-2015 10:33 PM
  16. Kelly Kearns's Avatar
    Ok, I pushed past the point I would normally charge to see what I could get out of this app.
    I got 8 hours screen time and over 21 hours battery. I'm going to install the second app and see if it does even better. NOW I am charging lol
    Attached Thumbnails Note 5 Battery life thread-1440993432584.jpg   Note 5 Battery life thread-1440993445628.jpg
    smooth4lyfe likes this.
    08-30-2015 10:57 PM
  17. MedicD's Avatar
    Sorry they are so long, but I figured people might like to see what wake lock detector can show you. As you can see, play services is a large drain for me and it's being caused by Google Now, Google Wallet, Google Maps, and a little Gmail.
    Attached Thumbnails Note 5 Battery life thread-1440994049794.jpg   Note 5 Battery life thread-1440994056905.jpg   Note 5 Battery life thread-1440994063005.jpg   Note 5 Battery life thread-1440994069585.jpg   Note 5 Battery life thread-1440994081425.jpg
    belodion and hjsizemore like this.
    08-30-2015 11:08 PM
  18. m3lover1's Avatar
    Battery life has been awesome for me so far. I think I might try that doze app or shutapp soon, currently using greenify.
    Yesterday's stats:
    Today's stats so far:
    08-31-2015 12:06 AM
  19. Kelly Kearns's Avatar
    Yesterday's stats:
    http://i1211.photobucket.com/albums/...psgudibkkz.png
    http://i1211.photobucket.com/albums/...psacymxcbi.png
    I would suggest ShutApp first and then try and add Doze. My battery life today was due to ShutApp.
    08-31-2015 02:46 AM
  20. TheMatrix31's Avatar
    What's a good percentage to lose while I sleep for 7, 8 hours?
    I think I lost like 5% overnight. My Twitter app of choice streams tweets as they come when connected to wifi but I'll look on GSam to see if that's a big % consumer when I wake up.
    I've been getting 20-22 hours on a full charge the last few days since I got the phone but the pattern I'm in, a lot of that chunk is while I'm asleep. I wonder what it'd look like on a normal weekday.
    Is it bad for the battery or phone to keep the phone on the quick charger overnight or does it (presuming it does) do the stop charging/drain a few percent/charge up thing? Since the phone quick charges full in like 40 minutes, that's obviously not a full night of sleep lol.
    08-31-2015 03:26 AM
  21. sup3r1or's Avatar
    I have done factory reset again. Will report of battery life soon. All seems okay for now I'm close to 2 hours so that and have 71% left. Been off charger for 6 hours. Have not enabled Google now yet.
    08-31-2015 05:00 AM
  22. spasell's Avatar
    Man I hear you on the iPhone deal. Switched from iPhone 6+ and actually sent that phone to one of my employees to use so now I have this no matter what. The hardware is fantastic and I want to love it since I didn't have any worries with iPhone. Once I turned that on and changed a few privacy features I was getting 15 hours during the week and 18 or more on weekends on battery. I didn't have to neuter it to make it work.
    That being said I love Android which is why when I saw the Note 5 out and changes I jumped. I will admit I was nervous doing so (first time I've ever been hesitant getting new phone) since for almost a year I never had a single issue with my IPhone. I had some smaller issues with Note 3 that I dropped for that iPhone 6+ and battery was one of them. But with improvements in over a year I was sure this was OK. Reading everyone's battery life it's beyond me how I can't get over 10 hours like many here do.
    08-31-2015 05:13 AM
  23. spasell's Avatar
    What's the name of the app recommended again with Doze? I also have battery doctor installed but not sure I need that. Also have Cleaner which I like
    08-31-2015 05:46 AM
  24. spasell's Avatar
    Ok. So now something called Media Server is taking up battery on this. 3% but I've only been off battery for 1 hour and down to 88% from 98% so 10% loss and I've never even barely used it!!!! Wow. Frustration is mounting.
    08-31-2015 06:28 AM
  25. tanson1011's Avatar
    Media server is from playing music or podcasts.
    08-31-2015 06:51 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
