04-25-2017 07:16 AM
3,351 ... 3031323334 ...
tools
  1. dpham00's Avatar
    thanks for the info...so I downloaded Shutapp and Doze. With shutapp i selected whitelist apps...how often should I close the apps? with "DOZE"... what do I do?
    I would just white list the apps that you want to keep open and shut the rest. Once in a while see what apps opened and white list or shut down accordingly.
    With regards to doze, just let whatever apps you need to be added to the white list.
    Sent from my Verizon Samsung Galaxy Note 5
    08-31-2015 04:28 PM
  2. spasell's Avatar
    So what happened to them then?
    Someone else from a couple years ago on a different thread did the same thing. That person was given Zip Files in the response from forum member and put them bakc. I used those Zip Files So I don't have the originals for Note 5 right now
    08-31-2015 04:49 PM
  3. spasell's Avatar
    You can not actually delete them unless you are rooted, those are system files.
    http://forums.androidcentral.com/htc...tock-ones.html
    There's the link to same thing that happened to this guy. I took the zip fIles from that post. Now I want my Note 5 ones. Don't know where to find them.
    Kelly Kearns likes this.
    08-31-2015 04:52 PM
  4. Kelly Kearns's Avatar
    But you really can't delete them without root.
    Did you do the hard reset and cache wipe?
    08-31-2015 05:13 PM
  5. spasell's Avatar
    If you are referring to the volume up + home key + power then yes I did
    08-31-2015 05:15 PM
  6. Kelly Kearns's Avatar
    No that is a wipe cache.
    And when you went to choose a new ringtone in sounds, nothing is there?
    I was talking about holding power and volume down until it rebooted.
    08-31-2015 05:25 PM
  7. ELAkid's Avatar
    Wow my phones battery has gotten better with timw and today it is doing great, I'm keeping the note 5 for sure
    08-31-2015 05:26 PM
  8. Kelly Kearns's Avatar
    Have you uninstalled both the apps?
    08-31-2015 05:32 PM
  9. Kelly Kearns's Avatar
    Good deal. Once you get everything like you want, the battery does seem to "settle" in. It takes a few days after new or a reset, to settle in.
    08-31-2015 05:33 PM
  10. mhunter6378's Avatar
    Great to hear that. Mine has never been bad, but after several charge cycles, app updates, tweaking things to my liking it's settled in. Lastly, after a few changes last night, I've finally killed off that dang cell standby. Now I'm good.
    08-31-2015 05:35 PM
  11. spasell's Avatar
    There's were no tones. I realized it when I was getting emails and text but no notification sounds.
    When I went into sounds there was nothing to select.
    Now there is when I used that zip file from post just not Note 5 stock sounds. Completely different now
    08-31-2015 05:41 PM
  12. Kelly Kearns's Avatar
    OK, two things I know to do. First a reset, do it from the menu of holding down home, power, volume up. There is a reset option listed above cache wipe, then set it up as a new device when it asks. The second, go by Best Buy, at the Samsung counter ask them to flash it for you.
    I just don't understand how those can be gone, they are system files and you don't even have access without root..
    08-31-2015 05:45 PM
  13. James8561's Avatar
    I'm currently using Doze and DU Battery Saver Pro, which seems to do the same thing as ShutApp but doesn't collect IMEI. What do you guys think of DU?
    08-31-2015 05:49 PM
  14. Glock23-G4's Avatar
    Did you by any chance install something like Zedge, used it to open your ringtones and notifications (thereby setting Zedge as the default), but didn't download/install any sounds?
    This would result in nothing to choose from when you try to set ringtones and notifications from the sound settings.
    08-31-2015 05:50 PM
  15. spasell's Avatar
    When u say set up as new user does that mean I'm going to have to set up everything all over again? I really don't want to go through that again.
    Also what keyboard are you using? Swiftkey? I had it but removed it as it was always showing up under battery issues. Maybe it's not a big deal.
    08-31-2015 05:53 PM
  16. Kelly Kearns's Avatar
    Yeah set it up as a new user. You can try to let it load everything and see if they show up. I'm just trying to figure the easiest way to get it done, reset is the last option I want. Best Buy is a quick and easy way to do it, they just flash the software back on your phone and it is free, but there is some setting up.
    Yeah, I use SwiftKey, have for several years now. It will show on what is used and it never needs to be hibernated. It should never use much battery.
    08-31-2015 05:56 PM
  17. ELAkid's Avatar
    Yeah when I just got the device the adaptive fast charger that came with the device after hours of bring plugged in it wasn't fully charges kinda made me nervous so I started use my note 4 one,and I just hooked up the one that came with the note 5 and it works now It charges all fast, and my battery is great now
    08-31-2015 06:00 PM
  18. spasell's Avatar
    I prefer swiftkey and noticed that in my notifications every day it keeps telling me to select Samsung Keyboard. Drove me nuts.
    I use Google Now Launcher and if I do a hard reset to set-up as new user is that going to disappear as well?
    08-31-2015 06:00 PM
  19. Kelly Kearns's Avatar
    Have not used it. I don't use many battery saving apps, so ShutApp is an exception for me.
    08-31-2015 06:00 PM
  20. spasell's Avatar
    Additionally that means having to disable all that bloatware and stop sync on Google again.
    08-31-2015 06:03 PM
  21. Kelly Kearns's Avatar
    Used to, Samsung wouldn't keep the default keyboard, not an issue now.
    Yes that will. Setting up as a new user you will have to download everything again.
    You can try to reset from the phone and restore when you log into your Gmail and see if they show up.
    Look at the post a couple back concerning Zedge and see if that is an issue for you.
    08-31-2015 06:03 PM
  22. spasell's Avatar
    Wrong post I responded to.
    Wish I could respond using an app vs browser without worrying about battery
    08-31-2015 06:05 PM
  23. spasell's Avatar
    I don't use Zedge but used to.
    08-31-2015 06:06 PM
  24. Kelly Kearns's Avatar
    The app doesn't use a lot of batter. I use AC app, it is just the forums, not Android Central App.
    08-31-2015 06:07 PM
  25. Kelly Kearns's Avatar
    And you don't have to stop sync on Google. I sync Google.
    08-31-2015 06:08 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
