04-25-2017 07:16 AM
3,351 ... 3132333435 ...
tools
  1. spasell's Avatar
    Wanted to ask this. I use Chrome a lot and I remember being able to see all the tabs open. How do I view that and how do I close them all?
    08-31-2015 06:08 PM
  2. Kelly Kearns's Avatar
    Go to settings and then under Merge taps and apps, tap and then that off.
    08-31-2015 06:09 PM
  3. spasell's Avatar
    And you don't have to stop sync on Google. I sync Google.
    So I don't sync it all just calendar mail and contacts. That's what I was told to do to avoid doing unnecessary syncing
    08-31-2015 06:11 PM
  4. Kelly Kearns's Avatar
    Sync what you need. You want Google Photos especially to sync, to save pictures. Look back a few posts, I posted my sync page for Google. It was two screenshots.
    08-31-2015 06:15 PM
  5. spasell's Avatar
    I'll try and scroll back through it to find it. Went back a few pages and didn't see it.
    08-31-2015 06:18 PM
  6. Kelly Kearns's Avatar
    I can just post the screenshots.
    Attached Thumbnails Note 5 Battery life thread-1441063202665.jpg   Note 5 Battery life thread-1441063224099.jpg
    08-31-2015 06:20 PM
  7. spasell's Avatar
    And all of that is found when you click on your Google account from accounts?
    08-31-2015 06:22 PM
  8. Kelly Kearns's Avatar
    Yes, go to accounts, then Google and then click on your Google account. I have 4 Google account on my phone. This is my main personal one and I sync the most with it.
    08-31-2015 06:24 PM
  9. spasell's Avatar
    Part of my issue is that I have a lot of accounts. I don't sync Facebook or LinkedIn or Twitter or Instagram. I have One Drive, Sunrise Calendar and my Samsung Account which I turned off
    08-31-2015 06:31 PM
  10. Kelly Kearns's Avatar
    I have Facebook, Twitter, Samsung, Google Calendar, my Gmail accounts, One Drive, Google Drive and Google Photos.
    08-31-2015 06:32 PM
  11. spasell's Avatar
    So part of the issue I think is the amount that sync. I don't really need my social networks to sync. I use OneDrive for my laptop so I might put that on. Just worried it's going to drain my battery faster and faster the more things sync.
    Do u white list this app as well for ShutApp?
    08-31-2015 06:35 PM
  12. Kelly Kearns's Avatar
    I don't white list this app, I don't use notifications or it would be going off all the time. I also have Android Central App and Tapatalk for this forum. I have push notifications for many thing, but many things don't push notifications through until I turn on the screen. First we need to see the battery running for a few days and sew how things are running. My battery last night get, was not the norm, likely I will never get battery usage like that again.
    Set up the things you want and then let's see what is using a lot of battery.
    Oh I also have beautiful widgets weather, two weather alert apps that do location and poll and also a breaking news app with tons of notifications coming through. I also have a lot of widgets that pull info from the startup of my phone. You don't have to make your phone into a basic phone to get manageable and good battery.
    08-31-2015 06:41 PM
  13. erasat's Avatar
    There's were no tones. I realized it when I was getting emails and text but no notification sounds.
    When I went into sounds there was nothing to select.
    Now there is when I used that zip file from post just not Note 5 stock sounds. Completely different now
    Look for a File Explorer app like ES Explorer that allows you to set hidden files, then look in your root folder and any media folder to set if you can see a file called .nomedia if you have that file in any of the folders it won't show or allow to use any media files in your phone, if it's in the root folder it basically vanishes all your files from the phone UI but you should be able to see the files.
    Sorry if you already mentioned that you looked for the files physically, I haven't read all the thread yet.
    08-31-2015 06:44 PM
  14. MikeekiM's Avatar
    I picked up my phone from the charger this morning at 6am and have purposely kept it away from the charger all day long...
    With light/moderate use, my battery is now at 61% (it is 4pm now...10 hours later). Admittedly, I have not used the phone much today...
    I am optimistic that with the Adaptive Charging, that the Note 5 will largely meet my needs. Supposedly the adaptive charging goes from 0%-50% in 30 minutes, and to 100% in a little over an hour... That means that if you stop by a coffee shop or a restaurant for lunch, and they have an AC outlet available, you can be at 50%-100% while you eat or have you cup of coffee... Not bad, right?
    My main issue is that I like to use my phone as my main (and only) camera...when I am on a personal or business trip, I sometimes take 100 photos in the span of 30-60 minutes. With that use case, the battery burns down pretty quickly, and usually I am not near an AC outlet in those situations... I'll need to get a portable battery that supports adaptive charging. Samsung has one, but it's pretty pricey...their website shows it as going for $69.99 when it releases...
    08-31-2015 06:51 PM
  15. MedicD's Avatar
    So... doesn't shutapp close the Apps very similarly to other app closers, even the built in "close all"?
    08-31-2015 06:54 PM
  16. Kelly Kearns's Avatar
    Here you go.. Very good battery pack and supports quick charge and less expensive.
    http://www.amazon.com/Qualcomm-Certi...cUvbUpU4651919
    08-31-2015 06:56 PM
  17. Kelly Kearns's Avatar
    No, it doesn't" close" them but hibernates them. It is different. It puts them to sleep basically.
    08-31-2015 06:57 PM
  18. spasell's Avatar
    So I need a separate app for that?
    08-31-2015 06:59 PM
  19. spasell's Avatar
    I have a rapid car charger and it works great. I can go from o-50 % in about 20 Minutes with that
    08-31-2015 07:01 PM
  20. spasell's Avatar
    I cannot get my widgets Under control for good battery though.
    08-31-2015 07:02 PM
  21. spasell's Avatar
    I'd also add that the handwriting recognition 'is amazing on this. my handwriting is terrible but it is very accurate. I can almost write faster than typing
    08-31-2015 07:05 PM
  22. Kelly Kearns's Avatar
    Well that is kinda secondary right now. We need to get your battery where it needs to be first.
    08-31-2015 07:05 PM
  23. MikeekiM's Avatar
    Do you have a product link for your rapid charger?
    Kelly Kearns likes this.
    08-31-2015 07:07 PM
  24. MikeekiM's Avatar
    http://www.amazon.com/Qualcomm-Certi...cUvbUpU4651940
    Nice! Thanks!
    08-31-2015 07:08 PM
  25. spasell's Avatar
    Now I need to just find a good thin case. That's in a different forum no doubt
    08-31-2015 07:08 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
