04-25-2017 07:16 AM
3,351 ... 3435363738 ...
tools
  1. tanson1011's Avatar
    Anyone know what this SVF app is? Did a Google search and couldn't find anything on it. I disabled it. See if anything happens to my phone...
    09-01-2015 11:54 AM
  2. Kelly Kearns's Avatar
    Not off the top of my head, but that icon looks like a sync icon..
    09-01-2015 12:02 PM
  3. Kelly Kearns's Avatar
    I've been running the ShutApp and then added Doze and this is what I have after that.
    Attached Thumbnails Note 5 Battery life thread-1441128057597.jpg   Note 5 Battery life thread-1441128066697.jpg
    09-01-2015 12:21 PM
  4. kcodya's Avatar
    Changing "Turn off pen detection" to "off" (as pictured) really helped my battery life, an I can't tell the difference in functionality.
    09-01-2015 12:41 PM
  5. quangtran1's Avatar
    Most definitely. I've always disabled that option.
    smooth4lyfe likes this.
    09-01-2015 12:46 PM
  6. dunamis's Avatar
    what is your carrier? what apps have have you selected on "DOZE"?
    09-01-2015 12:46 PM
  7. erasat's Avatar
    So How does it compares with previous day with just ShutApp?
    The problem is that with Doze's update yesterday some things were changed that affects the way it handles the blocked connections (according to what I was told) so it may be possible that it works even better now, what I'm saying is don't uninstall it just yet if you don't really like it and give it one more full charge cycle and see, then you'll have more data to compare and get to your conclusions.
    09-01-2015 12:52 PM
  8. Kelly Kearns's Avatar
    T-Mobile
    What I'm keeping from dozing is the phone, the clock, messaging, weather alert apps, Geo News, Beautiful Widgets, SwiftKey, Google Photo.
    I'm not sure yet that I can really tell a difference with Doze than without it yet.
    09-01-2015 01:01 PM
  9. MedicD's Avatar
    I think I'm not getting notifications using Shutapp and Doze. When I turn my screen on, I suddenly get a ton of gmails. Haven't tested with text yet, I keep responding via pc
    09-01-2015 01:03 PM
  10. Mariah Richardson's Avatar
    After reading through this thread and seeing people's device temperatures I noticed that mine is slightly higher than everyone else's. It drifts between 93-95 degrees. I do have a case on it, if that makes a difference. What's a normal temp?
    09-01-2015 01:17 PM
  11. erasat's Avatar
    Try adding Gmail, Google Account Manager, Google Play services and Google Services framework to the Active list, I added all of them because the relations they have with each other, and I receive all my Gmails in 2 accounts without any issues.
    I also added Google Backup Transport, Calendar Sync, Contacts Sync and google Play Store, so all the services I want and use, like Google backups and the Sync, don't get affected while the screen is off.
    09-01-2015 01:30 PM
  12. Kelly Kearns's Avatar
    That is a normal temperature. Mine varies. This is the chart for mine. Right now, I'm charging, so it is higher.
    09-01-2015 01:41 PM
  13. Mariah Richardson's Avatar
    Okay, cool. If I post my battery stats would you mind taking a look at it and telling me if it looks normal?
    09-01-2015 01:54 PM
  14. spasell's Avatar
    Want to thank Kelly Kearns for helping me out through my battery issue. I did a full reboot and started from scratch and that seemed to do the trick.
    Unplugged last night and off charger at 100% phone only lost 3% over 5.5 hours.
    Then when off charger I'm getting what appears to work out to 11-12 hours but I'm a heavy user so this is more than acceptable to me.
    Much appreciated Kelly
    09-01-2015 01:57 PM
  15. Kelly Kearns's Avatar
    Sure post what you have.
    On another note, my Note 3 had a motherboard go bad and it was running hot. They didn't worry about it until it was getting up to about 105 and it got even hotter than that.
    09-01-2015 01:59 PM
  16. Mariah Richardson's Avatar
    I was using the phone heavily for a bit until it got down to around 86% then I left it untouched, except for a few texts here and there and receiving a snapchat.
    09-01-2015 02:03 PM
  17. crystinonfire's Avatar
    Also, with the Note 5 how do we view the wake locks like we did on the Note 4?
    I don't think we can, but an alternative is go to Settings-> Battery --> Check --> Abnormal Battery Usage
    09-01-2015 02:12 PM
  18. Kelly Kearns's Avatar
    http://i60.tinypic.com/ng3o1d.png
    So far that looks pretty good. Post a screenshot of your battery graph also.
    09-01-2015 02:27 PM
  19. Mariah Richardson's Avatar
    I don't know if I'm just being paranoid but I feel like it's draining fast, compared to other people's stats on this thread.
    EDIT: Like the battery app says, it used 11% in an hour and a half of very light usage. Doesn't that seem like a lot?
    09-01-2015 02:33 PM
  20. Kelly Kearns's Avatar
    That looks a little fast, but not terribly fast. One thing I noticed is the difference in the cell signal in each screenshot. Are you in a "ok to sometimes bad" coverage area?
    09-01-2015 02:44 PM
  21. AlexMarie15's Avatar
    This was my first day of school use and I'm extremely pleased. Obviously my screen on time is lower than a non-school day, but I LOVE it is my top drainer. On my note 4 this was never the case.
    Attached Thumbnails Note 5 Battery life thread-1441136969451.jpg   Note 5 Battery life thread-1441136979893.jpg
    Kelly Kearns likes this.
    09-01-2015 02:50 PM
  22. Mariah Richardson's Avatar
    Yes, that would be the perfect way to describe it lol. I live in Michigan right on the water with Canada across the water, so signal strength is pretty bad the closer I get to the border. But I've been home this entire time.
    09-01-2015 02:52 PM
  23. crystinonfire's Avatar
    Any suggestions on undoing Facebook updates? .
    Facebook always had an absurd number of wakelocks on my Note 2. We can't check wakelocks with the GSAM app anymore on the Note 5, so I can't really say with 100% certainty that it's the same for the Note 5, but I'd be willing to gamble that it still has a ridiculously high number of wakelocks. My workaround for this is just not using the FB app and using the browser version through Chrome instead.
    09-01-2015 03:08 PM
  24. Kelly Kearns's Avatar
    Well the signal bars in the second screen dropped. Do you know where the graphs are in GSam? There is one for signal. Screenshot that one and post it.
    09-01-2015 03:14 PM
  25. MedicD's Avatar
    Does anyone here use Google Wallet? It has a decent number of wake locks on my phone. My drain, I'm certain, is either Google Wallet or Google Now. Both, I use daily. I would prefer to minimize their battery affect though
    09-01-2015 03:48 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
