04-25-2017 07:16 AM
3,351 ... 4647484950 ...
tools
  1. Kelly Kearns's Avatar
    With greenify you can't use a screen lock?
    Sent from my SM-G928T using Tapatalk
    Yes you can. Just turn the screen lock to swipe, set everything up and then turn the secure lock back on.
    09-06-2015 01:03 PM
  2. Kelly Kearns's Avatar
    Did you you use package Uninstaller on those apps?
    Sent from my Verizon Samsung Galaxy Note 5
    No, I haven't tried that app, thinking about trying it.
    09-06-2015 01:04 PM
  3. Chitown28's Avatar
    I just noticed that how do we get them to really stop running in the backround?
    09-06-2015 01:26 PM
  4. dpham00's Avatar
    Mistyped... Should have been package disabler
    You can disable or uninstall using package disabler. I would advise against uninstalling though.
    http://forum.xda-developers.com/note...ote-5-t3184563
    09-06-2015 02:00 PM
  5. Chitown28's Avatar
    Today these are my battery results with battery percentage at 10%=
    10h 37m battery on time.
    Android system 14% 2hr 31m
    cell standby 10% 2h 25m
    screen on 7% time on 4hr 1m
    unkilled game 8%
    does this seem normal?
    Auto brightness off. Sync always on. Wifi options all off besides pass point should i turn it off? All spen options off since i really dont use it. Text size all set to large if that makes a difference. Tmobile 4g lte always on or using wifi at home.
    Also wanna add that i never let my phone go down past 10% cause they say its bad for the battery to go completely dead so i always plug it up when it gets down to 10%.
    rubbertube likes this.
    09-06-2015 02:31 PM
  6. Chitown28's Avatar
    so is this bad?
    09-06-2015 03:12 PM
  7. Almeuit's Avatar
    so is this bad?
    This looks like data usage versus battery usage.
    09-06-2015 03:29 PM
  8. Chitown28's Avatar
    right but im wondering what does removed apps mean and why are they still running in the backround if there removed?
    09-06-2015 03:35 PM
  9. Almeuit's Avatar
    That doesn't mean they were running in the background after being removed. That is just how much data was used before they were removed. Instead of the phone forgetting how much an app (like Facebook) uses once it is removed it just clumps it into "Removed ,Apps". Since the app is gone it isn't using any more.
    Chitown28 likes this.
    09-06-2015 03:37 PM
  10. Veldrid_13's Avatar
    I get horrible battery life. Have to charge twice a day.
    09-06-2015 06:14 PM
  11. eclectic11's Avatar
    Today
    Attached Thumbnails Note 5 Battery life thread-1738.jpg   Note 5 Battery life thread-1739.jpg
    09-06-2015 07:55 PM
  12. Chitown28's Avatar
    i feel your pain! I miss my phone i had before this which had a 3400mah battery I would do the same stuff i do with this phone and it would last me on one charge the whole day and even some more the next i cannot get that with this phone! When i wake up everyday im usually non stop on the note 5 for 2.5hrs checking facebook,instagram,youtube,web browsing,gmail,etc and then after i use it here and there throughout the day and max id get is 10hrs a day with this phone at 10% left and thats with wifi on,4g lte,auto brightness off, all spen options off,etc but im gonna hang onto it as i love all the other awesome stuff about it and hope they will send a update that will give us more battery time if not i have a feeling the iphone 6s plus gonna have better battery life then the note 5 so ill get that instead or give the moto x pure edition a shot. Alot of the battery life is being sucked up by stupid cell standby when i have wifi on so i hope they get that fixed!
    09-06-2015 08:04 PM
  13. Chitown28's Avatar
    you have power saving mode on i never have it on is why your battery life is better. I hate when i put it on it makes my phone run like crap!
    09-06-2015 08:04 PM
  14. Chitown28's Avatar
    i watched a couple youtube phone reviews on the note 5 too and they say the battery isnt that great and wish they would have put a bigger battery in it.
    Sammuel1973 likes this.
    09-06-2015 08:10 PM
  15. MedicD's Avatar
    Yeah, power saving mode helps big time. I wish they'd let you have more control over the power save features. I'd like to keep the button lights on and the vibrate feedback. Other than those 2 things, I don't notice a difference in phone behavior between normal mode and power save.
    09-06-2015 08:25 PM
  16. spasell's Avatar
    But you have right below that option the Allow always scanning on, turn that off.
    So I turned that off and still I am getting WiFi on when I turn the screen off. I don't get it.
    I set I right and when I turn the screen on after it's been sitting off for 5-10 min the WiFi symbol is right there and GSM shows WiFi and cell signal are almost identical in times
    09-06-2015 08:27 PM
  17. Sammuel1973's Avatar
    I agree, a bigger battery would have most likely kept me from returning it. A bigger battery may mean a thicker phone, but who cares. Anyway, it is what it is. I too hope that an update be released soon to fix the issue as it did with the S6 and S6E. Consumers shouldn't need to fiddle with a new phone this much, imo.
    09-06-2015 08:29 PM
  18. Chitown28's Avatar
    yea i hate how you cant control the power saving mode anymore.
    09-06-2015 08:41 PM
  19. Chitown28's Avatar
    So you returned yours? and yea i dont mind a thicker phone i had a zte zmax before and it lasted a day and even some more the next on one charge but it didnt have anything great like the note 5. Totally agree with you on this one=Consumers shouldn't need to fiddle with a new phone this much, imo.
    09-06-2015 08:44 PM
  20. eclectic11's Avatar
    I only turned power saving mode on today once I hit 6 hours SOT and 18% because I was trying to see how far I could go. Here is the screen shot at 18% with no power saving modeNote 5 Battery life thread-1732.jpg
    09-06-2015 08:45 PM
  21. Sammuel1973's Avatar
    Yes, cuz of the battery and a few other issues that I have explained on another thread. This thread is about attempted battery fixes.
    09-06-2015 08:50 PM
  22. erasat's Avatar
    Which carrier is it? If you are under the 14 days buyers remorse period, just return that phone and get a new one, with what I've read from you there are too many things going on, I think that at this point you should try with a new one.
    One thing though, that 3G there never mean anything good for the Samsung phones, there is this girl from Australia on the S6 forum with Telstra service and we have tried for months to fix her battery drain at home where she is 24/7 and there is nothing that can be done about it, at least she recognizes that and has adjusted her usage so she can live with it, where she is right now, she is finally happy but she has done every little tweak on the books. I don't know your specific details about your signal but believe me, if that screenshot is a sample of your normal usage, it will be very hard to fix your battery drain.
    09-06-2015 08:50 PM
  23. dpham00's Avatar
    Can you use the Galaxy light app to turn on the button lights?
    09-06-2015 09:40 PM
  24. da3lynx's Avatar
    My best sot so far, never thought I'd see the day where I would be close to 4 hours lol. Note 5 Battery life thread-uploadfromtaptalk1441595056448.jpgNote 5 Battery life thread-uploadfromtaptalk1441595067287.jpg
    09-06-2015 10:04 PM
  25. James8561's Avatar
    just want to chime in with a little personal experience
    If you've done everything and applied every tweak available and turned off all extra radios, etc and your battery life is still below 12 hours, then it may be a good idea to exchange your device. I did that and got great battery life afterwards
    09-06-2015 10:53 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
