04-25-2017 07:16 AM
3,351 ... 4849505152 ...
tools
  1. spasell's Avatar
    So I was using Outlook for email as well as Gmail. During my battery issues I decided to go with just Gmail and I deleted outlook. I'm wondering if anyone knows if having two different email apps would hurt battery at all.
    I prefer Outlook for all the extra features it offers. Any idea of an impact on that?
    09-07-2015 08:30 PM
  2. Kelly Kearns's Avatar
    I just dont get why your backing up the note 5 so much like anything we post about it being bad you always dont agree.....We dont use the same apps and settings as you so you cant keep saying the note 5 battery is good and i can link you to about 8 reviews i watched and they state the battery isnt that great and is a downside of the phone.
    I'm not going to lie about results I get.
    Also, as I said, I checked a lot on this phone before it was released and the testing that was done. Just because you didn't see all that doesn't mean it wasn't there.
    I can link you to just as many, that think it is just as good and just as many that think it is worse, on here.
    09-07-2015 09:17 PM
  3. Kelly Kearns's Avatar
    I've run both before and not had noticeable issues.. But I don't have a Verizon variant. I'm not having the WiFi standby increase and I also am not dealing with a low signal.
    09-07-2015 09:20 PM
  4. ClintRo's Avatar
    This is a really light day at home with a good signal. Even with light use my work apps still draw quite a bit of the power.
    Wifi off all day
    Sent from my SM-N920V using Tapatalk
    09-07-2015 09:42 PM
  5. Kelly Kearns's Avatar
    Wifi off all day
    What apps do you use for work?
    09-07-2015 10:06 PM
  6. ClintRo's Avatar
    The Good suite of apps.
    Kelly Kearns likes this.
    09-07-2015 10:14 PM
  7. dpham00's Avatar
    Wifi off all day
    https://images.tapatalk-cdn.com/15/09...78b4d5fcfc.jpg
    Your held awake time is pretty high. Almost like your phone isn't sleeping. I would run wld
    http://forums.androidcentral.com/sam...-required.html
    For comparison, look at mine
    Sent from my Verizon Samsung Galaxy Note 5
    09-07-2015 10:49 PM
  8. dario12v's Avatar
    Same here , can't seam to be able to shut off wifi scanning, or even shut off when sleeping
    Everything is off ...but it keeps going!!
    T-mobile 64gb note 5 here
    09-07-2015 10:59 PM
  9. dpham00's Avatar
    That's weird. On my Verizon version, I shut off wifi and wifi scanning.
    09-07-2015 11:08 PM
  10. moonsunlala's Avatar
    Android system consuming so much battery but the phone most of the time is in standby mode=/
    *Tried to wipe cache seems like not working
    Note 5 Battery life thread-uploadfromtaptalk1441687358982.jpgClick image for larger version.
    Sent from my SM-N9208 using Tapatalk
    Attached Thumbnails Note 5 Battery life thread-uploadfromtaptalk1441687315923.jpg
    09-07-2015 11:47 PM
  11. Kelly Kearns's Avatar
    Same with the T-Mobile version.
    09-07-2015 11:48 PM
  12. spasell's Avatar
    Yes so did I but do you show in GSM that cell and WiFi are the same?
    09-08-2015 05:09 AM
  13. spasell's Avatar
    So it says you can use this without being rooted but might need to install something else?
    09-08-2015 05:15 AM
  14. Kelly Kearns's Avatar
    He doesn't use WiFi.
    Again, I think GSam reports the WiFi just when the toggle is turned on. Mine goes to sleep and GSam reports the WiFi as always on.
    09-08-2015 05:39 AM
  15. Kelly Kearns's Avatar
    You don't have to install anything else. Just check what you want disabled.
    09-08-2015 05:40 AM
  16. vamp07's Avatar
ID:	195542Click image for larger version.
    Looks to me like it's mostly screen on doing the consuming. Not the system.
    Sent from my Nexus 6 using Tapatalk
    09-08-2015 06:25 AM
  17. MedicD's Avatar
    27% drain in 3 hours and only 48 minutes screen time isn't that good. Something is draining it
    09-08-2015 07:40 AM
  18. Note5User's Avatar
    I turned off WiFi and was only on 4g whole the day amazingly i got more than 24hours. With Same usage on wifi it hardly got 10 hours.
    09-08-2015 10:10 AM
  19. Kelly Kearns's Avatar
    I turned of WiFi and was only on 4g whole the day amazingly i got more than 24hours. With Same usage on wifi it hardly got 10 hours.
    Are you on Verizon?
    09-08-2015 10:12 AM
  20. Note5User's Avatar
    Try using only on 4g/3g. Even it used to drain very fast over wifi to me. Once i switch to use only 4G its giving better life.
    09-08-2015 10:14 AM
  21. Note5User's Avatar
    Are you on Verizon?
    ATT
    09-08-2015 10:14 AM
  22. Kelly Kearns's Avatar
    Ok, final with using my Note 4 for two days and picking up my Note 5 a few times, almost 4 total hours of use. I still have about 5-7 hours left of battery, but am going to go ahead and charge it.
    WiFi and location on the entire time and WiFi to never stay on while sleeping. I'm still running ShutApp.
    Attached Thumbnails Note 5 Battery life thread-1441725326675.jpg   Note 5 Battery life thread-1441725337362.jpg   Note 5 Battery life thread-1441725349482.jpg
    09-08-2015 10:16 AM
  23. vm81's Avatar
    I am on Verizon and am seeing same stuff - Very good battery on 4G LTE but horrible battery life on WiFi. This needs to be fixed...as just turning off WiFi is not an option for lot of people - they are on tiered data.
    09-08-2015 10:18 AM
  24. erasat's Avatar
    I don't have Verizon, I have T-Mobile, can you post screenshots of the Wifi Settings Advance Settings options, and any other screen related to VoLTE or Advance calling or anything similar? I want to see those menus to see if we can find a good combination of settings until Verizon can take care of any issues they may have related to wifi usage.
    09-08-2015 10:32 AM
  25. Note5User's Avatar
    I am on ATT. Even my battery drains very fast over wifi. i have tried connecting to different Wifi aswel like Home, Friend Home, Office same issue.
    09-08-2015 10:46 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
