spasell
Well this is mine and I'm about to charge because I'm going out. This is with 5 hours SOT.
Would you be willing to share your EXACT settings you have for the device? Things you shut off to not sync. Things you disabled specifically (I disabled all Verizon stuff except My Verizon app since it's greyed out and wont let me disable), accounts you have and what you leave to sync? Is your WiFi always on. Do u sleep WiFi when screen is off? Location on and your settings. And anything else I've missed including social media accounts you have and apps you might have installed from battery monitoring and performance.
Also do you use the Gmail app or something else or both? Any calendar apps as well.
I'd like to test as close to your settings as I can get and then pinpoint if mine is simply cell reception.
Also so you have Google app on or off?
Thanks
