Originally Posted by
calicocat2010 Right, the Package Disabler Pro says to backup apps first. I'm wanting to know what would be a good recommendation for an App to backup and restore apps. I'm looking for specifically backing up Apps. I already use the cloud to sync and backup files, contacts, music, video.
If you are just disabling apps, no need to backup first. You can simply enable the apps through the app if you need them again.
Backup is only required when you uninstall apps.
Sent from my Verizon Samsung Galaxy Note 5
