04-25-2017 07:16 AM
3,351 ... 5758596061 ...
tools
  1. Fr0gburp3r's Avatar
    I disabled a lot of bloatware at around noon.Note 5 Battery life thread-uploadfromtaptalk1442198658055.jpgNote 5 Battery life thread-uploadfromtaptalk1442198670713.jpg
    09-13-2015 09:44 PM
  2. jdhooghe's Avatar
    I disabled a lot of bloatware at around noon.Click image for larger version.
ID:	196640Click image for larger version.
    8 hr SOT is amazing!
    Sent from my SM-N920T using Tapatalk
    09-13-2015 11:02 PM
  3. MagicMan2020's Avatar
    Anybody else see the problem with this? This has been my battery life for the past several days and it's really pissing me off. Any ideas anyone?Note 5 Battery life thread-screenshot_2015-09-12-00-16-48.jpg
    This was from a couple of days ago
    09-13-2015 11:22 PM
  4. pdqgp's Avatar
    I have my camera set to capture RAW and am in single shot PRO mode and can't seem to find the .dng files only .jpg files?
    I am using package disabler and am wondering if I turned off something related to shooting RAW.
    Any insight?
    09-13-2015 11:23 PM
  5. MagicMan2020's Avatar
    Anybody else see this as a problem? My battery life was solid before the past couple of days and it has absolutely tanked. Maybe my perception is wrong but this doesn't seem normal to me Note 5 Battery life thread-screenshot_2015-09-12-00-16-48.jpg
    09-13-2015 11:23 PM
  6. MagicMan2020's Avatar
    Sorry guys didn't mean to double post, my apologies
    09-13-2015 11:27 PM
  7. jdhooghe's Avatar
    Anybody else see this as a problem? My battery life was solid before the past couple of days and it has absolutely tanked. Maybe my perception is wrong but this doesn't seem normal to me Click image for larger version.
    If a battery optimizer is using 5 percent of your battety, it is not a battery optimizer; get rid of it. Your phone is not sleeping which means apps are pinging it awake. How many apps do you have and have you gone into each one and optimized their notifications for your use? You don't need push notifications on every single app or you're going to get terrible battery life
    09-13-2015 11:30 PM
  8. Fr0gburp3r's Avatar
    Any insight?
    Your phone doesn't come with an app that can display RAW images which is why you can't see it in your gallery.. You have to install a 3rd party app from the Play Store that can view those files.
    09-13-2015 11:42 PM
  9. MagicMan2020's Avatar
    Alright so I went thru and disabled notifications for the apps that come alot (Bleacher Report, Fantasy apps). So theoretically, that should allow my phone to actually sleep and stop "android system" from taking an abnormally high amount of battery?
    09-13-2015 11:44 PM
  10. pdqgp's Avatar
    Got it. I found the directory on the phone where the .dng files are located. What I've found so far is I can highlight them and "share" or copy them to a RAW Folder on my Google Drive which I have access to on my Photography Machine. From there it's business as usual with Adobe. I was just thrown for a loop in trying to figure where they were being put on my phone.
    Thanks!
    09-13-2015 11:52 PM
  11. ELAkid's Avatar
    My screen on time keeps improving
    09-14-2015 12:08 AM
  12. Chitown28's Avatar
    can you please show us which ones you have disabled?
    Is it ok to disable yahoo live weather,galaxy apps,galaxy apps widget,and app source?
    what do you mean by optimized their notifications for your use?
    09-14-2015 12:24 AM
  13. smooth4lyfe's Avatar
    Man Idk if I can beat that lol
    Sent from my Galaxy Note 5!
    09-14-2015 12:39 AM
  14. Almeuit's Avatar
    Mod Note - Again... please keep it on topic. This thread is for discussing battery stats & getting help (if needed). This is not a thread to argue battery semantics.
    Thanks.
    09-14-2015 12:58 AM
  15. Fr0gburp3r's Avatar
    I just used Package disabler Pro and chose disable all bloatware. Then I select show all disabled. Finally, I enabled the ones I would use.
    I disabled yahoo live weather etc...
    njshoremom4gurlz likes this.
    09-14-2015 01:51 AM
  16. Chitown28's Avatar
    And doing just that helped your battery that much? Even if your using wifi,facebook,instagram,youtube,gmail etc?
    09-14-2015 02:16 AM
  17. spasell's Avatar
    Converting back before an upgrade is a snap. No need to connect. All done on phone. At 78% now but been out and about all day. Up today at 8am. No charges.
    Sent from my SAMSUNG-SM-N920A
    OK. So what is the name of the app you do this with and do I need to be connected to laptop to perform this option?
    09-14-2015 06:34 AM
  18. njshoremom4gurlz's Avatar
    I was going to write the same thing battery app is draining a lot of your battery
    Sent from my iPhone using Tapatalk
    09-14-2015 06:53 AM
  19. calicocat2010's Avatar
    He is using Package Disabler Pro. I am.using it too. I'll see how it goes today from 100%.
    09-14-2015 07:23 AM
  20. dpham00's Avatar
    Overnight drain.
    Sent from my Verizon Samsung Galaxy Note 5
    09-14-2015 07:55 AM
  21. dpham00's Avatar
    If you are disabling in the application manager, then anything it let's you disable should be fine.
    09-14-2015 07:59 AM
  22. El Platanero's Avatar
    Looks like I was way off on my assumption that the battery life would be bad. So far it's damn good
    https://images.tapatalk-cdn.com/15/08...ea887e98e6.jpg
    I'm on the same page. The note 4 was a great phone but this thing hums and lasts.
    09-14-2015 09:45 AM
  23. Kingster99's Avatar
    I was having the same problem. i took it to the Samsung guy at Best Buy, he put it in ultra power saving mode then restarted it and then took it out of ultra power saving mode and within a day or so i saw a big improvement with my battery performance.
    09-14-2015 11:39 AM
  24. Glock23-G4's Avatar
    Fairly heavy use at home yesterday on a lazy Sunday.
    A few brief calls, some texting, email, Facebook, Tapatalk, Netflix, Words with Friends, etc...
    Brightness on auto, bluetooth on all day (syncs with my fitbit and Bowflex Max), wifi on, advanced calling on. I've disabled/uninstalled apps that I don't need or use, but I don't use anything like package disabler to disable services or anything like that.
    Pretty happy with my battery life.
    09-14-2015 11:49 AM
  25. pdqgp's Avatar
    Update from today. Woke up and pulled my Note 5 off the charger at 6am and it's now 2:20pm and I'm at 73% charge. Moderate to heavy use, screen at 50% which is plenty bright inside and with bluetooth connected to my Gear S and low power location services turned on too.
    VERY Happy with the battery life out of it so far.
    09-14-2015 01:21 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
