04-25-2017 07:16 AM
3,351 ... 5960616263 ...
tools
  1. jdhooghe's Avatar
    Neat app... Looks like rooting the phone is required... The app does suggest a workaround...
    Does the workaround work on the Note 5?
    Have you rooted your phone to use this app?
    There is a workaround and no root is required. You need to install some tools on your computer but here are step-by-step instructions: https://docs.google.com/presentation...dit#slide=id.p
    It seems like using Instagram and Facebook together exacerbate the issue. Any app that requires facebook whether it be login or syncing will wake it up, it seems. Since Instragram is connected to facebook they ping-pong off each other. I have limited background data, I have turned off notifications but they still won't stop waking the phone up. At least with the browser you wont have to deal with the app waking your phone up from deep sleep though. I use Instagram though and there are no third party alternatives that I know of.
    Baby_Doc and 1stGalaxyS3 like this.
    09-17-2015 03:31 AM
  2. Nathan Innocent's Avatar
    Hey guys,
    The update for my Note 5 has given me a problem. I noticed faster battery drain due to "Cell Standby" taking up 20% of my overall battery and it was first on the chart underneath the battery stats. Can you guys please tell me how to get rid of this issue? I already turned off VoLTE
    09-17-2015 04:31 AM
  3. billykac's Avatar
    I've had an N5 for a couple of weeks now, and battery life initially was wonderful, for my use case.
    Then, in dealing with a BT auto-connect issue, I wiped System Cache in Recovery and since then, battery life is even better! Could it be the wipe, or is the phone learning or just settling-in over time.
    Thrilled with battery life on the N5!
    09-17-2015 06:48 AM
  4. proctorc's Avatar
    I have seen great battery life with my Note 5. Try this app called “Trepn Profiler”. Its by Qualcomm and it can give you a more task manager like data by process and help you understand where is the leak. There are several guides on google on how to use it to figure out battery issues.
    dpham00 likes this.
    09-17-2015 09:07 AM
  5. sshafranko's Avatar
    Same here. Just got update this morning ...after 11 hour workday...normally at around 60 percent. Today at 35%. What gives?
    Let it settle in for a couple chatge cycles. I beleive last update may have included some kernel tweaking do to video calling but jist guessing. Also after update wipe caches it helps sometimes.
    09-17-2015 02:55 PM
  6. sshafranko's Avatar
    I want to post my stats i think you guys will get a kick out of it but i need a couple more posts☺
    09-17-2015 02:56 PM
  7. calicocat2010's Avatar
    Then go to other forum posts and give your opinions on them. Your post count will increase tremendously.
    09-17-2015 03:03 PM
  8. sshafranko's Avatar
    K think i got it now lol...thanx
    1stGalaxyS3 likes this.
    09-17-2015 03:27 PM
  9. HOLLYWOODANT215's Avatar
    Sheesh
    09-17-2015 03:38 PM
  10. calicocat2010's Avatar
    Alright, WHAT steps , apps, did you use to get this AMAZING battery life? ARE you even USING your phone? lol.
    Light usage, medium, heavy?
    09-17-2015 04:00 PM
  11. drone3's Avatar
    That is insane, are you rooted?
    dreaming of electric sheep
    09-17-2015 04:04 PM
  12. laestrella's Avatar
    I want to know if people actually use their phones for calls.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Frozen Corpse likes this.
    09-17-2015 04:07 PM
  13. ClintRo's Avatar
    Rarely!! Lol
    Sent from my SM-N920V using Tapatalk
    09-17-2015 04:14 PM
  14. laestrella's Avatar
    Rarely!! Lol
    That's the trend that I see lol. Maybe I could get 7 hours then. But I do about 2 + hours of calls daily.
    09-17-2015 04:17 PM
  15. Almeuit's Avatar
    I usually average around 1-1.5k minutes a month (and 2k+ text msgs). This month has been kind of light for me though.
    Maybe that is what saved my battery life on my devices? Talking doesn't stress it very much. .
    09-17-2015 04:38 PM
  16. sshafranko's Avatar
    I actually talk on the phone a lot and also text text almost all day long. The pic below shows the history of one contact for yesterday and today.
    Yes i am rooted, running a custom kernel obviously since modding the kernel is necessary to obtain root. I also undervolted all gpu, cpu, bus, etc frequencies..
    Battery life has been a very important thing to me ever since i got and rooted my first smart phone, Droid Charge and i have sort of a list of things i do to every phone to help with that. Anyway the point i was trying to make is that the potential for Note 3ish battery life is totally there on the Note 5 with a bit of tweaking, and coupled with fast charging im very happy with my N5.
    laestrella likes this.
    09-17-2015 04:55 PM
  17. Davenurse's Avatar
    This is what I've got so far today, am so happy with battery life. I used package disabler and it made a significant instant effect.
    09-17-2015 05:32 PM
  18. drone3's Avatar
    Battery life has been a very important thing to me ever since i got and rooted my first smart phone, Droid Charge and i have sort of a list of things i do to every phone to help with that. Anyway the point i was trying to make is that the potential for Note 3ish battery life is totally there on the Note 5 with a bit of tweaking, and coupled with fast charging im very happy with my N5.https://images.tapatalk-cdn.com/15/09...9081944cb8.jpg
    Do you have a guide for all your tweaks and custom kernel setup? Would really like to understand how to make the most of this awesome hardware.
    09-17-2015 05:38 PM
  19. sshafranko's Avatar
    Actually ill write up exactly what i do in a couple hrs when i get home. Im at my sons football game. But remember evem if you do exactly what i did your battery life may not be the same because there are so many things to factor in for example the types of apps you use, gps Bluetooth on/off, using wifi calling drains a lot of battery, bad signal strength and so on. Ill post later what i do and what i have and hopefully it helps someone.
    09-17-2015 05:49 PM
  20. Nathan Innocent's Avatar
    Help me fix the Cell Standby. It improved today but I would like it a bit less
    09-17-2015 06:33 PM
  21. jdhooghe's Avatar
    I'm guessing the cell standby is because my signal isn't too great. Standby time has improved greatly from taking care of wakelocks
    Does anyone know what in the world TouchWiz is doing?
    Sent from my smexy T-Mobile Note 5
    09-17-2015 08:31 PM
  22. jdhooghe's Avatar
    What is your cell signal like?
    09-17-2015 08:33 PM
  23. alex217c's Avatar
    Im getting higher cell standby and android system usage all of the sudden. I don't know if its from the last update but I haven't changed any setting.
    at 60% battery remaining with android system using 16%, cell standby 7% and screen 4% with on time of 2h30m.
    09-18-2015 11:56 AM
  24. erasat's Avatar
    I'm in a Business trip in Buckhead, Atlanta since yesterday. Just to let you know the importance of a good signal strength, with basically the same usage as always, and I can say that even more of a power usage as I've been strictly using Cell and no wifi, but with a great signal strength here from T-mobile, I unplugged it by 7:30am, I've been using it almost non stop using Evernote and SNote to take all my notes, using GPS walking on the streets and looking for places and using Whatsapp, Hangouts and SMS a lot, I averaged about 7.75-8 hours of SoT until now that I just plugged it back to do a full fast charge before heading back to the Airport.
    One thing though. I'm part of the Samsung Pay beta program but I haven't been able to add my cards yet, so the app was installed and running but without a way of using it, I noticed since I installed it that the Standby time took a dive and my Android system went up a lot, I decided to uninstall it until I can really use it and everything went back to normal, I hope that with yesterday's update this may have been fixed.
    Note 5 Battery life thread-screenshot_2015-09-18-14-09-47.jpg Note 5 Battery life thread-screenshot_2015-09-18-14-09-55.png
    09-18-2015 01:25 PM
  25. Kelly Kearns's Avatar
    Anybody else see the problem with this? This has been my battery life for the past several days and it's really pissing me off. Any ideas anyone?Attachment 196648
    This was from a couple of days ago
    Remove that battery optimizer and see if that helps the Android System go down. Of not, there is something else running up your Android System.
    Do not run any battery savers, battery optimizers, task killers, etc. You will create more problems.
    09-18-2015 02:33 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
