04-25-2017 07:16 AM
3,351 ... 6869707172 ...
tools
  1. calicocat2010's Avatar
    Well after un-installing CM Security , I charged the phone and then put it on airplane mode last night. I'm doing this because the night before I woke up to a noise outside and looked at my phone, it had went from 100% after 12 am to 90% by 5 am. So last night put it in airplane mode and lost 2 % over night. Right now it is at 78% with light usage. So, I don't know what else was draining while on cell standby, but I had to charge it after 4pm that afternoon.
    10-04-2015 02:17 PM
  2. tfou79's Avatar
    Do you have Verizon by any chance and do you have WiFi on during sleep?
    I have the AT&T model and the Wi-Fi is on
    10-04-2015 02:25 PM
  3. Kelly Kearns's Avatar
    Verizon has a call standby issue when on WiFi.
    I keep my WiFi on but set it sleep when the screen is off.
    10-04-2015 02:29 PM
  4. yi7682's Avatar
    I figured out. It's the app called "Ifeng News." I uninstalled it and the battery life now is 1day8hours. I assume your problem is caused by another app because this app is a Chinese news app. But I'm sure it is some certain app causing the headache.
    Just try install apps one by one. After installing one app, reset GSam, wait for 5 minutes, then if mediasever is not draining your battery, install next app. I know it is painful and time-consuming, but it's totally worth it.
    10-04-2015 03:42 PM
  5. TheMatrix31's Avatar
    Haven't been getting as great battery life in the last couple days. Not quite sure why. I'm at 74% after unplugging 4 hours and 40 minutes ago. Been at home and on wifi all day only really texting. Compare it to driving from home to work for 40 minutes and using Spotify on the drive, 4 hours and 40 minutes into my time at work I'm usually at about 80-85% left. GSam is reading me at around 5.7% per hour when again, I've been around 3% to 4% per hour thus far under my regular use and expectations.
    Signal is fine and I haven't changed any settings.
    Google Play Services is now showing up in the list of stuff on the main battery page in the options and that usually doesn't happen. How could I tell what specifically within Google Play is doing this? Because I presume that's it. Apps haven't been updating either because I don't see an icon with apps recently updated or any active downloading.
    10-04-2015 06:10 PM
  6. KruseLudsMobile's Avatar
    Sounds good..try draining it all the way to 0%?
    No that will shorten the battery life
    Sent from my SM-N920V using Tapatalk
    10-04-2015 06:20 PM
  7. Gray Area's Avatar
    Note 5 active has a 4100 mAh battery! I'm jealous!
    Droid Life: Rumor: Samsung to Launch Galaxy Note 5 Active on AT&T in November. http://google.com/newsstand/s/CBIwpsCEsyY
    Posted via the modest yet efficient Lenovo Tab 2 A8 50
    DEVICE HISTORY (since they got smart)
    PHONES: Galaxy Nexus, LG viper, Galaxy s3, HTC Evo 4g, Galaxy Note 2, Galaxy s5, LG G-Flex, Galaxy Mega 6.3, Galaxy s6 edge, Galaxy Note 5. TABLETS: Galaxy Note 10.1 gt-n8013, Galaxy tab 3 7.0. Lenovo tab2 A8 50 WATCH: Galaxy gear
    smooth4lyfe likes this.
    10-04-2015 06:37 PM
  8. smooth4lyfe's Avatar
    I want to make you aware that CERTAIN THEMES DRAIN BATTERY FASTER THAN OTHERS...this I have notices
    I'm not sure if its because of the colors or effects some of the themes, use, but the "heavier" themes will drain battery quicker than "lighter" ones
    10-04-2015 09:29 PM
  9. smooth4lyfe's Avatar
    My current battery stats!
    Sent from my Galaxy Note 5!
    10-04-2015 09:30 PM
  10. MedicD's Avatar
    So which darker themes are safe?
    10-04-2015 09:37 PM
  11. smooth4lyfe's Avatar
    The ones by developer "dlto" and "MINDON" have good ones that don't drain battery
    mari dub and MedicD like this.
    10-04-2015 09:42 PM
  12. kj11's Avatar
    No complaints at all about the battery on this thing. Now I'll throw it on the charger and be back to 100% in about an hour...
    Attached Thumbnails Note 5 Battery life thread-1444017414263.jpg   Note 5 Battery life thread-1444017423917.jpg
    smooth4lyfe and Gray Area like this.
    10-04-2015 10:58 PM
  13. TripleOne's Avatar
    Is my battery life normal? Or is my battery life terrible?
    It feels like I'm losing a lot juice pretty fast. Or is it because I'm a heavy user and doesn't realize that =P
    10-05-2015 02:51 AM
  14. Gray Area's Avatar
    Your overall battery life is low because you seem to have the phone on immediately after charging lol. You are definitely a heavy user my friend! Lol but 4.5hrs sot isn't bad, it's not great but definitely not bad.
    TripleOne likes this.
    10-05-2015 09:28 AM
  15. James Rogers2's Avatar
    My standby time is horrible. I went from 50% to 15% in 6 hours. I'm on Verizon and didn't have wifi on and getting a pretty good signal. I do have google now on but it still shouldn't drain that fast.
    Sent from my iPhone using Tapatalk
    10-05-2015 09:49 AM
  16. TripleOne's Avatar
    Oh pheww, looks like i'll be needing a wireless battery pack hahaha.
    Thank you
    10-05-2015 10:13 AM
  17. James Rogers2's Avatar
    I'm getting horrible standby time. Any suggestions to help.
    Attached Thumbnails Note 5 Battery life thread-uploadfromtaptalk1444070163743.jpg   Note 5 Battery life thread-uploadfromtaptalk1444070173101.jpg
    10-05-2015 01:37 PM
  18. MedicD's Avatar
    Verizon? Turn off wifi. I'm surprised your email is using so much power
    vm81 likes this.
    10-05-2015 06:05 PM
  19. reidcc's Avatar
    So I was sick and slept most of weekend, but 5 16 hr days is amazing.
    10-05-2015 06:41 PM
  20. vm81's Avatar
    If you use Gmail app and it is using too much battery...my guess is that u r also using that app for another email provider like Hotmail, yahoo or something. Take that off and it should get much better. Gmail app works great with Gmail.
    10-05-2015 07:34 PM
  21. James Rogers2's Avatar
    Using Gmail just for gmail. I'm using the stock email for others.
    10-05-2015 08:01 PM
  22. James Rogers2's Avatar
    Could certain themes use more battery? I can't seem to get more than 3 hours screen on time.
    10-05-2015 08:10 PM
  23. Ruben Ocasio's Avatar
    So far at 35% lol
    Running On Samsung Galaxy Note 5 N920A
    10-05-2015 08:25 PM
  24. spasell's Avatar
    This
    10-06-2015 05:36 AM
  25. spasell's Avatar
    Why the hell does Facebook use so much battery when I only spend a total of MAYBE 30-40 min Inca day looming at that app?
    Don't have their messenger app installed so it's not that.
    Shutapp won't shut it
    Makes no sense to me. No location for it. No notifications active. No sync active.
    10-06-2015 05:38 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
