04-25-2017 07:16 AM
3,351 ... 6970717273 ...
tools
  1. spasell's Avatar
    Your overall battery life is low because you seem to have the phone on immediately after charging lol. You are definitely a heavy user my friend! Lol but 4.5hrs sot isn't bad, it's not great but definitely not bad.
    Posted via the modest yet efficient Lenovo Tab 2 A8 50
    DEVICE HISTORY (since they got smart)
    PHONES: Galaxy Nexus, LG viper, Galaxy s3, HTC Evo 4g, Galaxy Note 2, Galaxy s5, LG G-Flex, Galaxy Mega 6.3, Galaxy s6 edge, Galaxy Note 5. TABLETS: Galaxy Note 10.1 gt-n8013, Galaxy tab 3 7.0. Lenovo tab2 A8 50 WATCH: Galaxy gear
    If you actually use your phone as a phone not a gaming toy or a battery testing device you're fine. I spend 60-90 min talking on my phone as well as email text and reading articles. I get 4 hours SOT and total battery of 13-15 hours. I don't think that is bad.
    10-06-2015 05:47 AM
  2. spasell's Avatar
    Could certain themes use more battery? I can't seem to get more than 3 hours screen on time.
    Sent from my SM-N920V using Tapatalk
    Can't see how that would be the case. Live Wallpapers I get. Themes? If it does can't be enough to make a noticeable difference.
    10-06-2015 05:51 AM
  3. kj11's Avatar
    Why the hell does Facebook use so much battery when I only spend a total of MAYBE 30-40 min Inca day looming at that app?
    Don't have their messenger app installed so it's not that.
    Shutapp won't shut it
    Makes no sense to me. No location for it. No notifications active. No sync active.
    I'd like to know this as well... Instagram does the same thing
    10-06-2015 06:03 AM
  4. reidcc's Avatar
    I deleted Facebook App, and set up a Chrome link to facebook.com on my main screen. It gives me what I want for what limited use of facebook I do. Granted Chrome can be a hog- but nowhere near as bad as the FB App itself!
    Chris
    10-06-2015 06:06 AM
  5. Kelly Kearns's Avatar
    Not sure why yours is doing that, mine isn't.
    10-06-2015 08:14 AM
  6. Kelly Kearns's Avatar
    Instagram is known to do that.
    Do you have Verizon also?
    10-06-2015 08:15 AM
  7. Kelly Kearns's Avatar
    Both of you try disabling these two in Package Disabler (if you don't have that you might can disable them on the application manager) and see if that helps.
    10-06-2015 08:17 AM
  8. calicocat2010's Avatar
    YES! Someone, a male, posted that a few days ago. He listed Which themes are safe. Let me see if I can find that thread.
    smooth4lyfe likes this.
    10-06-2015 08:56 AM
  9. spasell's Avatar
    Will that crippled Facebook at all?
    10-06-2015 10:29 AM
  10. spasell's Avatar
    Never mind. It's not even listed using package Disabler pro. Not sure why unless Verizon has a different variation of Facebook.
    10-06-2015 10:32 AM
  11. Kelly Kearns's Avatar
    No it won't cripple Facebook, I have them disabled.
    I'm not sure why it isn't there. That comes with all versions.
    10-06-2015 10:33 AM
  12. Katrina White1's Avatar
    At&t Note5
    10-06-2015 10:44 AM
  13. Ruben Ocasio's Avatar
    I have never noticed any eating battery from a theme i have tested a few and it doesn't eat battery.
    Running On Samsung Galaxy Note 5 N920A
    10-06-2015 11:45 AM
  14. kj11's Avatar
    Yes, I do
    10-06-2015 12:58 PM
  15. KiwiCoalBattery's Avatar
    I have 3 Verizon Note 5 phones.($269 each, thanks to the $400 off promotion)
    I keep one as a wifi-only device(no SIM card inside the phone). That one has the best battery life(obviously) and can last over 7 days with wifi in the "always on" mode with daily usage of about 30 minutes.
    I assume most people keep their smartphones for at least 1 year.
    It will be interesting to see what the Note 5 battery life is like after the non-removable is 1 year old.
    Even in best case scenario, I predict the battery will have 80% of life left.
    What I really like to know is how much Samsung charges to replaced the internal battery of the Note 5.
    10-06-2015 01:54 PM
  16. calicocat2010's Avatar
    At&t Note5
    YES, Thank You. I KNEW I had seen something like that, but couldn't find which thread it was posted.
    10-06-2015 02:08 PM
  17. Karan Jagdev's Avatar
    10-06-2015 02:47 PM
  18. mavelos sule's Avatar
    Hope it continues after about 6 months to a year.
    I can't wait to hear him complain.
    Sent from my GT-I9505 using Tapatalk
    10-06-2015 06:11 PM
  19. Ruben Ocasio's Avatar
    Battery will last a long time if you do not over charge, that is what happens i seen it happen on removable battery where they over charge it or charge it when it's at 80, 90 etc etc then battery gets swollen and gets damaged i seen it before on removable battery and this happens cause they over charge the phone or keep it plugged all day at there house and that's a bad thing to do.
    10-06-2015 06:16 PM
  20. Karan Jagdev's Avatar
    I have a quick question for you guys. I used package disabler pro and disabled bloatware and then reenabled some of the things I needed like Facebook and Instagram and such. But for some reason, any notification that's supposed to say "saved to gallery" shows up as some weird com.sec.android.app.smartclipservice or something like that on the lock screen only. Inside the notification shade it's fine.
    Anybody know how to fix it?
    I tried enabling everything and rebooting but the problem is still there now. It bothers my ocd.
    Beagles329 likes this.
    10-06-2015 06:29 PM
  21. Ruben Ocasio's Avatar
    Pictures are broken, wanna try uploading again, also did you try enabling everything back to see if it still does it?
    10-06-2015 06:42 PM
  22. Karan Jagdev's Avatar
    They show up fine on both my phone and computer so I'm not sure why they're broken for you.
    But yes I did enable everything and rebooted the phone and the problem is still there. It won't go away.
    10-06-2015 06:49 PM
  23. Ruben Ocasio's Avatar
    Stupid Tapatalk lol now i see the pictures lol
    Anyways did you try wipe cach in recovery try that then reboot.
    10-06-2015 06:51 PM
  24. Karan Jagdev's Avatar
    Yup I tried it and still no change. Not sure what to do at this point. Don't want to have to factory reset this whole thing.
    10-06-2015 07:38 PM
  25. Kelly Kearns's Avatar
    You have content hidden on your lockscreen.
    10-06-2015 08:22 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
