04-25-2017 07:16 AM
3,351 ... 7071727374 ...
tools
  1. Karan Jagdev's Avatar
    You have content hidden on your lockscreen.
    That's true but I've had that enabled since the first day. Hidden content just hides what the image is but it doesn't alter the title of the notification.
    For example, Facebook notifications will still say Facebook, not com.facebook.katana
    And this problem only started after disabling bloatware and now I can't fix it no matter what.
    10-06-2015 08:24 PM
  2. Kelly Kearns's Avatar
    Go to lock screen and security, then notifications and these are the options under notifications on lock screen.
    10-06-2015 08:26 PM
  3. Karan Jagdev's Avatar
    Yeah I know what you mean. But what I was saying was that before Package Disabler Pro, I used to have the notification content hidden, and it wasn't showing "com.sec....blah blah" until last week. It used to just say "Saved in Gallery" or whatever.
    So Package Disabler did something that's causing it. But I can't undo it. I like having my notifications private.
    If there's no way to fix it, I guess I'll live with it. *sigh*
    I guess it's a small price to pay for 10 hours of screen-on time.
    10-06-2015 08:44 PM
  4. Kelly Kearns's Avatar
    And these 3 are enabled?
    10-06-2015 08:47 PM
  5. Kelly Kearns's Avatar
    What are you saving that picture from and how?
    10-06-2015 08:51 PM
  6. Karan Jagdev's Avatar
    Just checked. And yes those 3 things are all enabled. Also, the notification is from me using Smart Select with the S Pen, and saving the selection to Gallery.
    10-06-2015 08:56 PM
  7. Kelly Kearns's Avatar
    Ok.. Let me try something.
    10-06-2015 09:03 PM
  8. Kelly Kearns's Avatar
    Does the same thing if I turn on hidden notification. I don't know if that was the case before because I don't show notifications on the lock screen.
    10-06-2015 09:10 PM
  9. calicocat2010's Avatar
    I WAS GETTING that error too BUT when I was trying to use the app PushBullet to transfer an image to my Surface PRO 3. I had to go into Control Panel and had to set the default program to Windows Viewer because it was saving my image as a FILE, no png, no jpg, nothing. Afterwards, it saved fine after labeling it "image.png"
    10-07-2015 01:06 AM
  10. crf450r420's Avatar
    Won't even last if I use Ultra Power Save mode and try to entrain myself. This sucks.
    10-07-2015 08:27 AM
  11. kj11's Avatar
    Were you on Facebook for the entire hour and 2 minutes?
    10-07-2015 08:35 AM
  12. Ruben Ocasio's Avatar
    👍👍👍🔋🔋🔋Awesome so far.
    Running On Samsung Galaxy Note 5 N920A
    10-07-2015 08:51 AM
  13. Note5User's Avatar
    Can you try using in Wifi and post your statistics. Note 5 performs well on 4G but sucks over wifi.
    vm81 likes this.
    10-07-2015 09:08 AM
  14. Ruben Ocasio's Avatar
    Who me ?
    10-07-2015 09:09 AM
  15. Karan Jagdev's Avatar
    My battery life varies but it's mostly a lot better than it used to be. On wifi all day i got 10 hours of screen. And using the phone at work and home and at the gym one day, I still got about 7 hours before it died.
    Note 5 Battery life thread-uploadfromtaptalk1444227659439.jpgNote 5 Battery life thread-uploadfromtaptalk1444227675849.jpg
    10-07-2015 09:21 AM
  16. Glock23-G4's Avatar
ID:	200288Click image for larger version.
    My best so far was 9hrs 08min with 18% battery left... but it was bedtime lol
    10-07-2015 10:03 AM
  17. Note5User's Avatar
    Who me ?
    Yes. My Note 5 sucks over wifi
    10-07-2015 11:03 AM
  18. Ruben Ocasio's Avatar
    Oh ok will have to do another day for wifi , but i can tell you tho on my wifi i do get more from 4G LTE.
    10-07-2015 11:07 AM
  19. Ruben Ocasio's Avatar
    Oh and when I'm home wifi is always on i never put it to sleep and have got close to 2 days and sot around 7 hrs or so not a heavy user but use my phone a lot for calls text and when in room browse in web and YouTube.
    10-07-2015 11:13 AM
  20. Ruben Ocasio's Avatar
    This was few days back on wifi
    10-07-2015 11:21 AM
  21. Marc Barbieri's Avatar
    I was having issues on my home WIFI too. I went into my router settings and set it to use Wireless N only and 2.4ghz only. Now the problems are gone and my battery life is way better. Hopefully Samsung will fix the WIFI issues with an update because my Note 4 never had this issue on the same network without changing the settings.
    10-07-2015 02:24 PM
  22. spasell's Avatar
    I like package disabler BUT now I can't print anything from my phone. And I have zero idea what was deactivated cuasing it to not work.
    10-07-2015 02:28 PM
  23. Kelly Kearns's Avatar
    I would check the print spool and there is another print process also.
    10-07-2015 02:37 PM
  24. Kelly Kearns's Avatar
    These two
    10-07-2015 02:39 PM
  25. Gray Area's Avatar
    So I was sick and slept most of weekend, but 5 16 hr days is amazing.
    That is awesome
    Posted via the modest yet efficient Lenovo Tab 2 A8 50f
    DEVICE HISTORY (since they got smart)
    PHONES: Galaxy Nexus, LG viper, Galaxy s3, HTC Evo 4g, Galaxy Note 2, Galaxy s5, LG G-Flex, Galaxy Mega 6.3, Galaxy s6 edge, Galaxy Note 5. TABLETS: Galaxy Note 10.1 gt-n8013, Galaxy tab 3 7.0. Lenovo tab2 A8 50 WATCH: Galaxy gear
    10-07-2015 03:16 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
