04-25-2017 07:16 AM
3,351 ... 7273747576 ...
tools
  1. Sapient's Avatar
    If you was fast charging yes thats pretty much accurate
    Running On Samsung Galaxy Note 5 N920A
    I thought fast charging slowed down above 50%. Anyway, I don't know how I lived without it. It's amazing.
    10-09-2015 11:49 AM
  2. Ruben Ocasio's Avatar
    Nope on the Note 5 is really fast i was at 3 % and like in 45 mins i was around 90% something like that , it's way faster in charging than the Note 4.
    10-09-2015 11:51 AM
  3. spasell's Avatar
    I am on Verizon. I have Advance Calling on which I thought allows data while on a call but I guess not? So that being said is it a battery killer and not needed? Not sure what the benefits of it would be if not.
    10-09-2015 12:49 PM
  4. Ruben Ocasio's Avatar
    Where's that option at I'm on AT&T unless your talking about the 4G LTE in Mobile Data.
    10-09-2015 12:53 PM
  5. Muhammad Tayyab Iftikhar's Avatar
    My Samsung Note 5 - Duos (SM - N920C). Bought it last week, initial 2 charge went beyond 30+ hours. Now for the most recent 2 charge, battery is draining like hell. First it went down 50% in 4 hours, now it's 15% down in 1.5 hours.
    Can somebody tell me if it's normal, as someone mentioned initially the battery drains fast.
    10-09-2015 01:01 PM
  6. dmlv's Avatar
    I just moved up to the Note 5 from the s6. I couldn't take that battery life. By 2pm needed charging and then again early evening.
    With the Note 5 I'm making it all day same use...by 9 pm at worse I'm at 10/15%.
    Btw, neither rooted or altered from stock.
    10-09-2015 01:03 PM
  7. Ruben Ocasio's Avatar
    Thats not normal check few post back to see if you need to turn stuff off.
    10-09-2015 01:05 PM
  8. Muhammad Tayyab Iftikhar's Avatar
    Thanks for the prompt response.
    Ruben Ocasio likes this.
    10-09-2015 01:08 PM
  9. Ruben Ocasio's Avatar
    Basically you should post pictures of screen time and battery life screen shots that way we can probably get a better idea what might be killing your battery.
    10-09-2015 01:10 PM
  10. Muhammad Tayyab Iftikhar's Avatar
    Here is the battery usage details for my note 5. The android is taking the most battery. Do I need to delete some of app from Android?
    Attached Thumbnails Note 5 Battery life thread-1263.jpg   Note 5 Battery life thread-1262.jpg
    10-09-2015 01:17 PM
  11. Ruben Ocasio's Avatar
    Go here read this: http://forums.androidcentral.com/sam...y-s6-edge.html
    Thats S6 But basically the samething for Note 5!
    10-09-2015 01:30 PM
  12. Ruben Ocasio's Avatar
    Go here this is for Note 5 to save battery life: Battery life tips/tweaks to stop battery dra… | AT&T Samsung Galaxy Note5 | XDA Forums
    10-09-2015 01:37 PM
  13. spasell's Avatar
    Not sure. Just says Advanced Calling. Then when I select it I get the following
    10-09-2015 03:08 PM
  14. Kelly Kearns's Avatar
    AT&T is VoLTE I believe.
    10-09-2015 04:00 PM
  15. Ruben Ocasio's Avatar
    Let us know if your issue got resolve with those tweak link i sent you mate.
    10-10-2015 07:54 AM
  16. Sammuel1973's Avatar
    Well the reason I ask is I experienced it within hours of the update. Also my Android System and Android OS started showing up high on the list and it was using about 10% battery per hour and even losing a lot while in standby.
    I had TMO send me a new phone, got it last night. It was fine, I did the third upgrade and it seemed to get a bit bad again. I sent my original phone with to Samsung today and am using the replacement right now.
    Two phones have done that after that last update, I think it is the update.
    This is how bad it got and I was having a hard time making it through the day much less charging every other day. See how high my Android System and Android OS are? They never even popped up close to my screen, which is always in the #1 spot.
    TMO will make you reset it before replacing it. You can do what I did, call TMO for a replacement, call Samsung to send yours in when you order the replacement. When you get the new one, send yours to Samsung that day or the next. When yours comes back, send back the replacement to TMO. They want you to return a phone to them in 7 days if you get a replacement. They don't care which one you return. If it is over 7 days they will bug you a few times with a text, but you will have your phone back by 10 days or less and can drop off the package going back to TMO and still be good.
    I think the OS needs to be pulled off and put back on, which is necessary if there is an issue like this with an update, a reset won't fix if there is an issue. If Samsung finds an issue in TMO's software, they will get with TMO and get it fixed.
    I am reconsidering the Note 5 again cuz of Samsung Pay, but has the update really affected the battery life? If the issue is cuz of the updates (which includes Samsung Pay), how could getting a phone replacement help? Has it in your case? I also have TMobile.
    10-10-2015 10:08 AM
  17. Kelly Kearns's Avatar
    No idea yet. One way it will help is people that had the issue after the update, to contact Samsung. BUT.. the replacement I'm using right now has settled down and is seeming to be more normal. If that continues, it could mean I had a corrupted download.
    Mine is at Samsung right now, they will remove the OS and put it back on and that will correct the issue if it was a corrupted update. They will also run it a day or two and check everything to see if there is an issue. If it is a Samsung Pay issue, they should find that. If it is a T-Mobile update, they should find that.
    Sammuel1973 likes this.
    10-10-2015 10:21 AM
  18. Kelly Kearns's Avatar
    Forgot the screen shot, no high Android System right now.
    10-10-2015 10:23 AM
  19. Ruben Ocasio's Avatar
    That is weird you had those issues I'm on AT&T Note 5 and as you see never get android system showing basically it's way to the bottom.
    10-10-2015 10:30 AM
  20. Kelly Kearns's Avatar
    Just started hours after the update the night before Samsung Pay went live.
    10-10-2015 10:59 AM
  21. Kelly Kearns's Avatar
    This is when I decided to do something about it. If it hadn't started draining battery, then I wouldn't have worried about it.
    10-10-2015 11:31 AM
  22. Ruben Ocasio's Avatar
    Wow never seen anything on my Note 5 AT&T those 2 are always at the last bottom or sometimes it doesn't even show.
    10-10-2015 11:43 AM
  23. Kelly Kearns's Avatar
    Exactly, mine never show up. It caused me to go from charging every 24 to 36 hours to two and three times a day. It just got worse by the day.
    I upgraded at home and I have been having issues with my WiFi going down for a few seconds at a time. It is possible that happened and my download was corrupted and made my update corrupted. If that happens, no amount of reseting or reflashing will help. You have to remove the entire OS and put it back on and only the Samsung service center can do that.
    10-10-2015 11:48 AM
  24. Ruben Ocasio's Avatar
    Wow sorry your having those issues, damn thst really sucks.
    10-10-2015 11:50 AM
  25. Ruben Ocasio's Avatar
    Here's all apps android os to bottom
    10-10-2015 12:04 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
