04-25-2017 07:16 AM
3,351 ... 7778798081 ...
tools
  1. Kelly Kearns's Avatar
    Did you get your returned original Note 5 yet from Samsung? If so, did they say what the battery problem was?
    Yes got it back. There was an issue with the update and it was also causing my battery to read full when it wasn't full. They took off the OS and put it back on, they went ahead and replaced the battery and they replaced the SIM drawer for some reason.
    Sammuel1973 likes this.
    10-21-2015 05:21 PM
  2. spasell's Avatar
    Does anyone know what the circled app or process does that I see when opening package disabler? It's in pink which I think is bloatware but then again others were in pink that I unchecked since I want them.
    Thoughts?
    Anyone know answer to this?
    10-21-2015 05:52 PM
  3. Xxwabbit's Avatar
    Wife has this phone and her battery life is better than my maxx. Sorry don't have any numbers right now other than she went more than 2 days on full charge and she couldn't care less about battery life.
    10-22-2015 06:58 PM
  4. anon(9228075)'s Avatar
    Is this normal? See attached pic
    24% of my battery use is cell Standby...
    10-23-2015 12:04 AM
  5. doctordwaynewilliams's Avatar
    Does anyone use power save mode? I do most of the day and it really helps me. Plus, my brightness is usually turned way down because the screen is so bright. I only turn the brightness on when I'm outside in the sun.
    Note in my house!
    10-23-2015 07:20 AM
  6. Ruben Ocasio's Avatar
    Note in my house!
    I never use it lol.
    10-23-2015 07:26 AM
  7. doctordwaynewilliams's Avatar
    I never use it lol.
    I'm suspected that a lot of users aren't using it. If they are having battery issues, then maybe they should.
    Note in my house!
    10-23-2015 07:28 AM
  8. recDNA's Avatar
    Of course phone does sync and phone calls, lots of texting, web browsing, and i use Tapatalk a lot and Google Plus, those are my main things i use a lot , no game playing don't like to play games.
    Running On Samsung Galaxy Note 5 N920A
    I meant in the picture showing battery life only screen is shown. If nothing else is shown nothing else is used
    10-23-2015 07:42 AM
  9. recDNA's Avatar
    Note in my house!
    Yes it turns a super fast smart phone into a slow phone that only syncs with screen on. perfect
    10-23-2015 07:44 AM
  10. Ruben Ocasio's Avatar
    Oh yeah when i took the picture it was to the top if i scrolled a bit down then the rest would show so basically was cut off
    10-23-2015 07:47 AM
  11. Ruben Ocasio's Avatar
    See just now i scrolled a bit down , there's more if scroll down more.
    10-23-2015 07:49 AM
  12. kj11's Avatar
    https://images.tapatalk-cdn.com/15/10...7f2930f3a6.jpg
    Scroll capture might be my favorite feature.... Just saying...
    crf450r420 and jdhooghe like this.
    10-23-2015 08:56 AM
  13. kj11's Avatar
    Note in my house!
    I do not. Never had the need, but I imagine some day if I'm stranded on a deserted island it could come in handy.
    10-23-2015 08:57 AM
  14. crf450r420's Avatar
    So the first app I've found to drain a lot of my battery even when I don't use it all day is Tapatalk. Went from a 36 to 38 hour battery to a 24 hour battery without opening the app. So yesterday I disabled and battery was good again. Activated it today and it is draining again. I'm going to try and set alarms with Tasker for every 10 percent battery so I can screen capture both ways at the same points.
    10-23-2015 01:00 PM
  15. Ruben Ocasio's Avatar
    I use Tapatalk and it never drains my battery at all, what version Tapatalk you using cause latest Tapatalk is v5.2.10 link: https://www.apkmirror.com/apk/tapata...-apk-download/
    10-23-2015 01:04 PM
  16. crf450r420's Avatar
    Again, when not using. Didn't even open the app. I'm using the latest from play store like most people do.
    10-23-2015 01:27 PM
  17. Ruben Ocasio's Avatar
    AT&T Note 5 i use gplus all day and Tapatalk plus web browsing and do lots of texting few phone calls and watch YouTube off and on and i get 1 day 12 hrs of battery life, plus sot for over a day 5hrs, if i was to use my phone lets say 15 hrs i get at least sot 7hrs and half.
    10-23-2015 01:35 PM
  18. Ruben Ocasio's Avatar
    Here's proof
    Now that sot 3hrs and 40min or so at 15% when i reach at 2 or 3% my sot will be at least over 5 hrs.
    10-23-2015 01:40 PM
  19. drmcn1nja's Avatar
    Getting terrible battery life on my 5 day old Note 5 - not sure if it is a defect or something else . This morning it drained about 20% in 3.5 hours with only 40 min of screen on time. Mostly on wifi at work, advanced calling enabled, running package disabler pro with xml package from the xda developers thread (i can't post links)
    Tried master reset and cache wipe from bootloader. Doesn't seem to be helping. Thinking about exchanging the phone at BB to see if is a defect - looking at my usage numbers, there's no way I could get a day of use like some of you are reporting. i'm barely picking up the phone - if i use it for anything I can watch the percentage drop as I'm using it.
    Note 5 Battery life thread-battery-2.jpgNote 5 Battery life thread-battery.jpg
    10-23-2015 02:27 PM
  20. badkitties's Avatar
    how does one do scroll capture? I forgot....
    10-23-2015 02:50 PM
  21. kj11's Avatar
    SPen, screen write, the scroll capture button shows up in the bottom left
    10-23-2015 04:38 PM
  22. crf450r420's Avatar
ID:	202792Click image for larger version.
    Try it in safe mode for one day first. I'm finding apps are draining the battery without showing up as a power user. Mine was worse than yours and in safe mode it used a 1/6 the power.
    10-23-2015 07:17 PM
  23. Kelly Kearns's Avatar
    Actually that isn't what power saving does.
    10-24-2015 08:01 AM
  24. Kelly Kearns's Avatar
    The latest what app from the Play Store?
    I have Tapatalk, AC Forums and the Android Central App all three on NY phone and it isn't draining my battery.
    10-24-2015 08:03 AM
  25. Kelly Kearns's Avatar
    Your cell signal is probably your problem, it is almost non-existent.
    jdfry15 likes this.
    10-24-2015 08:05 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
