04-25-2017 07:16 AM
3,351 ... 7980818283 ...
tools
  1. Kelly Kearns's Avatar
    Very true forgot about that lol, but i never use Samsung Pay or any thing for credit on my phone i rather use my plastic card.
    I would use it in a heartbeat if they took my bank. I used to use Google Wallet with tap and pay and loved it.
    10-24-2015 06:58 PM
  2. bettercallsal92's Avatar
    You don't need NFC for Samsung Pay.
    Kelly can you share your settings too? And your stats?
    10-24-2015 06:59 PM
  3. Kelly Kearns's Avatar
    These are the last I have, I posted earlier today. That My T-Mobile app polls location a lot.
    This is what I have disabled.
    Attached Thumbnails Note 5 Battery life thread-1445731724782.jpg   Note 5 Battery life thread-1445731737517.jpg   Note 5 Battery life thread-1445731778207.jpg
    10-24-2015 07:10 PM
  4. crf450r420's Avatar
    The latest what app from the Play Store?
    I have Tapatalk, AC Forums and the Android Central App all three on NY phone and it isn't draining my battery.
    Okay, tried it again today and not the issue. Battery was good the day before I turned it on so I thought it could be it. Then it was good again the next day after disabling it so I thought it had to be it. Was going to double check anyways. Had it on today and battery is great, so something else happened. Now I'm wondering what, but will just move on to the next app.
    10-24-2015 07:53 PM
  5. Kelly Kearns's Avatar
    You should run your phone for 24 hours like normal, also install GSam battery monitor. Then post some screenshots for us after the 24 hours of running it.
    10-24-2015 08:55 PM
  6. xocomaox's Avatar
    Also others please remember, battery life is subjective to carrier, signal, how you use your phone, etc. You can set your phone up exactly the same, doesn't mean you will get the exact same battery life.
    Yes, this is true.
    I haven't done any gaming today on my G3 and my battery life is nearly 6 hours SoT. But this was with mainly WiFi all day and, like I said, no games. Games kill battery more than anything it seems.
    Here's a shot of my G3:
    Kelly Kearns likes this.
    10-24-2015 11:28 PM
  7. Kelly Kearns's Avatar
    Yup, many games will eat battery so much your battery will drop still when your phone is plugged in and playing.
    10-24-2015 11:30 PM
  8. bettercallsal92's Avatar
    My battery life is nothing like this, turning off nfc changed nothing and I get like 30% or higher drain on standby per charge cycle. Right now I'm barely getting 4 hours of SoT and I'm not even using my phone heavily anymore. Should i send my phone in to samsung or something?
    10-25-2015 04:37 PM
  9. kj11's Avatar
    'Nother solid day...
    10-25-2015 07:28 PM
  10. doctordwaynewilliams's Avatar
    I was using the " my places" widget and I found that it was draining my battery. Since removing it, my battery life has been much improved.
    10-25-2015 08:06 PM
  11. badkitties's Avatar
    or playing high bitrate videos. I stupidly encoded all of my Blu-ray collection into 1080p with 640kbps audio. Each video is set to be just under 3999MB, in order to get around the 4GB size limit of FAT32. (mostly because I have several other devices that can only read FAT32 and not exFAT or NTSF) The Note 5 plays it without any issue and the video look great... but I guess it also takes a lot of CPU processing power, so the battery life aint' so great.
    Even worse is playing 1440p YouTube videos. They look bloody marvelous, but again, takes more CPU processing and lower battery life.
    10-25-2015 09:46 PM
  12. Kelly Kearns's Avatar
    Post your screenshots again.
    10-26-2015 02:53 AM
  13. calicocat2010's Avatar
    That's awesome, but sucks at the same time.
    10-26-2015 07:09 AM
  14. bettercallsal92's Avatar
    Note 5 Battery life thread-uploadfromtaptalk1445891809705.jpgNote 5 Battery life thread-uploadfromtaptalk1445891815986.jpgNote 5 Battery life thread-uploadfromtaptalk1445891821529.jpg
    10-26-2015 03:37 PM
  15. Ruben Ocasio's Avatar
    Here is what i got , usually i get 6 to 7 hrs sot with probably 1 day and 8 hrs or so , but still excellent battery life 👍👍🔋🔋
    Lefty724 likes this.
    10-26-2015 03:41 PM
  16. Kelly Kearns's Avatar
ID:	203155Click image for larger version.
ID:	203156Click image for larger version.
    So what SOT are you averaging and how often are you recharging?
    10-26-2015 03:56 PM
  17. bettercallsal92's Avatar
    4 hours on average, and I usually recharge once a day. Usually when it's down to 15-20%, sometimes less if I can't get to a charger
    10-26-2015 04:06 PM
  18. Kelly Kearns's Avatar
    Ok, I'm missing something then. Your battery life is fine.
    10-26-2015 04:20 PM
  19. bettercallsal92's Avatar
    How? You guys get over a day with 6-7 hours of SoT on a single charge
    10-26-2015 04:24 PM
  20. Ruben Ocasio's Avatar
    The reason i got this time 4hrs of SOT there was a wifi issue and network but all got resolve, my average SOT is 6hrs to 7 hrs, considering that i got 1 day and over 15 hrs with SOT 4 hrs is excellent battery life , i charge my phone once a day when it hits 3 to 5 % , And 8hrs 1/2 is on 4G LTE when I'm at work the rest when I'm home Wifi on always.
    10-26-2015 04:32 PM
  21. Kelly Kearns's Avatar
    Not always and you can't compare how your phone does to other phones. People use them different ways. You can browse a few things, use a lot of texting, reply to a lot of emails, etc and it doesn't use a lot of battery and you can get a lot of hours.
    If you are making it through the day, then that is good. Do many factors go into phone use and some things will use more battery than others. Signal through the day am make a difference in battery usage.
    I'm not getting 6-7 hours SOT always, sometimes I get less, sometimes I get more.
    10-26-2015 04:36 PM
  22. bettercallsal92's Avatar
    Thats the thing though, I have NEVER gotten even 5 hours of SoT, no matter how I've used the phone. That's what irks me
    10-26-2015 04:40 PM
  23. Kelly Kearns's Avatar
    But that is OK if the phone is done what you need it to do and meeting reasonable expectations. You could have apps that ping location more or again, in an area much of the day with a lower signal.
    10-26-2015 04:43 PM
  24. recDNA's Avatar
    Actually that isn't what power saving does.
    Well whatever it does it doesn't do it for me. I put my phone on energy saver today and got typical battery use....in fairness I tried it on note 3.
    10-26-2015 06:27 PM
  25. Kelly Kearns's Avatar
    Now today I got a lot of time, but most of my time was hangouts and Android Central. I only did tethering for about 30 minutes.
    Attached Thumbnails Note 5 Battery life thread-1445904387060.jpg   Note 5 Battery life thread-1445904400952.jpg
    1stGalaxyS3 likes this.
    10-26-2015 07:07 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
