04-25-2017 07:16 AM
3,351 ... 8081828384 ...
tools
  1. kj11's Avatar
    Now today I got a lot of time, but most of my time was hangouts and Android Central. I only did tethering for about 30 minutes.
    Wow! Your phone was unplugged for 13 hours and the screen was on for 8.5 of it?! That's something
    10-26-2015 07:17 PM
  2. Kelly Kearns's Avatar
    Yes I generally charge once a day.
    If I'm tethering a lot, I will keep it plugged up. The things I did today just don't use a lot of battery, so I got a lot of screen time today. There are other things I could have done for less time and my batter would have run out faster and less screen time.
    Even screen time is subjective, it just depends on what you are doing.
    10-26-2015 07:31 PM
  3. Allenhardiman's Avatar
    My first tryout on normal school day.. I was off the charger at 7.30 a.m. So satisfied with the battery life!! I didnt expect it to last this long. Coming from an s5, the battery is comparable if not better!! I didnt disable google now as well.
    Attached Thumbnails Note 5 Battery life thread-4799.jpg   Note 5 Battery life thread-4800.jpg
    10-26-2015 09:49 PM
  4. javitolopez's Avatar
    What is Your settings .well screen onda time mate is realy good .
    10-27-2015 04:15 AM
  5. Kelly Kearns's Avatar
    Well my settings for what? There are so many settings, so many different apps people have, etc. That is why I keep saying, battery life is subjective, none of us run our phones the same way.
    10-27-2015 08:48 AM
  6. Ruben Ocasio's Avatar
    Basically what @Kelly Kearns is saying is everyone runs there phone different so you can't expect to get what we are getting , for example yesterday i got pass 1day and 16hrs or so and SOT Was 4hrs and 45min , the day before that i got 1day and 8hrs and my SOT was 6hrs and 14min, last week there was a day that i got 1day and 5hrs and my SOT was 7hrs with 45min, so basically you will not get the same all the time , it all depends what you do on your phone each day!
    10-27-2015 09:07 AM
  7. Bklyndude's Avatar
    Ok here is my question regarding note 5 battery life. I will try to make it as consice as possible.
    Ok so I just upgraded to a note 5 coming off of an lg g2. Both have the the same 3000 mah battery. The first thing i noticed that the note 5 drains immediately when you start using it. The lg didnt. The lg also was able to maintain 100% in standby/idle mode. Meaning i took it iff charger it was on, idle and three hours later it would be 100%. Now before the g2. I had a droid. Also drained when idle, of course only 1% or 2 like this current brand new note 5. I didn't even get to my question yet. My question is..is the note 5 capable of sustaining 100% battery life when idle for a few hours like my 2 year old lg g2. I would have thought samsung would have optimized the os by now. Anyone?
    10-27-2015 09:25 AM
  8. Ruben Ocasio's Avatar
    If your asking after full charge on Note 5 and you unplug it and let it stay standby/idle without turning screen on , it will still be at 100% after 2 hrs and half or so i have seen mines do this, fully charged, leave for work and like 2 hrs and half later i get a text i look at my text and my phone was still at 100%.
    10-27-2015 09:31 AM
  9. Bklyndude's Avatar
    Nope. So far not. Mine is brand spanking new. That is exactly what i was asking. Draining slow. Right away. How do you solve that?
    10-27-2015 10:02 AM
  10. Ruben Ocasio's Avatar
    AT&T Note 5 and i only disable all bloatware crap that i don't use.
    10-27-2015 10:09 AM
  11. Jklein9515's Avatar
    Kelly Kearns, are you on auto brightness? Any power saving modes? Google Now on/off? Location services on?
    10-27-2015 10:12 AM
  12. Bklyndude's Avatar
    Ok. Mine is verizon. I can only compare it to the lg g2 that i previously used. Which i didn't have to tweak much at all. It just was very stable and consistent at maintaining battery idle and slow to drain while using. Maybe i have to cycle the battery a couple of times still in early stages with this phone. 1 day old. Not even. Just going on usage after a few mins.
    10-27-2015 10:12 AM
  13. Bklyndude's Avatar
    Umm location is typically always off. Auto brightess always off. And low display. Google now i believe is on. That's really it
    10-27-2015 10:15 AM
  14. Bklyndude's Avatar
    Ruben stated above that his phone maintains 100% at least for 2 hours being idle and off charger. I already see my phone is not doing that. Maybe 1% drain. I read somewhere its normal. I just wish it held steady at 100. Would feel more confident that its battery that will preform longer
    10-27-2015 10:17 AM
  15. Kelly Kearns's Avatar
    My experience, and it is with Samsung phones, when new or after a reset your battery will settle down and do much better. You disable the things you don't use, have your apps set like you want and all the sudden you notice the battery getting better.
    10-27-2015 10:50 AM
  16. Kelly Kearns's Avatar
    I have auto brightness on, I do have Google Now turned on, but I really don't use it. I have a couple of apps that use location so location stays on all the time. I have some things disabled. This is what I have disabled. I really think when I have so much disabled with package disabler that my battery doesn't do as well, so I have less disabled than some.
    10-27-2015 10:55 AM
  17. Kelly Kearns's Avatar
    Oh just read this.. Yeah, get your phone set up and then give it a few days.
    I also use two apps called ShutApp and Doze and those really help with battery and idle time.
    10-27-2015 10:56 AM
  18. njshoremom4gurlz's Avatar
    Pretty good battery life!
    10-27-2015 02:03 PM
  19. bettercallsal92's Avatar
    I think its unrealistic to expect your phone to hold 100% after 2 1/2 hours, I have never heard of any android phone doing that, dont know what black magic Ruben is using on his battery lol. Even when I sleep at night I get like 3-4% drain over a period of 7-8 hours
    10-27-2015 03:11 PM
  20. Ruben Ocasio's Avatar
    There's no magic it's very true, also when i use to have the LG G3 i would go to work fully charged and would be standby after 8 hrs i would turn on screen and it was still at 100% .
    10-27-2015 03:18 PM
  21. bettercallsal92's Avatar
    Are you running stock? Or custom rom and kernel?
    10-27-2015 03:30 PM
  22. Ruben Ocasio's Avatar
    Here's proof of LG G 3 100% when i was at work after 8 hrs was still 100%
    10-27-2015 03:32 PM
  23. Ruben Ocasio's Avatar
    No I'm on AT&T so as you know i can't root the phone.
    10-27-2015 03:33 PM
  24. Ruben Ocasio's Avatar
    10-27-2015 03:43 PM
  25. bettercallsal92's Avatar
    I never said you were lying, and if I implied that I apologize. And no, I had no idea you couldn't root note 5 on AT&T
    10-27-2015 04:12 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
