04-25-2017 07:16 AM
3,351 ... 8283848586 ...
tools
  1. leggy's Avatar
    That is correct. 8 min on active use. Now almost 30 at 94% my lg g2 would be like 98 still
    You can't compare many phones with lg g2 because the way it reports the battery usage. Mine used to drop from 100 to 99 after 30-35 minutes of internet browsing and once I hit 97% the battery was draining like crazy. The max sot I could get with my lg g2 was 7.5hr with airplane mode enabled for 1-2 (in subway using kindle).
    I personally have edge plus but my wife and sister in law have note 5. The way Samsung reports battery drain is more accurate than the way lg g2 did.
    10-28-2015 11:58 AM
  2. rainyboy7's Avatar
    It's not bad !? After 21 hour on battery, what you think ??
    bassplayrguy likes this.
    10-28-2015 03:38 PM
  3. Ruben Ocasio's Avatar
    Yeah if you did get 21 hours and that's your SOT without charging that is Excellent
    rainyboy7 likes this.
    10-28-2015 03:43 PM
  4. Bklyndude's Avatar
    Good point leggy. Now that i think about it the g2 dod drain fast after that point of 30 min. Esepcially after a year or when i switched phones
    10-28-2015 07:22 PM
  5. Kelly Kearns's Avatar
    Ok today's battery.
    Attached Thumbnails Note 5 Battery life thread-1446078546581.jpg   Note 5 Battery life thread-1446078559092.jpg   Note 5 Battery life thread-1446078569852.jpg
    10-28-2015 07:29 PM
  6. tanson1011's Avatar
    Never had pocket casts drain so much for the couple years I've used it. Just listening to audio pods like everyother day. Been draining the last few days.
    10-28-2015 09:13 PM
  7. MedicD's Avatar
    After months of various changes and attempts to settle my battery, I'm still unable to find the drain. The weird thing is that in safe mode it doesn't drain at all, so it's gotta be some app. Even going one by one with apps, I never was able to figure it out. I'd install one and it'd start the drain, but then removing it didn't fix the drain.
    I'm pretty convinced the culprit is a Google app, and it must be some specific setting I have on it. That or its my Gear S...
    Attached Thumbnails Note 5 Battery life thread-1446085678772.jpg   Note 5 Battery life thread-1446085686881.jpg   Note 5 Battery life thread-1446085693471.jpg   Note 5 Battery life thread-1446085699561.jpg   Note 5 Battery life thread-1446085706371.jpg
    10-28-2015 09:30 PM
  8. rainyboy7's Avatar
    I had G2 just before note 5, the battery on kitkat was extremely excellent. At nights it didn't dropping any battery, but on lollipop battery was so bad, on kit Kat I had 2 days with lots of usage. G2 with android 4.4.2 was the best phone I ever had in battery life concept.
    10-29-2015 01:17 AM
  9. Bklyndude's Avatar
    How do you attain such great battery life?
    10-29-2015 01:28 AM
  10. Bklyndude's Avatar
    How do you add photos,quote someone on app?
    10-29-2015 01:40 AM
  11. Bklyndude's Avatar
    Quotes i figured out. How to post photo?
    10-29-2015 01:41 AM
  12. Bklyndude's Avatar
    Ok. Got it. This doesn't seenlm good compared to others
    10-29-2015 01:42 AM
  13. Bklyndude's Avatar
    What could be wrong?? Location is off. Nfc off. What else already ??
    10-29-2015 01:42 AM
  14. calicocat2010's Avatar
    Depends on who your carrier is with. Lots of users had the dreaded WiFi signal issues, most have said it is the Google Now app that drain the most, Others says Volt LTE...there's a Ton more to list. Best bet is probably install Package Disabler Pro.
    I'm not going to state what it does as I need to go to bed, but I'm sure lots of users will enlighten you on PDP.
    Good luck.
    10-29-2015 02:29 AM
  15. Bklyndude's Avatar
    Thanks - on verizon
    10-29-2015 02:44 AM
  16. rainyboy7's Avatar
    Note 5 Battery life thread-uploadfromtaptalk1446105384447.jpgNote 5 Battery life thread-uploadfromtaptalk1446105390123.jpg
    What about this!!!
    kj11 likes this.
    10-29-2015 02:56 AM
  17. Bklyndude's Avatar
    Why post graphs. Why not just state what you do or don't do to achieve superb battery? Would be greatly appreciated.
    recDNA likes this.
    10-29-2015 02:59 AM
  18. Bklyndude's Avatar
    Ok. Will make it easy for someone to answer. 210 pages. Break it down. What things/services. Options, settings. On my verizon note 5. Should I have enabled. Or disabled to get the most mileage out of my battery. I watched some youtube video's which were useless since the 3 or 4 steps they mentioned I already done. Thanks in advance
    recDNA likes this.
    10-29-2015 03:20 AM
  19. leggy's Avatar
    Couldn't agree more. My screen was broken which made by edge plus, otherwise a very fine phone.
    10-29-2015 03:22 AM
  20. Glock23-G4's Avatar
    I'm not on Verizon, so can't help there...
    And not to be mean, but there are 2 reasons why there are ~2100 posts in this thread.
    1. There's a lot of good information and tips from a lot of different people on how they've improved their battery performance.
    2. There's a lot of people jumping in at the end to ask questions that have been asked and answered many times already.
    There's a lot of good info here... take some time and look through it.
    10-29-2015 08:44 AM
  21. Kelly Kearns's Avatar
    It is impossible for anyone to do that for you. None of us have the same apps or same things disabled. You just have to take some time and read through the thread and work from there.
    10-29-2015 09:23 AM
  22. Bklyndude's Avatar
    Not really. You have people claiming to get 12 hours. What were the main tweaks they did or can recommend that they think someone with less than optimal battery predromance can do. These phones are pretty much identical. I would think. So someone like me with new phone, few apps. Just some basic things i might have missed. Known to the community that can be battery killers.
    10-29-2015 09:28 AM
  23. recDNA's Avatar
    That would be great. One post summarizing the best tips....maybe even make it a sticky. Few of us have the time to read through everything in this thread.
    10-29-2015 09:28 AM
  24. bettercallsal92's Avatar
    I feel like some people are more about showing off than actually helping
    Palladium65, kj11 and bassplayrguy like this.
    10-29-2015 09:49 AM
  25. Bklyndude's Avatar
    Could be. Will check back later.
    10-29-2015 09:50 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
