04-25-2017 07:16 AM
3,351 ... 8586878889 ...
tools
  1. Ruben Ocasio's Avatar
    All you have to do if want to clear cache go into settings and storage, or reboot into recovery and clear cache there i do that once a week, no need for CLEAN MASTER.
    rainyboy7 likes this.
    10-30-2015 04:28 AM
  2. Kelly Kearns's Avatar
    I am so mad that some carriers are using Cheetah Mobile and that Google is allowing them to stay in the Play Store.
    Back a few years ago when Clean Master was developed, Android also didn't handle RAM as well and Clean Master wasn't an evil app.
    Things have changed on both fronts.
    Don't think of Android RAM like Windows RAM. The newer phones and newer Android OS, actually function better on a full RAM.
    Ruben Ocasio and Geezer Squid like this.
    10-30-2015 04:33 AM
  3. Kelly Kearns's Avatar
    This is my free RAM right now, not abnormal and gets lower many times.. 870 mb..
    Ruben Ocasio likes this.
    10-30-2015 04:36 AM
  4. Ruben Ocasio's Avatar
    Yeah that is why AT&T removed it they know exactly what it does.
    10-30-2015 04:38 AM
  5. Kelly Kearns's Avatar
    I think TMO knows also, CM probably paid a pretty penny to get TMO to add it on.
    10-30-2015 04:40 AM
  6. Ruben Ocasio's Avatar
    Here's my ram uses.
    10-30-2015 04:41 AM
  7. Kelly Kearns's Avatar
    With my previous Samsung phones (which have been all my android phones) before my Note 4 and S5 before rooting, I constantly pulled up the task manager and cleared the RAM.
    The "full RAM = happy phone" takes a while to get used to.
    I always have at least 5 apps running in the background. I only close out (most of the time) the ones I open and rarely use.
    10-30-2015 04:46 AM
  8. rainyboy7's Avatar
    Yes agree DON'T EVER USE CLEAN MASTER VERY VERY VERY BAD! had to put that in caps!
    Ok clear you cache, it doesn't matter how you do it. Clean master or every another app or just do it yourself. Android do make junk files, I am not talking about RAM and I don't care about it. There is 4 gb available
    10-30-2015 05:34 AM
  9. rainyboy7's Avatar
    Yessss you can do it and I meant that. There is no problem about RAM management.
    10-30-2015 05:37 AM
  10. Kelly Kearns's Avatar
    Yes it does matter, Clean Master is not good. Listen to the entire video, just one or two problems with CM and Cheetah Mobile.
    Your cache is what uses RAM that your OS and apps aren't using.
    You very rarely need to clear your cache. I never did on my Note 4, haven't done it with my Note 5.
    The ONLY cache clear I ever do, is wiping cache partition after an update.
    Ruben Ocasio and Bklyndude like this.
    10-30-2015 05:42 AM
  11. Kelly Kearns's Avatar
    Don't know anything about the source for this article, but this article is true.
    http://www.makeuseof.com/tag/ram-boo...s-bad-android/
    10-30-2015 05:46 AM
  12. Kelly Kearns's Avatar
    And more and references Phil's podcast about this app.
    http://www.howardforums.com/showthre...roid-Flagships
    10-30-2015 05:50 AM
  13. Kelly Kearns's Avatar
    And I don't do it once a week, your phone rebuilds that cache. I only use wipe cache for updates or problems. Myself, I don't do it for any other reason.
    10-30-2015 05:53 AM
  14. Bklyndude's Avatar
    Good morning
    10-30-2015 06:05 AM
  15. Ruben Ocasio's Avatar
    My second Note 5 only 2 days old
    10-30-2015 08:03 AM
  16. Bklyndude's Avatar
    Second? How many do you nees
    10-30-2015 08:45 AM
  17. Bklyndude's Avatar
    Need
    10-30-2015 08:45 AM
  18. Ruben Ocasio's Avatar
    Need
    Bought it for my daughter, i am working on her battery life.
    10-30-2015 08:47 AM
  19. Ruben Ocasio's Avatar
    Need
    My wife has the SG6 Edge plus, which her battery life is as good as my Note 5.
    10-30-2015 08:50 AM
  20. Bklyndude's Avatar
    Ohhh
    10-30-2015 09:06 AM
  21. Bklyndude's Avatar
    Work on my batter life next
    10-30-2015 09:06 AM
  22. Bklyndude's Avatar
    Battery*
    10-30-2015 09:06 AM
  23. Ruben Ocasio's Avatar
    Awesome for 2 days old on the second Note 5 battery life is pretty awesome.
    10-30-2015 10:01 AM
  24. recDNA's Avatar
    Here's the list, you don't have to do all of this, for example I disabled Samsung voice because it's not useful for me.
    1.Disable GPS, Bluetooth, NFC and turn them on when necessary
    2.Disable Wi-Fi calling
    3.Disable voice over LTE : on phone application go to more, settings. Find Voice over lte settings and set it do not use volte
    4.Disable all motions: settings, motion and gestures, turn all 4 options off
    5.Disable SVOICE and Shealth app
    6.Disable all Google useless services
    7. Use black wallpapers for screen and lock screen
    8.Go to location setting and turn off Google location history
    9.Turn 4g data off when using Wi-Fi or don't need Internet
    10.Turn useless vibrations and sounds off
    11.Go to developer settings and turn all animations off
    12.Go to Wi-Fi settings, more, advanced and turn always allow scanning off
    13. Use auto mode for display light
    14.If you don't using Samsung printer service Disable it, on settings, connection, more connection settings, printing, Samsung print service plug-in
    15.This is just an advice, don't use more than one application for one task, you don't need 2 calculators or 2 pdf readers and so on..
    16. Use clean master every week and Uninstall it after that. Just clean junks with it
    17.Turn backup data and auto sync off
    18.Go to smart manager, ram, manage apps and auto stop apps you don't want to run on background, for example an application like what's app needs to run on background but games or pdf readers don't.
    19. Do not use Google Chrome if you can. The default browser is so good and support fingerprint sign-in which is a nice feature.
    20. Be smart, use do not need Gmail app,yahoo mail app, and ... to manage your emails (this is just an example) you can install an application like k@mail to control all your email accounts with just 1 application , same thing for note taking and ...
    Hope you find this useful, tell me if any of this tips worked for you.
    Thanks for the great summary! This was exactly what many of us were hoping for.
    10-30-2015 10:05 AM
  25. tanson1011's Avatar
    Exactly. That list is absurd. I've done zero things on that list, my battery lasts all day with 4-5 hours of screen on time.
    How many of those things have actually proven to save battery life, and exactly how much?
    4 to 5 hours of screen on time? Lol. So what apps do you use and why are you in this thread. Just to tell people you have great battery life?
    10-30-2015 10:23 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
