04-25-2017 07:16 AM
3,351 ... 8788899091 ...
tools
  1. Kelly Kearns's Avatar
    And so people understand that many things affect battery life, there are days mine doesn't get as great a life as other days.
    Attached Thumbnails Note 5 Battery life thread-1446313952113.jpg   Note 5 Battery life thread-1446313965433.jpg
    10-31-2015 12:52 PM
  2. TheMatrix31's Avatar
    I changed my Twitter app of choice from Twittnuker to Tweetings for the time being since the developer messed up Twittnuker but I'm definitely seeing Tweetings use more battery than Twittnuker. Shame. Twittnuker even with live streaming on wifi was doing really well.
    10-31-2015 03:21 PM
  3. Ruben Ocasio's Avatar
    See i don't get sot 6 to 7 hours all the time but this is still good sot over 4hrs some days i get sot 5 or 6 or 7
    10-31-2015 05:57 PM
  4. fantom305's Avatar
    Right might as well turn the phone into a paperweight, so again making a list is a Bad idea like Kelly said.
    Thank you for saying it.... I was just about to say that if I am supposed to do all this, why spend so much money on a smart phone ??? ... might as well buy a regular phone and like you said, use this one as paperweight....
    10-31-2015 07:12 PM
  5. Hetmasteen's Avatar
    Not sure why but my battery seems to last around 8-10 hours through casual use
    10-31-2015 07:14 PM
  6. smackitdude's Avatar
    Hey guys I have moved from iphone 6 to note 5. I have been seen overnight battery drain on this beauty. This was never with iphone 6.
    I had disable location. There is no email account t to sync. I have even disable Facebook and the Instagram app. I have autosync enabled for the Google account with no for Gmail. I slept at 11:30 PM and woke at 7 am and the decrease was 10%. WiFi was disabled but network data was on. Nfc and other things were disabled. Now what led to that drain is a mystery.
    10-31-2015 09:52 PM
  7. Bklyndude's Avatar
    Here is the thing. This is what i did with my last phone which I considered to have very good standby battery life. I just shut it off. Best and only solution for overnight standby drain. I realize this is not an option for everyone since they rely on thier phone 24/7 but. Hey that's just me.
    10-31-2015 10:30 PM
  8. Bklyndude's Avatar
    Can't say if i will always do this. But right now its one method. If you must have phone on for alarm. Try airplane mode
    10-31-2015 10:36 PM
  9. Kelly Kearns's Avatar
    But you don't have to do all that. I have no landline in my house, none of us shut off our phones and I have zero alarm clocks now.
    It is figuring out what your problem is and correcting that.
    This phone has a battery that doesn't require it to be shut off overnight.
    10-31-2015 10:46 PM
  10. Kelly Kearns's Avatar
    You need to post battery screenshots like others have. Having the GSam app is a good option, it shows what the percentage of loss an hour is and posting that.
    10-31-2015 10:47 PM
  11. James Rogers2's Avatar
    Turning off Bluetooth seemed to help my overnight drain
    10-31-2015 10:57 PM
  12. MedicD's Avatar
    I find disabling everything Package Disabler considers bloat is worse on my battery also.
    I now go through and pick things and do not disable the Samsung beaming service, etc.
    You use shut app, right? Did you buy pocketshut inside it?
    10-31-2015 11:27 PM
  13. Keeping_matt's Avatar
    My battery life is pretty bad compared to my previous phone (note 3) i used to get a day easily and a lot of time most of the next day but on my note 5 i only get around 3 and 1/2 hour screen on time which isn't the best but i still love the phone and recommend it to others
    10-31-2015 11:32 PM
  14. Kelly Kearns's Avatar
    Nope didn't buy that, just use ShutApp and Doze.
    10-31-2015 11:33 PM
  15. smackitdude's Avatar
    I will download the Gsam battery pro app and post my results tomorrow morning
    Kelly Kearns likes this.
    11-01-2015 12:02 AM
  16. Bklyndude's Avatar
    Isn't doze a marshmellow feature?
    11-01-2015 01:26 AM
  17. Kelly Kearns's Avatar
    Doze and ShutApp are apps in the Play Store, different from the Doze feature of Marshmallow. Works in a similar way, but different.
    11-01-2015 01:43 AM
  18. Bklyndude's Avatar
    A ha. Might check it out
    11-01-2015 01:46 AM
  19. Fappybird01's Avatar
    Code:
    www . browser . primatelabs . com/battery3/136175
    11-01-2015 02:09 AM
  20. Bklyndude's Avatar
    Now you coming with the tips
    11-01-2015 02:14 AM
  21. Kelly Kearns's Avatar
    I posted about those apps a couple days ago lol
    Ruben Ocasio likes this.
    11-01-2015 02:57 AM
  22. Bklyndude's Avatar
    Not sure if does helps. Still eating some battery in idle. But i did leave email to still sync so that could be it
    11-01-2015 06:06 AM
  23. Bklyndude's Avatar
    Doze i meant
    11-01-2015 06:06 AM
  24. Bklyndude's Avatar
    This guy on YouTube has the same battery drain issue on verizon in stanby.
    11-01-2015 06:18 AM
  25. Bklyndude's Avatar
    Pretty common. Is it a samsung thing? My first samsung i noticed this had it on my droid hd about 2 years ago. Like I said before the only phone which was the most stable in standyby was my previous lg g2. Anyone had other phone's prior to your note 5 or not a samsung that was able to hold a good standby battery percent
    11-01-2015 06:21 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
