Originally Posted by
IronStar Guys, not sure what im doing wrong but im only averaging 10 hours. This is after 3-4 full charges, brightness at 50%, everything off but sync and wifi. Ive even turned off all the motion stuff.
Hey Iron try the settings for best battery life for the S6. Make sure you go into your account settings and disable the aspects of your Google account you don't use and disable or uninstall the bloatware that you don't use.
For instance my twitter and Facebook doesn't have to keep running and syncing so I turn those off (don't disable just turn off sync). When you open them they automatically update anyway. Same goes for many other apps.
I leave google now on and leave optimal location, Bluetooth and WI fi on too and I'm getting 19 hours with about 3.5 hours of on screen time even with all that stuff enabled but the trick on Android is figuring out what you need to sync and that's it.
