04-25-2017 07:16 AM
3,351 ... 9091929394 ...
tools
  1. Kelly Kearns's Avatar
    Well it is kind of like not disabling too much where my phone is concerned.
    I disable some bloat, but if I disable a lot, it shoots my Android OS up and drains my battery.
    11-02-2015 10:55 AM
  2. TheLastPanda's Avatar
    Agreed. Thought it was quite interesting.
    11-02-2015 11:00 AM
  3. Kelly Kearns's Avatar
    Well it is like I have said several times..if you are having an issue, the fix is not going to be to turn a lot of stuff off. Now if you have bad signal, then you might have to use the bandaid of turning a lot of stuff off, but with this phone, with everything being good, we shouldn't have to turn things off and run at half power, etc.
    11-02-2015 11:08 AM
  4. Ruben Ocasio's Avatar
    I am at work and haven't really done nothing on phone while at work on 4G LTE and my idle is excellent as you can see here.
    11-02-2015 11:29 AM
  5. MedicD's Avatar
    Yeah I charged it twice, but never back to 100%
    11-02-2015 12:27 PM
  6. MedicD's Avatar
    11-02-2015 12:27 PM
  7. Kelly Kearns's Avatar
    With that you can be on TMO. You don't even have to have TMO service at your house, hook that up to your Internet.
    11-02-2015 12:47 PM
  8. movielover76's Avatar
    I've only been on the new update for a little over 5 hours, but standby seems to have improved.
    This is while mostly idle at work, previously that line was noticeably steeper.
    11-02-2015 02:19 PM
  9. Kelly Kearns's Avatar
    Speaking of the update..
    I did this thread about the new feature. Sprint and TMO have this update, or is rolling out as I post this, Verizon and AT&T don't have it yet.
    Here is an explanation of how this feature works, doesn't work like I thought it would. Everyone might want to read this.
    http://forums.androidcentral.com/sho...d.php?t=603077
    11-02-2015 02:22 PM
  10. Ruben Ocasio's Avatar
    Just got home and didn't have no time at all to use my phone at work today standby idle is fantastic as you can see.
    kj11 likes this.
    11-02-2015 03:36 PM
  11. Bklyndude's Avatar
    https://images.tapatalk-cdn.com/15/11...0dafb688a5.jpg
    What? ? How many hours...that is crazy
    11-02-2015 07:45 PM
  12. Ruben Ocasio's Avatar
    Look at the top one it shows on this one how many hours it was on 94% and top one as well.
    11-02-2015 08:15 PM
  13. smackitdude's Avatar
    How's this?
    11-03-2015 09:05 AM
  14. Ruben Ocasio's Avatar
    Still great battery life no tweaks or any special apps at all just disable bloatware nothing else and was playing YouTube for 1 hr and 38 minutes on my second Note 5 .
    Note 5 Battery life thread-uploadfromtaptalk1446568551281.jpgNote 5 Battery life thread-uploadfromtaptalk1446568565371.jpg
    11-03-2015 10:36 AM
  15. Kelly Kearns's Avatar
    So far 4% battery use looks good, but run it for the entire time and let's see how it looks.
    11-03-2015 10:37 AM
  16. MedicD's Avatar
ID:	204372Click image for larger version.
    I would love battery life like that
    Ruben Ocasio likes this.
    11-03-2015 10:38 AM
  17. Kelly Kearns's Avatar
    Ok, this is after the TMO update yesterday and using the battery optimization, but the day is just starting.
    Attached Thumbnails Note 5 Battery life thread-1446569616098.jpg   Note 5 Battery life thread-1446569627817.jpg
    11-03-2015 10:53 AM
  18. dkunzman's Avatar
    What exactly shoots up?
    I disabled 27 items on mine (AT&T) between the Carrier and TW. Basically if I didn't need it, want it, or use it, I killed it.
    I am not seeing any huge battery suckers. From an app perspective Android OS is low down at 8.7%.
    11-03-2015 11:52 AM
  19. Kelly Kearns's Avatar
    My Android System and Android OS shoots up and becomes the number 1 and number 2 things using my battery and my battery won't even last 10 hours.
    11-03-2015 12:04 PM
  20. jamieboii09's Avatar
    Hope someone can help me. The past two night I have suffered from about 50-70% battery drain through the night. This is within a 7 hour window. Please let me know any details needed to help troubleshoot this matter. My phone is also not rooted.
    Thanks
    11-03-2015 04:39 PM
  21. kadavika's Avatar
    I have crazy idle drain at night as well. I have the verizon n920 and have the latest update. I have even turned on airplane mode to see if it was the signal that was causing the drain. from 100% to 75% in 4.5 hours.Note 5 Battery life thread-screenshot_2015-11-02-06-36-48.jpgNote 5 Battery life thread-screenshot_2015-11-02-06-36-43.jpg
    I have tried everything. I disabled most things on Package disabler pro, have turned off autosync. The only thing that I have turned on is wifi, just so I can use whatsapp. I am not rooted, and dont plan to at the moment.
    EDIT: Location is OFF, Power saving mode is ON, there are no themes, I use greenify.
    jamieboii09 likes this.
    11-03-2015 04:47 PM
  22. TheLastPanda's Avatar
    I have crazy idle drain at night as well. I have the verizon n920 and have the latest update. I have even turned on airplane mode to see if it was the signal that was causing the drain. from 100% to 75% in 4.5 hours.Click image for larger version.
ID:	204427Click image for larger version.
    Try enabling everything in package disabled pro and only disable stuff through application manager.
    11-03-2015 05:10 PM
  23. Kelly Kearns's Avatar
    Still going with my battery after the update yesterday and the app optimization yesterday. It is very disappointing that Sprint disabled this feature because it is really making a difference with battery.
    Attached Thumbnails Note 5 Battery life thread-1446592859955.jpg   Note 5 Battery life thread-1446592872075.jpg
    11-03-2015 05:21 PM
  24. kadavika's Avatar
    most things are disabled thru the application manager as well, such as all the apps that I dont use (instagram, etc.). There are some system processes with the android icon that have been running since the phone has been on today, but I dont know what will happen if I disable those.
    11-03-2015 05:22 PM
  25. Kelly Kearns's Avatar
    This is my final before I recharge.
    Attached Thumbnails Note 5 Battery life thread-1446599919923.jpg   Note 5 Battery life thread-1446599931793.jpg
    11-03-2015 07:19 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
