04-25-2017 07:16 AM
3,351 ... 9192939495 ...
tools
  1. Ruben Ocasio's Avatar
    My main Note 5 here's mine best you will see
    11-03-2015 07:24 PM
  2. MedicD's Avatar
    This is my final before I recharge.
    OK so - make a system image of your phone and post it for me to download and flash onto my phone. Idc if I'm verizon... that's insane!
    11-03-2015 07:56 PM
  3. Kelly Kearns's Avatar
    That is due to the update yesterday and the app optimization that came with it. Sprint took it out of their update, TMO kept it, don't know what Verizon and AT&T will do, keep or remove.
    11-03-2015 08:30 PM
  4. smackitdude's Avatar
    i will be happy if i can squeeze one and a half hour more screen time.
    11-04-2015 01:05 AM
  5. dieselhazza's Avatar
    http://i1276.photobucket.com/albums/...pstwfxtilz.png
    It will be hard to get one and a half hour more SOT. Its just not possible. Iphone 6 plus has the best SOT due to how efficient the OS is.
    11-04-2015 02:19 AM
  6. Jesus Delgadillo's Avatar
    Basically the Note 5 is working as Good as the Droid Razr Maxx from VZW, where on standby it would kill 1% or less per hour. Insane difference on my Note 5, it'd just amazing, it feels like it has 2 batteries now!
    11-04-2015 04:03 AM
  7. Bklyndude's Avatar
    What? Two batteries?
    11-04-2015 04:53 AM
  8. Almeuit's Avatar
    Mod Note - Please keep it civil and not throw out accusations / calling people liars. It isn't needed. This thread is to help with battery life for those who want more and/or are having issues.
    Thanks.
    11-04-2015 07:39 AM
  9. bstarr3's Avatar
    I'm getting about 5 hours SOT in my first two days using this phone. So much better battery life than my moto x. Not as good as my wife's iPhone 6s,but more than enough for me
    11-04-2015 08:49 AM
  10. Kelly Kearns's Avatar
    You should continue to get better. Every Samsung I have had seems to have a period where it settles in and gets even better. That happens when new or with a firmware upgrade or a reset.
    11-04-2015 08:51 AM
  11. linkiik121's Avatar
    I'm very impressed so far with the battery.have everything on, no power saving of any kind. Watch youtube, browse Web, facebook, emails and I get about 7 hours SOT.
    Kelly Kearns likes this.
    11-04-2015 11:10 AM
  12. Palladium65's Avatar
    Usage since last full charge time on that?
    11-04-2015 03:32 PM
  13. linkiik121's Avatar
    It was little over 22 hours. The only thing I didn't use is wifi.
    11-04-2015 03:53 PM
  14. AlexMarie15's Avatar
    Honestly, I'm starting to feel hopeless about ever getting decent battery life.
    Attached Thumbnails Note 5 Battery life thread-1446684664173.jpg   Note 5 Battery life thread-1446684756032.jpg
    11-04-2015 06:53 PM
  15. Kelly Kearns's Avatar
    Well I can see a problem right now.. Your signal. Is your signal always that low?
    11-04-2015 07:10 PM
  16. AlexMarie15's Avatar
    Depends on which part of the house I'm in or which area on campus. Usually I get great signal, so I never really take it into account, but it could be the cause for today's depressingly bad battery life. Also, I use Textra but had Google Messenger installed for backup. My phone actually sent me a little message saying that messenger was causing a lot of problems and my phone temperature actually went down after uninstalling it, so here's to hoping I've fixed part of the problem.
    11-04-2015 08:07 PM
  17. Kelly Kearns's Avatar
    One thing you might want to think about is getting a TMO booster.. You are on TMO right?
    You can get the window booster, it is free and only requires you have electricity and get like one bar of LTE. It will grab the LTE signal and boost it through the house. They used to have them on stores, but you have to ask for it through 611 now.
    It works great, it is free and it is portable and you just need to sit one box in a window and the amplifier box in another part of the house, far enough away from the window unit but not too close. It will have you not only at full bars but will boost your LTE speed through the house.
    AlexMarie15 likes this.
    11-04-2015 08:16 PM
  18. AlexMarie15's Avatar
    I'll definitely look into that tomorrow.
    11-04-2015 09:04 PM
  19. Kelly Kearns's Avatar
    It is the best thing I ever used, now I have a tower completed near me. My signal was always the highest it could be and my LTE speed was boosted from about 5 gb to 20-30 gb.
    11-04-2015 09:11 PM
  20. TheMatrix31's Avatar
    Perhaps a stupid question but it doesn't harm battery life over time if you mix up how you charge the phone, right? Just got the free wireless charger and I'm thinking of using that one for overnight charging and the fast charger in other situations. I was always worried about leaving the phone plugged in overnight with the fast charger since it charges to full like 45 minutes. Even with the technology it has to drain then re-top or whatever.
    11-04-2015 11:35 PM
  21. linkiik121's Avatar
    Nope, won't harm the battery. If you plug in the USB in the computer it'll take a long time to charge very slowly. About 6 hours from dead.
    Posted via Note 5 AT&T
    TheMatrix31 likes this.
    11-05-2015 08:39 AM
  22. vm81's Avatar
    So I have had great battery life on this phone ever since I got the phone from Verizon. Initially Verizon had a WiFi bug which was draining my battery in standby when on WiFi...but they seemed to fix that with Oct 20th update for Samsung Pay (atleast fixed it for me). In standby overnight...7 hours I would loose at most 5% or so.
    But something dramatic happened last night...nothing new, no new apps, nothing changed on the phone. I went to bed with the phone at 39% and woke up 7 hours later with 3% left...thats 36% drop in 7 hours of standby. Just cant get my head around it. Even this morning after charge, its losing juice lot quicker than it used to.
    I cant post screen shots as I didnt take one...will take a screen shot at the end of the day today before charging...but this is quite dramatic considering nothing changed on the phone or location or signal.
    Just thought will bring it up if someone else saw huge change like that.
    11-05-2015 10:41 AM
  23. madiom's Avatar
    I can only say that my battery life is really good
    11-05-2015 11:23 PM
  24. MedicD's Avatar
    In my quest to find my battery drain, I disabled the Gmail app and have been trying the stock app. My battery was okay-ish today, but I found the fact that the email app used so much battery today pretty interesting... I have 3 accounts, all hosted on Gmail, synching to the phone, with peak time doing it every 15 minutes and otherwise every 1 or 2 hours. Any input here? Could there be something in one of my accounts that is causing issues with email?
    Attached Thumbnails Note 5 Battery life thread-1446793714340.jpg   Note 5 Battery life thread-1446793744785.jpg
    11-06-2015 01:09 AM
  25. Kelly Kearns's Avatar
    Umm.. Gmail you don't set sync time though. I have 4 Gmail accounts that sync. Your email is high. You don't need the sync like that for push notifications, IIRC.
    I'm guessing the sync time is causing it.
    11-06-2015 01:43 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
