04-25-2017 07:16 AM
3,351 ... 9293949596 ...
tools
  1. MedicD's Avatar
    I'll go back to Gmail app and see how that does. I was kinda figuring the constant push might be using more than only having it do it once in awhile, but we'll see today
    11-06-2015 07:07 AM
  2. Kelly Kearns's Avatar
    Well with Gmail, you can't tell it how often to sync though can you?
    11-06-2015 07:12 AM
  3. Ruben Ocasio's Avatar
    I am still at work hardly used phone since I'm very busy at work look at and awesome idle standby
    11-06-2015 08:34 AM
  4. MedicD's Avatar
    No, it's push email, which I assume is constant. I was thinking normal email, if I slowed it down, might fix it. Clearly it did not
    11-06-2015 09:27 AM
  5. vm81's Avatar
    Gmail worked great for me for gmail. Once I used it also to check my hotmail account, it was draining battery. Took that off...its great again. I just wanted one app for all emails...so went to AquaMail. But for your information (my experience)...Gmail app was draining when syncing other email accounts other than Gmail.
    11-06-2015 09:29 AM
  6. Kelly Kearns's Avatar
    I've used the Gmail app since it came out. Never been a problem for me.
    11-06-2015 10:02 AM
  7. spasell's Avatar
    I use Outlook app for my email. My company is Google Apps for business. I think the Gmail app does drain battery faster than others. It can't be measured and wish it could.
    However I noticed that all day use Outlook app used 3% but my Google services and Android OS have seemed to drop combined over 6% than in the past.
    I started tracking it last week and it's consistently lower. Now I will test again and remove Outlook and go back to Gmail to see if the two services increase and end up at top again.
    vm81 likes this.
    11-07-2015 07:53 AM
  8. Kelly Kearns's Avatar
    I generally never have Gmail show up as more than 0.1 of my battery use in GSam and I never see it on my battery stats.
    These are my settings.
    11-07-2015 08:03 AM
  9. MedicD's Avatar
    No, but I assume some of the use is hidden in system/os
    11-07-2015 08:20 AM
  10. Kelly Kearns's Avatar
    Yeah but it doesn't eat up my battery. It never shows up in my running processes either..
    11-07-2015 09:24 AM
  11. vm81's Avatar
    Do you have any other email besides gmail linked to it?
    11-07-2015 11:37 AM
  12. Kelly Kearns's Avatar
    I have 1 email and 4 gmail accounts.
    11-07-2015 11:44 AM
  13. MedicD's Avatar
    I already disabled Facebook and switched email back to gmail. I can barely make it a day with 3 hours screen time. Wish there was an easy way to see that it was low signal causing a drain... also wish Verizon would stop being a **** and allow WiFi calling, my voip system (8x8) works perfectly fine on my phone
    Attached Thumbnails Note 5 Battery life thread-1446921042434.jpg   Note 5 Battery life thread-1446921051534.jpg   Note 5 Battery life thread-1446921060853.jpg   Note 5 Battery life thread-1446921071544.jpg   Note 5 Battery life thread-1446921081234.jpg
    11-07-2015 12:37 PM
  14. Kelly Kearns's Avatar
    Oh if you have low signal, you don't even need to see. It is constantly trying to connect.
    11-07-2015 12:46 PM
  15. MedicD's Avatar
    Yeah... just wish I could KNOW because in these screenshots I posted, a lot of the time was in 4/5 bar signal
    11-07-2015 12:54 PM
  16. Ruben Ocasio's Avatar
    Just keeps getting better
    11-07-2015 01:24 PM
  17. MedicD's Avatar
    Jealous
    11-07-2015 04:57 PM
  18. sweetypie31's Avatar
    It's hard for me to to gauge my battery life because I can just plug in my phone when needed. I'm also not a super user as some are. I just use my phone.
    11-07-2015 05:23 PM
  19. declauds's Avatar
    After using my note 5 for about a week I'm quite disappointed with the result of the battery. It can only last for about 12 hrs reaching 15% with "moderate" use. I just used it for FB, browsing, around 20 mins of Spotify and around an hour of YouTube. And just texting without any calls.
    I got disappointed because before I bought this phone I've already read that the battery results is superb.
    PS I cant attached my SS of battery usage because the AC app keeps on crashing after trying to attached my SS!
    11-07-2015 06:34 PM
  20. Ruben Ocasio's Avatar
    Here's Today's which is still excellent even thought SOT is a little over 4hrs but close to 2 days with no charge and every battery life i get it different not always the same usually i get 6 to 7 SOT with 15 hrs. 👍👍👍
    11-07-2015 07:01 PM
  21. linkiik121's Avatar
    https://images.tapatalk-cdn.com/15/11...198d20cb4f.jpg
    https://images.tapatalk-cdn.com/15/11...169d80e631.jpg
    I'm loving the battery life. I didn't for a moment expect it to be so good. I'm looking at the battery percent 57 and almost 4 hour screen on time.
    Also noticed I have very little drain if I don't touch the phone.
    I too would like to post a picture but the app crashes every time.
    Posted via Note 5 AT&T
    Kelly Kearns likes this.
    11-07-2015 07:31 PM
  22. linkiik121's Avatar
    Just checked 56%, 3hours and 33 mins SOT. Still very good I think.
    11-07-2015 07:38 PM
  23. DamienP's Avatar
    Everyone uses their phone different, but I can tell you without and charts or graphs this phones battery runs out at a constant rate. If you get light use you will be fine. If you are near a plug were you can fast charge you will be fine. But if you work out side and use evernote for your job all day like I do your going to be in a pinch on a daily basis, wondering why you paid $900 for this device.
    Personally I could care less about the "design language" and the thinness of the phone. I wanted the best System on a chip, and a big screen.
    11-08-2015 01:27 AM
  24. Kelly Kearns's Avatar
    Well that actually isn't true. That might be happening for you, but without your info, no one knows why. It doesn't happen for others.
    11-08-2015 01:34 AM
  25. Richy9596's Avatar
    Hi everyone,
    I'm concerned by the fact that Samsung ecxluded the option of switching off the fast charging for a Note 5.
    In other words I have to always fast charge my device unless I use a different non-fast charging charger.
    Does anybody have an idea as to whether it's bad for the battery? I mean a fast charging could reduce the battery life. What do you think?
    I once tried to charge my Note 5 with a Sony 0.5 A charger, which gives the same safe 0.5 A as a PC usb connector does, but I noticed that the battery drained very quick after that.
    11-08-2015 02:12 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
