Hey Iron try the settings for best battery life for the S6. Make sure you go into your account settings and disable the aspects of your Google account you don't use and disable or uninstall the bloatware that you don't use.
For instance my twitter and Facebook doesn't have to keep running and syncing so I turn those off (don't disable just turn off sync). When you open them they automatically update anyway. Same goes for many other apps.
I leave google now on and leave optimal location, Bluetooth and WI fi on too and I'm getting 19 hours with about 3.5 hours of on screen time even with all that stuff enabled but the trick on Android is figuring out what you need to sync and that's it.
Ok so I am new coming back to Android from Apple. Last time I had Android it was Galaxy Note 3. Been well over a year and I actually dumped my iPhone 6 Plus for this.
My biggest beef is battery. I see all the tests and great battery and in my entire previous time using Galaxy devices I rarely get close to what people say they get. If I get 8-9 hours I'm lucky.
Typically I use auto brightness and then spend heavy use on my email applications, texting in particular.
I do use Facebook frequently. Twitter occasionally and once in a while audible. No games but I do use Chrome for certain sites here and there.
I consider myself a heavy user like some who do same as I do.
I'm curious though how to shut off Facebook and Twitter sync. I went into Facebook settings and while I don't get notifications I see the little number all the time telling me friends updates which I don't want.
If I could get 12 hours with this I'd be thrilled.
For reference my iPhone 6 Plus gave me 15 hours under same conditions which was it's single best feature. Loved the battery on it. Outside of that I wanted the Note 5 features.
Any suggestions on undoing Facebook updates? . Think that might be one of issues
