Kelly Kearns
I'm just curious how everyone's battery life will be this time next year, if they keep their phones that long.
from my old nexus 5
Because of the battery?
from my old nexus 5
from my old nexus 5
Got the phone Thursday night. Been tweaking and setting it up. Took it off the charger last night at around 9pm my time and had somewhat normal use outside from streaming Spotify or At Bat while driving. I think I'm on the right track with things. I don't have too much on-screen time with normal but I'd like to go from getting 1:45 or so to about 3 or 4 like you guys are getting. I still think it seems relatively healthy and hopefully it settles in nicely.
Any problem areas stand out to you guys? Let me know if I should tweak anything. I have location on wifi network only or whatever that setting is and Google Now on. I slept from 3am to about 10am too and my battery drained like 5% or something. I'm on wifi at home but just regular mobile network while I was out last night and just a bit today.
View attachment 193902View attachment 193903View attachment 193904View attachment 193905
Just wanted to try to help you. You don't have to do a factory reset. You can reset the gsam stuff in the gsam app. Makes it kind of start over. I'm not sure where it is without looking but it's in there. You could also probably just uninstall it and reinstall .Really dont want another facotry reset. Got all the settings and apps installed. Batelly life is okay just over 4 hours sot on full charge
So if you ever used an iPhone there is an option in iTunes to download a NEW copy of ios and then install it. There is an option to do the same in Smart sync or if that doesn't work Samsung Kies. You load up smartsync, go to tools then firmware upgrade and initialization. You will need your model number and serial number. It will download a completely new copy of the note software and have you put your phone into recovery mode. It will then install the new software erasing everything.What do you mean reinstall? What did you do? Who's your carrier
One thing I liked about iPhone 6+ was you could tell GPS or location to use apps in various states. So I never had it set to on unless the app was in use. Not sure if that is possible in this case.
WiFi usually improves standby if you have poor cell signal. But cell stand by is a known issue in Android that Google hasn't fixed yet. Apparently carries over for some other phones, although I've never personally experienced it on my Note 4Does Wi-Fi affect standby? Honest question cause I was home from the time I took the phone off the charger at 7:15ish am and was on Wi-Fi till I left the house at 4:45 to officiate a high school football game. Met my crew around 5 with 14% standby time. From 4:45 to 11 my phone has been on 4G. Here are some screen shots. I took a screen shot at halftime.
Yeah I can't seem to get rid of cell standby I even am using doze now and can't get it to go away.
For those getting cell standby battery drain, the first thing to do is disable voice over lte. It has a different name on different carriers so google it but can you can usually get to it in dialer settings. The next is to disable WiFi calling if its available. Those are two things that always cause it and are bugs Google has to fix. Weak signal is the other.
Sent from my SM-N920T using Tapatalk
