MikeekiM
I picked up my phone from the charger this morning at 6am and have purposely kept it away from the charger all day long...
With light/moderate use, my battery is now at 61% (it is 4pm now...10 hours later). Admittedly, I have not used the phone much today...
I am optimistic that with the Adaptive Charging, that the Note 5 will largely meet my needs. Supposedly the adaptive charging goes from 0%-50% in 30 minutes, and to 100% in a little over an hour... That means that if you stop by a coffee shop or a restaurant for lunch, and they have an AC outlet available, you can be at 50%-100% while you eat or have you cup of coffee... Not bad, right?
My main issue is that I like to use my phone as my main (and only) camera...when I am on a personal or business trip, I sometimes take 100 photos in the span of 30-60 minutes. With that use case, the battery burns down pretty quickly, and usually I am not near an AC outlet in those situations... I'll need to get a portable battery that supports adaptive charging. Samsung has one, but it's pretty pricey...their website shows it as going for $69.99 when it releases...
I am at 12 hours now, and my battery is at 56%... Again, admittedly it is a light usage day... I'll need to do the same test with a moderate and heavy usage... Based on other reviews, I have heard that the "screen on time" is more like 4 hours...
One more update before I turn in for the evening... It's nearly 11pm here, my Note 5 has been running for nearly 17 hours and my battery level reads 38%. As mentioned earlier, I am going to need to do a similar test on a moderate or heavy use day... But this test has proven to me that this phone will likely go 24 hours on a single charge with light use...
