jdhooghe
Yep! Search Cortana for Android on Google and opt in to the betaWhoa wait. There's a Cortana app?
Sent from my SM-N920T using Tapatalk
Just pulled out my old Note 2, Note 3, as well as S5. Also my current S6 and Note 4. None of them have that notification. I've never seen it before.
Although all of them are Verizon phones, so perhaps that's the reason?
Just to let you know that I got my T-Mobile Note 5 today, after waiting for an Unlocked Silver one, I just got tired and also realized that it's not coming down on price for some time, so i took the plunge for this one and immediately sent to Samsung the 1 year free Netflix offer to help with the total price paid.
So I've been setting it up, doing my usual tweaks and soon I'll be helping with more direct experience. Kelly, the Auto Stop feature, at least on the T-mobile version is on the Smart manager App, under RAM management, Manage Apps. So for all of you that at least have the Smart manager App try it in there, for the rest look for it on the battery Settings, but it's definitely there.
I'll keep in touch.
//images.tapatalk-cdn.com/15/09/03/c05a7e2754a2c6c42401812176ea1bdc.jpg
Even if it did have a battery drain it is easy to hibernate it compared to Google Now which is baked into Android itself imoJust downloaded it so we will see. Don't like it for my SP3 because it is a big drag on battery in connected standby on that device. Hopefully won't happen here.
I'll keep in touch.
Oh.. I don't mess with that. It is connected to Clean Master, so I don't touch that app.
You're an addict! can't wait for your thoughts on the Note 5. Would love a battery comparison to the S6 Active.
dreaming of electric sheep
Where can I get screen on time?
//images.tapatalk-cdn.com/15/09/03/39d87b1cd854834376d75700fe74acb7.jpg
Sent from my SAMSUNG-SM-N920A using Tapatalk
Do you know what play services was doing? Installing apps or is that unknown? Also maps takes a lot of juice so the comparisons to ours will be difficult to make. Facebook it seems is also running rampant on you; it worries me that it is taking more juice than a quad hd screenWhere can I get screen on time?
//images.tapatalk-cdn.com/15/09/03/a659ac04033383915ef31313a0ef0215.jpg
Is this any good?
The majority of my usage today was Facebook. I have my screen brightness to 25%/auto. I used navigation for about 25 minutes today. Not sure what play services was doing. I have Google Location Services on along with history.Do you know what play services was doing? Installing apps or is that unknown? Also maps takes a lot of juice so the comparisons to ours will be difficult to make. Facebook it seems is also running rampant on you; it worries me that it is taking more juice than a quad hd screen
There's an app in the play store called gservice fix. I've never used it but I've heard that it fixes that drain. Maybe someone here can comment on itThe majority of my usage today was Facebook. I have my screen brightness to 25%/auto. I used navigation for about 25 minutes today. Not sure what play services was doing. I have Google Location Services on along with history.
Well, this is something that was on the battery management on the S6 and S6 edge but since latest update it was moved to be accessed through that app, if it's really part of the app or not I don't know, only thing I know it's that it indeed helped with S6 batteries when it was released.
I did not know this! Every time the ram is cleared android has to go through and re-index everything? That would probably explain a lot of what users see as high android system drainYeah it was, but the Clean Master, by Cheetah Mobile, isn't an app in the app drawer, but is listed in application manager. When you open that built in app, the data and cache on Clean Master immediately go up and it is a unnecessary RAM cleaner and it can interfere with indexing, which can make your Android System run high.
