Doing pretty good now!
Things I realized that will drain battery
1. If your not on a good WiFi network (not strong or keeps dropping)... Your battery will drop FAST
2. I used to use auto wifi connect apps ok my S6, but I realized it drained battery... After u installing it... My battery is BETTER
3. In WiFi settings, turn Keep WiFi On While Sleeping to "Never"... It helps save battery
4. Doze drains battery if you constantly awake your phone... It will make "Android System" go up... I turned mine off and my battery is doing great
Sent from my Galaxy Note 5!
Well from my testing that's what I noticed. I disabled mine and my battery is pretty good now... When u make the phone sleep then Doze activates and when you open it has to turn itself off until u make the phone sleep again... I think that alone makes Android System go up because it creates a VPN and activates and deactivates constantly... My guessSo you're sure that Doze does this? I have Shutapp anyway so I'm thinking I might diable Doze temporarily and see what happens.
https://forums.androidcentral.com/e...quiteinsane.galaxybuttonlights&token=wEmx3l3SI turned off Doze, wasn't sure it was helping at all.
Dpham00 - what do you mean?
I put my Verizon extender in my basement, and right now I'm about 10 feet away from it (1 floor up) and it's not connecting to it - it only has 1x but I have 3 bars 4g.
https://forums.androidcentral.com/e...quiteinsane.galaxybuttonlights&token=vTuX9CMZ
Sent from my Verizon Samsung Galaxy Note 5
you have power saving mode on i never have it on is why your battery life is better. I hate when i put it on it makes my phone run like crap!
i watched a couple youtube phone reviews on the note 5 too and they say the battery isnt that great and wish they would have put a bigger battery in it.
So I turned that off and still I am getting WiFi on when I turn the screen off. I don't get it.
I set I right and when I turn the screen on after it's been sitting off for 5-10 min the WiFi symbol is right there and GSM shows WiFi and cell signal are almost identical in times
Why the hell would this be happening if I have option selected to never allow WiFi when sleeping? I had my screen off for 20 minutes at home and cell and WiFi are exactly the same. It's NOT sleeping despite clearly having that option selected.
I know this is causing more battery drain as well.
I just dont get why your backing up the note 5 so much like anything we post about it being bad you always dont agree.....We dont use the same apps and settings as you so you cant keep saying the note 5 battery is good and i can link you to about 8 reviews i watched and they state the battery isnt that great and is a downside of the phone.
