dkunzman
Is your wifi 2.4 ghz only?
Note 5 handles 2.4 and 5.
I have my wifi set up with different id's for 2.4 and 5. I set my Note to choose 5 as Primary with 2.4 if no 5 or signal gets low.
Works well.
My Wifi is set to only stay on when plugged in. What's up with this?
Did you try wipe cache in recovery, if that doesn't work i would factory reset, i know thats not what you wanna hear but it's the only thing i can think of.Can anybody explain the "mediaserver" process? It is draining my battery to death!
I fully charged my Note5 last night and leave it there (muted, wifi on). 8 hours later, the battery drop from 100% to 56%!! And 55.8% is consumed by the "mediaserver" process!
I have no audio files, no images on the phone.
At first I thought it was the poor signal at home; but when I put it in somewhere else with excellent signal, same results...
I did some research on the "mediaserver" process and it sames that the solution is only for rooted devices or old phones with SD card.
Any suggestions will be appreciated!
Works well.
Battery life is still terrible on my device. Better with bluetooth disabled but still wont last much past 10pm either way.
Thanks. I'm gonna do a factory reset then install apps one by one to find out which one causes the problem.
I tried this, but my battery is still draining , it was close to 40% by 3pm! I thought Google Now was the culprit. I don't know anymore. I do Not want to delete apps that could be rogue because I Use them all the time.
Which carrier are you on?
Hmm I'm on AT&T as well here's some screen shots of my battery haven't used Hardcore but have made texting and lots of gplus and Tapatalk browsing, do you get anything like this.AT&T. I just don't get it, I don't have a very high brightness, (set to auto), I'm using Package Disabler Pro, I have no Power Saving apps installed, I use WIFI all the time, the device on GSM Battery Monitor has 0% held awake, SOT is usually high, Most of the apps I use are restricted to background, Google Photos only sync with WIFI, I have location turned off, Google Now turned off, I deleted Facebook as I've heard that's a battery drainer. My accounts, well there's no option to sync Wifi or Cellular Network. Spotify only downloads my playlist over WIFI only. I Use Do Not Disturb at night, so nothing should come through except calls, and alarms. I've turned off vibrations on the phone as I know it drains battery. All bloatware is disabled. I have factory reset the phone, wiped the cache partition. My cell signal right now is at 4 bars, sometimes it decreases. It just varies, but I can't do anything about that from where I live. I do put the phone in airplane mode when that happens, but I leave WIFI on.
I think that's it.
You mean it showing WiFi on in stats?
//images.tapatalk-cdn.com/15/10/02/b2b4b2d58d4bdea33863785044b6d437.jpg
//images.tapatalk-cdn.com/15/10/02/2dff79a2e04461d74675ea42f913f1eb.jpg
Running On Samsung Galaxy Note 5 N920A
