Greetings,
I've switched from S5 to Note5 last week and I'm having a terrible battery depletion issue. I'm charging my phone to 100% by using its OEM adaptive fast wall charger and unplugging it and closing all background apps and cleaning RAM with smart manager just before sleep. After waking up after 7-9 hours later I'm finding that 60-65% left in the battery everyday. I'm sending you the screenshots. I didn't see any apps running in the background. No significant WiFi downloads, no cell operator caused signal issues or significant mobile data usage in the background. And screen is off during these hours but I'm loosing nearly half of my charge by sleeping beside my phone..
After searching on Internet I've applied suggestions such as:
- NFC, Bluetooth, adaptive screen color, etc. all disabled (WiFi, MobileData, Location, mail sync are the only active ones).
- Screen Brightness is around 25% and set to auto.
- Disabling all sensor related functions such as smart stay, background animations, etc.
- Being sure that google location history is turned off. (I'm constantly using swarm app to make check-ins while I'm awake so I will not disable the GPS - it was always on at my S5 and I never had such a problem).
- Disabling android device manager user (under advanced security options).
- Disabling all Sync options except emails (2 mail accounts in mail app that are being checked every hour and Gmail).
- Restricted nearly all possible apps from using background data (except whatsapp, facebook, messenger, swarm, periscope, youtube just to keep receiving notifications-but even they aren't active during night).
- Adjusted all apps to auto close in smart manager.
- Only using OEM weather app and nearly no apps yet installed on the phone.
I'm about to loose my mind because of this battery issue. If I'm supposed to disable all the functions of the phone all the time and every time if I'm going to need them I'm supposed to spent lots of time at the settings to activate them and then disable them again; what's the point in using this phone? If I can not solve this problem I'll get the phone back to dealer for a refund.
I'm madly need your advises. Your help and support will really be appreciated.
Thanks.
Cheers,
