israel01
Yeah, someone in a another forum was worried about tbis, but a person using the Doze feature on their Nexus 6 said that it won't interrupt the notifications.
Enviado desde mi X210 mediante Tapatalk
I don't have enough posts to post a screenshot...but the battery settings say the cell standby is using 20%.
I talked to a Verizon rep but he wasn't much help.
Thanks for the suggestions. My location is always off anyway, and Smart Network switch was already off.If you began to set your phone yesterday, this is normal, remember, the phone is trying to set everything you have on the cloud, on each app and in all places. One common thing is if you just set Google photos, the first time it will upload or sync all your photos with the cloud, depending on the amount of pictures and videos you have, it may take hours to do so, draining your battery in the background.
Just follow the suggestions on this thread, it's long, but begins from the very first page. In a summary, turn off Location History on Location settings (Location reporting is on now by default and a huge battery killer) adjust your Screen brightness to a point where you feel comfortable, and go to Wifi settings and in Smart Network Switch, turn that off, and in Advanced turn off Always allow scanning. Remove Bloatware and turn off Services and sync from Google and Samsung that you won't use.
I think the above is a summary of the most important things to pay attention if you are concern of battery life.
Is there a guide to bloatware? I don't really know what I should and shouldn't disable.
In the time between this post and my last post the battery drained another 4% down to 40%. :/
Make sure you turn off printing it comes on by default go to few post back i posted it cause that will also eat your battery if on.Thanks for the suggestions. My location is always off anyway, and Smart Network switch was already off.
After your phone settle should look like thisThanks for the suggestions. My location is always off anyway, and Smart Network switch was already off.
What's your time screen?//images.tapatalk-cdn.com/15/10/19/3f1d9bc49b6b2e61be2a6c738a0d4b0e.jpg
Hi,
I see people with 50% and a lot of hours left, I disconnected the phone everyday around 5am, if I don't charger the phone in mid day, it will turn off by 5p, is this normal? Any suggestions
Thank
Sent from my SAMSUNG-SM-N920A using Tapatalk
Running On Samsung Galaxy Note 5 N920A
