Thats from my second Note 5 i just bought yesterday for my daughter.
That would be great. One post summarizing the best tips....maybe even make it a sticky. Few of us have the time to read through everything in this thread.
I feel like some people are more about showing off than actually helping
Not really. You have people claiming to get 12 hours. What were the main tweaks they did or can recommend that they think someone with less than optimal battery predromance can do. These phones are pretty much identical. I would think. So someone like me with new phone, few apps. Just some basic things i might have missed. Known to the community that can be battery killers.
I am working my daughters Note 5 gonna give it 10 cycles after that battery is gonna improve more even tho just the way it is now battery life is good on her Note 5.Thats from my second Note 5 i just bought yesterday for my daughter.
This is what I got yesterday. I think it's kinda low considering I only got less than 4 hours of screen on time. I have my screen brightness set to 25% at work or auto outside of work. I think its about 50% when it's on auto as I'm not in bright environments.
Why is Android System, Kernel, Google Play Service, and System always so high on the list?
These are my disable stuff. Anything I shouldn't disable that would impact battery life?
I usually am in area of good reception (3-5 bars) so I don't think that's draining the radio.
I only get low signal at home. at the time of the screenshot I probably have only been home about an hour.You are losing 5% an hour, that isn't bad at all. Your worst culprit is your low signal, I guarantee you. Your signal you are showing is not good.
I have AT&T. What do you mean by standby?Do you have Verizon? Your standby is high.
Sorry, not your standby, that was another I saw.
Perhaps there is another member willing to post a summary of top tips.
Kelly, I understand your opinion. I am hoping another kind member will create a summary of tips to save battery. Please don't take it personally. Perhaps another member would like to try. If not no harm no foul. Please leave the option open to others.
That is not opinion.
None of us use all the same apps.
None of us use our phone the same way.
We have different carriers.
What I don't use and disable, someone else uses and doesn't want to disable.
At least 3 people have told you this isn't possible.
The top tips:
Disable bloatware and apps you don't use.
Read the thread.
We've said this over and over.
