You need to post battery screenshots like others have. Having the GSam app is a good option, it shows what the percentage of loss an hour is and posting that.
Check for any email app or app that has is constantly checking, that's was the issue on my phone, after I found the app, now get about 20hr battery or moreNot sure why but my battery seems to last around 8-10 hours through casual use
This guy on YouTube has the same battery drain issue on verizon in stanby.
https://youtu.be/wkqkqAB70HU
I don't have to post gsmam when i have two eyes. Just like you just stated. That the iphone was stable in sleep. I cannot use iphone as a point of reference seeing as i did not have one since the 4. But i will take your word for it. Now with that being said. Is there something that can be done with the note 5?
I posted this before when I did an experiment and comparison for 1 week.
The iPhone 6+ standby barely moved the needle on battery. I took mine off charger at 100% didn't touch it all night and in 7 hours the battery drained only 2% in 7 hours.
N5 drained 6% over that same time.
But when actually using the phone itself the N5 routinely have me about 15% more time overall then the iPhone 6+
Yup like when i had the LG G 3 idle was awesome but once you use the phone eats way way lot more then the Note 5.Yes some phones will do that. They will have very little standby loss and huge use loss.
Either this thread or another, a couple talked about an LG and how it would do great and then when it got to a certain point and it was still a high amount, it would drop like a rock with use.
Are you seriously complaining about 2 to 3 % in 2 hours while idle that is normal nothing wrong with that mate.Tested battery drain while asleep this morning. I turned on airplane mode and force closes all apps. It still drained 2-3% in 2 hours which I don't think is acceptable. What is this "held awake"that's draining my battery?
Also, isn't it weird that even when I have the phone in airplane mode the signal is still medium?
//images.tapatalk-cdn.com/15/11/01/d62a86d21d8fd87f87b55753397a9ab3.jpg
//images.tapatalk-cdn.com/15/11/01/6abdac42998d1d2ce98209759bde6a43.jpg
//images.tapatalk-cdn.com/15/11/01/3089037ae67321bce4e50ac4fa4af100.jpg
I am because that's with nothing on. I believe it was you that mentioned 2-3% drop over night but with radio and WiFi on.Are you seriously complaining about 2 to 3 % in 2 hours while idle that is normal nothing wrong with that mate.
Just so i understand; You need to see how it drains over night at idle?
