sweetypie31
It's hard for me to to gauge my battery life because I can just plug in my phone when needed. I'm also not a super user as some are. I just use my phone.
Here's Today's which is still excellent even thought SOT is a little over 4hrs but close to 2 days with no charge and every battery life i get it different not always the same usually i get 6 to 7 SOT with 15 hrs.
//images.tapatalk-cdn.com/15/11/07/640d476ecb6af6b06dad2f198d20cb4f.jpg
//images.tapatalk-cdn.com/15/11/07/321b0d76ef103dca8deb6f169d80e631.jpg
Everyone uses their phone different, but I can tell you without and charts or graphs this phones battery runs out at a constant rate. If you get light use you will be fine. If you are near a plug were you can fast charge you will be fine. But if you work out side and use evernote for your job all day like I do your going to be in a pinch on a daily basis, wondering why you paid $900 for this device.
Personally I could care less about the "design language" and the thinness of the phone. I wanted the best System on a chip, and a big screen.
Hi everyone,
I'm concerned by the fact that Samsung ecxluded the option of switching off the fast charging for a Note 5.
In other words I have to always fast charge my device unless I use a different non-fast charging charger.
Does anybody have an idea as to whether it's bad for the battery? I mean a fast charging could reduce the battery life. What do you think?
I once tried to charge my Note 5 with a Sony 0.5 A charger, which gives the same safe 0.5 A as a PC usb connector does, but I noticed that the battery drained very quick after that.
I think so too, Kelly, but I liked the option of switching it off with my Note 4. I didn't need the fast charging, I untick it. Now there's no option. Anyway, thanks for sharing.
Do you have your Playstore settings to not update apps automatically?I started using a VPN and noticed that it said in the last 30 minues, my phone has downloaded over 130MB on wifi...
This correlates with GSam telling me my system is downloading a lot on wifi. What could my system be doing?
Maybe Play Music, Keep, Youtube, Drive, Samsung Kids mode?
my phone is s6 edge and it has battery drain problems i posted in many threads but i got no replies
i have tried clearing cache, reseting but still doesnt help
View attachment 205027View attachment 205028
Samsung account is having trouble syncing, maybe that's causing the drain? I tried to remove and re add it with no success in fixing it
Try removing the VPN and see if it syncs. It may be that causing it.
As for the data it could have been photo back-ups or anything really. It's hard to gauge.
