Kelly Kearns
bump please someone help me :/
You have to post your battery stats, the battery page, what is being used and also it would help to install GSam and post that.
What I've been doing lately is before I unplug my phone, I do a phone restart to clear any BS that's running. That seems to help. Maybe it doesn't. I don't know. I do know that when I do that and I drive home from work, I'm still at around 75% when I get home.
I don't use my phone nearly as much as you guys do though, apparently. I don't think my phone as constituted would be able to get 5, 6, 7 hours of SOT. But I don't need that so it's okay I guess.
I can get around 15-20 hours before I get to 20-25% left so it's pretty damn good for me lol. But it also leaves me wondering whether my battery should be lasting like 2 days since I *dont* have the screen on that much, haha. If I leave it overnight it drains like one percent an hour rather than 4 or 5 so that inflates numbers.
View attachment 205079 this is ridiculous. Why is android downloading 2GB of data for? I'm using the basic xml settings from the "detouchwizzing and debloating note 5" thread for T-Mobile on xda. But this is beyond my comprehension
Agree with you, You beat me to it but that is definitely correct.
And if I unplug it fully charged before bed I can also pretend I get 48 hours of battery life.
I keep mines here always
//images.tapatalk-cdn.com/15/11/08/54e24517e8866bf7a4ec2d8ad68f0460.jpg
I was having battery issues last week. First 4 days Android System kept getting to the 20% mark. Cleared the cache partition and didn't fix it. Decided to do a factory reset. Didn't work either. Got up to 22% with about 50% battery left. Decided to uninstall Nova Launcher and that was it. Android System hovering around the 2-3% range now since I took it off yesterday
Your brightness is up there and you still get 7 hours SOT?? I barely get 4 hrs at 1/3 full brightness
Do all of you who get 6-7 hrs use package Disabler pro?? Or by default you get 7hrs SOT?
I don't use it i do have that app but haven't used it , All i have is in settings all applications manager bloatware disable from there, I'm on AT&T .Your brightness is up there and you still get 7 hours SOT?? I barely get 4 hrs at 1/3 full brightness
Well Android OS is such a dump for anything and everything, hard to pin down what shoots that up.
I use Nova, but it doesn't affect my battery or Android OS. I'm wondering if you had an icon pack or some other setting in Nova that did that.
Thank you so much. I cannot see the contents clearly but I think I see you've disabled CM, Microsoft Office, whatsapp and instagram among them.I just package disabler pro and this is what I have disabled.
Are you active on social media or whatsapp like apps through your phone?I don't use it i do have that app but haven't used it , All i have is in settings all applications manager bloatware disable from there, I'm on AT&T .
Gplus, hangouts, Gmail, stock message, Tapatalk, YouTube , Google Drive ,dropbox, most of those do sync.Are you active on social media or whatsapp like apps through your phone?
Didn't install anything with it. Just Nova with Nova Prime. It wasn't Android OS. That was always low. It was Android System taking up a lot. Maybe I'll try again in a few days.
For Verizon it seems to be normal. They have some bug for many that cause standby to go up when WiFi is on.
I am searching the forums but is there any tweak or fix to help with that?
