Kelly Kearns
Yeah. That's my point!!! If I charge my phone and go to bed full, unplugged, after 8 hours, EIGHT HOURS, it drops 2-3%. . My point is these graphs and charts etc mean ZERO for someone that does that.
For instance. I did just what I said above. Then got up, used my phone pretty hard for most of the day. By the time I was done work and driving home, I had a graph that showed I had used my phone for 18 hours and 27 minutes and was down to 12% battery. Pretty damned awesome right!?!?
Ok. Now same thing except this time I left my phone plugged in until I got up. So I didn't have 8 hours of phone on with only 2-3% loss despite idle use.
Good. We've established that.
So I unplug my phone at 530am, start using it again SAME as last test. Now, this time, I get home at 530 pm and guess what? I'm at 12 hours, 22 minutes, and have 14% battery left on my computer graphs and stats.
How can that be? My actual USE was about the same and yet, I got 6 hours less, about 4 hours OF SOT between the two.
I think you see my point. If I only drop 2-3% in 8 hours of non use of course when I actually use it I am getting REAL stats.
So again, the point was simple. Posting stats doesn't say much given what I proved above.
Usage is usage. I can 100% guarantee that if you use this device as much as I do and in the ways I use it, as a phone and email device, productivity device, you're not going above 15 hours. No how. No way.
And how do I know? We deploy more than 18 of these phones across our Salesforce and they all same the same thing. Using it as productivity device (isn't that how it's promoted?), you're not going over 15 and I doubt above 13-14 without getting into the red.
The KILLER thing about the Note 5 is quick charge capability. Putting it on a quick charger for 20 minutes you'll get an additional 1.5-2.5 hours. That's pretty bad ***.
I think you don't get it, which is why SOT is an important stat. I can get days of time with no SOT.
Time between charges without SOT mean nothing, zero, a phone can idle for days.
This is why we always ask for SOT.
