I got this phone last Sunday and so far it's great. Just wondering if I should drain the battery all the way??. I usually charge it at 5 percent. Thanks guys
Well that actually isn't true. That might be happening for you, but without your info, no one knows why. It doesn't happen for others.
I have been getting terrible standby drain at night. There should be no reason for battery drain at night because I'm asleep and so is the phone. Note the steep slope from about 2 AM onwards. Is there any fix for this? Google play did not do any app update last night
Same here. I had my 31% last night and it dropped to 14%. When I fully charge my battery I get 12 hrs remaining in battery usage estimate.
I tried a factory reset and nothing fixed the drain.
When you did the factory reset did you install any apps after? Like gsam.
Posted via Note 5 64GB AT&T
I can tell you this adguard is a battery drain killer that i know for sure.What's ad guard? Seems to be taking up some battery.
Why are you quoting me twice already.
Damn apps lol. is the errorFirst one was agreeing with you on the great battery life. Second one was an error. Not really sure. How or why the pictures came in separate.
