Leave it on. It shouldn't have any real impact on the battery.
My location is always on never do i turn it off i keep my location set on wifi and mobile that setting is low which saves you battery.This is what I was referring to
Im barely getting 20hrs of stand by time with my note 5. Its been 2 months since i got the phone. Sot barely reaches 4hrs. Should i factory reset? Recalibrate the battery?
My phone drained 10% in 4 hours, while sleeping, with the power saving on. It looks like it all went to the phone radio. Is this normal, or because of a bad signal?
You're fine. Look at the time you have remaining. Plus you're only losing 2.2 % an hour.
That was cause i was in Denver visiting family for Christmas, but now i am home Laramie Wyoming, didn't do any changes , so must of been a weak Network where i was in Denver.What did you do different about this time vs other?
Yes a few disabled with Package Disabler Pro and the rest bloatware i don't use from settings, All Applications.
I downloaded this to see if it'll help. No idea how it works so I just did disable bloatware lol. Fingers crossed!
