aspiller1998
Got mine in late September and was great till November. After that android system started draining me, and so did wifi. Frustrating.
That is odd i have my AT&T Note 5 since it first came out and no battery life issues at all, i am always getting SOT from 5, 6 , 7 and 8 , my normal SOT is 7 hrs or so.I'm starting to wonder if the batteries in the Note 5 are becoming defective. Over the last month or so my battery life is getting worse. At times my battery percentage will be at 7%, and literally drop to 3% skipping 6,5,4%. My bought my phone on release day.
That is odd i barely even see Google Play Services on my background at all if i do see it probably using 2% that's it.My "normal" is 1.5-2 hrs…
I know Verizon has a bug a battery life, but I'm on AT&T Note 5 if it makes any difference to anyone else.And like i said before if i go to bed with 100% on battery and Wake-up 8hrs later i be at 98 or 97% on battery and on wifi 24.7 on .
Did you try a factory reset, i know no one wants to do that but i have heard it fixes battery life issues.I'm also on att note 5. My battery sucks
What settings do you have in location and do you have the 4G LTE Enhanced services off?Yes, I have done multiple ones, cleared cache, disabled bloat, you name it! And nothin'!
Location is off, I've turned off enhanced LTE & even tried airplane mode for a couple hours. Still the same.
2 screen shots above broken mate.Nothing done, no power saving , auto dim, I also was listing to Pandora for about an hour
View attachment 211638View attachment 211639
