Note 5 Battery life thread
Venom0642
2,361
340
83
For those having issues with Battery drain, why don't you do this to calibrated your battery, on the dialer press *#0228# after will show a menu with battery details and in the bottom a button saying QUICK START, press there and it will lock the display, unlock and wait a little bit at till get a message. After close everything and drain the battery at till 0 and after full charge and then should be calibrated , this works on any Samsung phone.
Aaron_Jones
Active member
Dec 28, 2015
44
Is there a certain percentage that the battery has to be at in order for this to work properly?
Does it matter if I use the quick charger or a slow charger?
Venom0642
2,361
340
83
Doesn't matter if it's quick or slow charger, first you need to let battery hit 5 % then dial the code i mentioned after that recharge.
Venom0642
2,361
340
83
Actually i myself did it this way dial in code where ever your battery percentage is at then once you reach at 5% recharge phone at 100% works this way as well mate. @Aaron_Jones
Aaron_Jones
Active member
Dec 28, 2015
44
Thanks, I'm at 9% now and im at work, but I don't have my fast charger with me. I will keep it close to 10% til I get home.
dennisharrison
81
I'm not sure we should be advocating running this on phones carteblanch:
http://forum.xda-developers.com/showthread.php?t=2561236&page=3
anon(9228075)
520
If we got a fix for the WiFi cell standby bug I'd be happy camper.
I'm 11 hours on battery, 6 of them sleep overnight time, 3:45 of screen on time, 44% left and my breakdown is 26% of use is cell standby.
26% !!!!!
burwil
798
20
18
If you have GSam please post your graph showing phone signal strength. Note here I arrive to work very early in the morning. My cell strength jumps up considerably as I get a much better cell signal at work than at home.
Aaron_Jones
Active member
Dec 28, 2015
44
I hope I can get a MOD to delete this post and I will repost the right one...
anon(9228075)
520
burwil
798
20
18
Mine updated with more data..
Point of all this is that a weak signal is going to drain your battery more. And while I see that Gsam looks at your phone signal and classifies it as 'medium' I bet if you look at Settings/System/About Device/Status/Sim card status, you'll find your signal strength probably near or above -100 dbm....anything in triple digits is bad. For example, in an extreme case, I took a trip out to the sticks while on T-Mobile. My cell coverage was horrible...I was barely getting any signal at all. I come home and look at my data usage....it had skyrocketed during that period even though it wasn't receiving any data. I could only surmise it was the cell phone working extra hard to grab signal.
Venom0642
2,361
340
83
Here's how 4G LTE Network in my area works so far, and this isn't bad it's normal
Of course if i was at home with wifi it's better.
burwil
798
20
18
That's kinda my profile. When it's mostly not in use, about 3% per hour. It was even better before I added my Gear S2 Watch and a bunch of apps.
WillyC
